talljordan Samba Member
Joined: January 10, 2012 Posts: 1103 Location: San Francisco, CA
Posted: Tue Jul 15, 2025 10:59 pm Post subject: Engine case pitting under strainer. Fill with JB? |
Pic shows the pitting well, its rather deep. Should I fill er up with some JB weld? Or leave as is. I have always had leak issues from here. The stud it is next to is also helicoiled due to a previous strip.
_________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11091 Location: Oregon
Posted: Tue Jul 15, 2025 11:28 pm Post subject: Re: Engine case pitting under strainer. Fill with JB? |
Don't mess with it. It'll seal just fine like it currently is.
Do get some replacement drain cover studs. Using blots there is asking for trouble down the road. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Tue Jul 15, 2025 11:39 pm Post subject: Re: Engine case pitting under strainer. Fill with JB? |
yep theyre in the mail. Took this photo today while removing the old ones that I didnt trust.
I got the ones with a shoulder from WW, they have mixed reviews here, but I think theyll be fine.
I also purchased their silicone seal kit, as the cardboard has never sealed for me _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Posted: Tue Jul 15, 2025 11:45 pm Post subject: Re: Engine case pitting under strainer. Fill with JB? |
talljordan wrote: |
I also purchased their silicone seal kit, as the cardboard has never sealed for me |
I have used the silicone before.
They are a little fragile, but reusable a few times.
Check your drain cover to make sure that the mating surface is flat and makes a good seal to the case.
If any of the stud holes are dimpled toward the case, flatten them. _________________ I have learned over the years.
Buy Once, Cry Once!
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2050 Location: Wichita, KS
Posted: Wed Jul 16, 2025 5:47 am Post subject: Re: Engine case pitting under strainer. Fill with JB? |
67rustavenger wrote: |
I have used the silicone before. They are a little fragile, but reusable a few times. |
More than just a few times, in my experience — I’ve had the same set of those silicone sump gaskets on my car for over 6 years now. I just clean and reuse them every time I change the oil. They’ve never leaked on me yet!
Recommend exercising reasonable care when removing and installing them, plus using the correct tightening sequence & torque on the nuts that hold it all down. _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33088 Location: Hot Arizona
Posted: Wed Jul 16, 2025 6:44 am Post subject: Re: Engine case pitting under strainer. Fill with JB? |
talljordan wrote: |
Pic shows the pitting well, its rather deep. Should I fill er up with some JB weld? Or leave as is. |
Leave as is.
talljordan wrote: |
I have always had leak issues from here. |
So have many others ! Right now I'm using the silicone gaskets on my two VWs.
talljordan wrote: |
The stud it is next to is also helicoiled due to a previous strip. |
Leave that be, as long as it stays. Myself: I'd order 7mm x 6mm step stud or 8mm x 6mm step stud to have on-hand should that fail. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4488 Location: viroqua wi.
Posted: Wed Jul 16, 2025 9:20 am Post subject: Re: Engine case pitting under strainer. Fill with JB? |
Clean well and 'paint' the paper gaskets with Permatex 3H snug down wait an hour till final sequence torque and wait a day before putting oil in. Works for me. The only downside is clean up. I also put a drop in my acorn nuts, it will squeeze out and coat your crush washers. Every thing needs to be squeaky clean, flat cover with no dimples for satisfactory results. |
Cusser Samba Member
Posted: Wed Jul 16, 2025 10:33 am Post subject: Re: Engine case pitting under strainer. Fill with JB? |
bsairhead wrote: |
Clean well and 'paint' the paper gaskets with Permatex 3H snug down wait an hour till final sequence torque and wait a day before putting oil in. Works for me. The only downside is clean up. |
Denatured alcohol or 90% isopropyl alcohol will clean up brown Permatex Aviation. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Jul 16, 2025 12:09 pm Post subject: Re: Engine case pitting under strainer. Fill with JB? |
Cusser wrote: |
bsairhead wrote: |
Denatured alcohol or 90% isopropyl alcohol will clean up brown Permatex Aviation. |
Yep, denatured alcohol works great for lots of things. And it has that good hospital smell. |
Posted: Wed Jul 16, 2025 9:05 pm Post subject: Re: Engine case pitting under strainer. Fill with JB? |
Replaced most of the studs with the WW ones, and silicone seals. So far looking promising. However I don't think the red loctite is working, the oil contamination seems to prevent it working.
For future readers. The long side of the WW shouldered studs goes into the case, the short end is for the nuts. Don't make the same mistake I did! By sinking the long end of the studs until they wouldn't turn further, each stud was ~1cm extended out of the case which is correct. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Posted: Wed Jul 16, 2025 9:22 pm Post subject: Re: Engine case pitting under strainer. Fill with JB? |
talljordan wrote: |
For future readers. The long side of the WW shouldered studs goes into the case, the short end is for the nuts. Don't make the same mistake I did! By sinking the long end of the studs until they wouldn't turn further, each stud was ~1cm extended out of the case which is correct. |
Brake cleaner is your friend. I don't use anything on the studs. If they come out they come out. |
