Rear lock up
PYE
PYE is offline
PostPosted: Fri Jul 18, 2025 9:59 am    Post subject: Rear lock up Reply with quote
A week or so ago I reversed off my drive, when I came to drive forward my rear drivers side wheel was locked up, I reversed a bit and it freed up. Today I was driving down a gravel drive at about 10mph and the same wheel locked up. I reversed for a while then it was ok. I took the drum off, There does seem to be a lot more wear at the top of the shoes by the adjuster but everything else seems ok.??????? I put the drum half on and spun the axle in neutral and that seems fine. Not sure where to go from here.
thom
thom is offline
PostPosted: Fri Jul 18, 2025 10:08 am    Post subject: Re: Rear lock up Reply with quote
Had you applied the brakes immediately before the lock-up? Or were you rolling when it locked up? I've had a brake lining come loose and wedge against the drum, locking up the wheel; in my case it locked in reverse and freed up going forwards. If it's locking up without applying the brakes, then it's either something loose in the trans or reduction box; I had a car once where the ring gear bolts had come loose and would momentarily wedge themselves - that was not a pretty teardown.
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
Clara Premium Member
Clara is offline
PostPosted: Fri Jul 18, 2025 11:59 am    Post subject: Re: Rear lock up Reply with quote
If your brake shoes have uneven wear, they aren't adjusted frequently enough.
Adjust the brakes every 3K miles, same interval as valve adjustment.
Lube the beam/spindles/all zerks at the same time.
tranny oil should be checked/topped up every 6K miles (or every year if driven infrequently.)
Is this a bus that is driven regularly? Or had it been sitting for months?
I had a tranny which would freeze up momentarily in long drives in hot weather. My solution was to replace the trans.
PYE
PYE is offline
PostPosted: Fri Jul 18, 2025 12:13 pm    Post subject: Re: Rear lock up Reply with quote
I was rolling
PYE
PYE is offline
The bus is driven regularly
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Fri Jul 18, 2025 2:39 pm    Post subject: Re: Rear lock up Reply with quote
Possibly a wheel bearing going bad?
pondoras box
pondoras box is offline
PostPosted: Fri Jul 18, 2025 4:15 pm    Post subject: Re: Rear lock up Reply with quote
Pull the other drum and see if you have a leaking axle seal. It can cause the dry one to lock up and grab. Backing up forces the brake pads back and allows it to roll.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop
Another 65 hardtop
1973 standard bug
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion
sub-hatchtim
sub-hatchtim is offline
PostPosted: Fri Jul 18, 2025 9:00 pm    Post subject: Re: Rear lock up Reply with quote
Broken spring, shoe pin or maybe shoe lining separated from its backing
Sounds like the "front" shoe is catching and getting wedged then freeing up when reversing
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
BarryL Premium Member
BarryL is offline
PostPosted: Sat Jul 19, 2025 6:10 pm    Post subject: Re: Rear lock up Reply with quote
Locked up like totally skidding?
I had a broken tooth in the top RGB and it would do that until a final catastrophic failure.
