Van Cafe Subie coolant tank sensor wire connection?
dubbified
dubbified is offline
PostPosted: Mon Jul 14, 2025 6:14 pm    Post subject: Van Cafe Subie coolant tank sensor wire connection? Reply with quote
Need to connect the low coolant sensor.. No oem harnesses, needing to identify which color wires to connect to in that lil black box in the front, left of the bay. Its a 90 auto mv originally the 2.1..
thought it was the blue/green striped wire but nay..
Ugggh here is where you all can laugh an say rtfm..
All this long game project work, lost the installation paper.. Vc closed at the moment.
Its a single pin sensor atop the tank used in my alh tdi build.
Being my van is fully drivable now.. Getting ridda this blinking light would enhance my calm...
https://vancafe.com/van-cafe-aluminum-coolant-expansion-tank/
Any ideas are welcomed!
pbrown
pbrown is offline
PostPosted: Mon Jul 14, 2025 8:04 pm    Post subject: Re: Vancafe subie coolant tank sensor wire connection? Reply with quote
There are two wires to connect. The brown is ground and is connected to one of the tanks mounting bolts with a ring terminal. The other connect to the sensor at the top.
Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF
dubbified
PostPosted: Mon Jul 14, 2025 8:34 pm    Post subject: Re: Vancafe subie coolant tank sensor wire connection? Reply with quote
Thanks!
wesitarz
wesitarz is offline
PostPosted: Mon Jul 14, 2025 9:02 pm    Post subject: Re: Vancafe subie coolant tank sensor wire connection? Reply with quote
Blue/green and the brown in the T7a round connector in the black box
dubbified
PostPosted: Mon Jul 14, 2025 9:50 pm    Post subject: Re: Vancafe subie coolant tank sensor wire connection? Reply with quote
Thanks, had just run blue, green to the primary lead no ground, assuming chassis ground was good enough.. I'm on it..
Hopefully no more blinking dash light..
Thanks!
dubbified
PostPosted: Fri Jul 25, 2025 9:09 pm    Post subject: Re: Vancafe subie coolant tank sensor wire connection? Reply with quote
Oddly, for a time, that light went out.
It came back on. The ALH outputs from the FastForwardCA harness are correctly signalling the coolant meter on the odo..
But the blinking coolant low led is still trippin. That's blue green patched to the tank lead on the top, and a ground to the side of the tank, bolted down and grounded to the brown lead in the box.
mmmm.
but it sure does drive very nice. I took a buddy from Seattle/Eastside to i-90 seattle, a range of city driving, and busted out to the Alpental Ski area.. all freeway while datalogging VCDS.. and charting.. its so lean... and clean..
And it whistles.. I have a boostvalve for it, and was geeking out on the fine tuning.. I'm 500 miles on this build now..
Pesky led light.. would be nice to have some confidence in that circuit.. its even soldered!
pbrown
pbrown is offline
PostPosted: Fri Jul 25, 2025 11:00 pm    Post subject: Re: Vancafe subie coolant tank sensor wire connection? Reply with quote
You might want to look at the low coolant controller. It looks like a relay and is installed at relay space #3 in your fuse panel for 86 newer. You might have a bad controller circuit.
Patrick Brown
dubbified
PostPosted: Sat Jul 26, 2025 7:11 am    Post subject: Re: Van Cafe Subie coolant tank sensor wire connection? Reply with quote
Thanks for that suggestion Pbrown!
I did a search, and found, https://www.thesamba.com/vw/forum/viewtopic.php?t=657993
That article seems to diagnose an earlier model, but similar.
Glad for the direction!
dubbified
PostPosted: Sat Jul 26, 2025 8:26 am    Post subject: Re: Van Cafe Subie coolant tank sensor wire connection? Reply with quote
Alright, I'm happy to say..
I keyed on the ignition, see the led flashing..
I grabbed the #3 module, and wiggled it..
No more light.
Smile Problem solved
Thanks again!
