Steering rack hose adapters
DougR
DougR is offline
PostPosted: Tue Jul 15, 2025 5:11 pm    Post subject: Steering rack hose adapters Reply with quote
I bought my rack from Van Cafe more than a year ago and never installed it Because I had an engine failure. Now that that’s taken care of I started the install. I have everything in place and was about to move the hose adapters from the old rack to the new rack and they don’t fit! The threads look clean on the old rack, the new rack, and the adapters. The adapters going about one and a half turns and then bind. I don’t want to force them. I don’t recall what brand the rebuilt rack is, but I think it’s Meyle. Has anyone had this experience, and what did you do?
I understand these fittings are really hard to find. My tap and die set ends at M 12, but the threads on everything look like they are 1.50. The plastic cap that covers the opening fits both racks nicely. Any advice is appreciated.
Thanks! Doug
'85 Westy 1.9L (currently in need of a new engine)
vanis13
vanis13 is offline
PostPosted: Tue Jul 15, 2025 5:47 pm    Post subject: Re: Steering rack hose adapters Reply with quote
Have you asked the place you bought it? If so, what did they say?
DougR
DougR is offline
PostPosted: Tue Jul 15, 2025 7:40 pm    Post subject: Re: Steering rack hose adapters Reply with quote
Not yet. They were closed when I called. It’s on the list for tomorrow.
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Jul 16, 2025 12:00 am    Post subject: Re: Steering rack hose adapters Reply with quote
A rebuilt rack would be compatible as it's a ZF unit (VW).
The newly made ones are most likely JP Group, I've installed a few, the threads are also the same, but that could have changed on a new unit.
That is odd...
DougR
DougR is offline
PostPosted: Wed Jul 16, 2025 12:14 pm    Post subject: Re: Steering rack hose adapters Reply with quote
I filled out the, “ask an expert“ form on an Cafe’s website. I immediately got a response that said they are having an unusually high volume of questions. I’m pretty sure it says that year-round. Anyway, I’m sitting here high and dry until I figure this out. I think I’m going to try my local Ace Hardware store and see if I get some matching bolts and see how well they thread into these openings.
vanis13
vanis13 is offline
PostPosted: Wed Jul 16, 2025 2:15 pm    Post subject: Re: Steering rack hose adapters Reply with quote
They used to be really good about taking calls... Maybe that has changed?
RoryGirl
RoryGirl is offline
PostPosted: Wed Jul 16, 2025 5:30 pm    Post subject: Re: Steering rack hose adapters Reply with quote
Fill the (oiled) hole up with some dollar-store playdoh, then carefully unscrew. Measure the threads.
1991 Twin Slider VR6
1985 Audi 4k
DougR
DougR is offline
PostPosted: Thu Jul 17, 2025 10:54 am    Post subject: Re: Steering rack hose adapters Reply with quote
I’m not going to stick Play-Doh in there. I like the way you’re thinking, but that makes me nervous. I just bought a thread tester. It will be interesting to see what comes of it.
?Waldo?
?Waldo? is offline
PostPosted: Thu Jul 17, 2025 11:06 am    Post subject: Re: Steering rack hose adapters Reply with quote
I would use a thread pitch gauge set and calipers.
DougR
DougR is offline
PostPosted: Thu Jul 17, 2025 1:27 pm    Post subject: Re: Steering rack hose adapters Reply with quote
Tried the thread tester. Same results. Won’t go past 1/4 to 1/2 turn. My tap and die set has a thread pitch gauge. That with a camera and I can see that it looks like a 1.5. Calipers tell me it’s M16 and M14. The plastic cap that came with it is a perfect 1.5. Really hard to see into this cavity after the rack is in place - so annoyed that I didn’t do this before the rack was installed.
Wellington
Wellington is offline
PostPosted: Fri Jul 18, 2025 2:16 am    Post subject: Re: Steering rack hose adapters Reply with quote
https://www.amazon.ca/EAWONGEE-Detachable-Suitable...9&th=1
this type of tool has been invaluable at times.
ALIKA T3
ALIKA T3 is offline
PostPosted: Sat Jul 19, 2025 11:33 am    Post subject: Re: Steering rack hose adapters Reply with quote
Look also that there's no nicks in the female threads, who knows, but it looks like the tooling was off that day in China. They don't check for deviations and recalibrate every 2 blue moons, poor QC that let this one slide is entirely possible.
Try something with 1.25 pitch or send a clear picture, I can tell most threads sizes and pitch by eye but in real life.
syncrodoka
syncrodoka is offline
PostPosted: Sat Jul 19, 2025 1:02 pm    Post subject: Re: Steering rack hose adapters Reply with quote
Measure the fittings going into the rack, a bottoming tap should clean up the rack threads quickly.
MarkWard
MarkWard is offline
PostPosted: Sat Jul 19, 2025 1:16 pm    Post subject: Re: Steering rack hose adapters Reply with quote
In a pinch, I have made a thread chaser using a proper size bolt and cutting lengthwise slits into the threads.
AlfromNH
AlfromNH is offline
PostPosted: Sun Jul 20, 2025 3:01 am    Post subject: Re: Steering rack hose adapters Reply with quote
Clever!
‘88 2wd Auto Westy project
