Four tab hood emblem
jeffros 58
jeffros 58 is offline
PostPosted: Wed Sep 03, 2025 6:23 pm    Post subject: Four tab hood emblem Reply with quote
The original emblem is so weak at the tabs if I bend them back to hold it to the hood I know they will break off . So we ordered a new one for it from WW has anyone had issues with the tabs not lining up with slots in hood ?? Fixes ? Anybody know of a new replacement one besides WW that fits correctly?
finster
finster is offline
PostPosted: Thu Sep 04, 2025 2:23 am    Post subject: Re: Four tab hood emblem Reply with quote
that looks like a later short 4 tab emblem of the type used with the 3 pin plastic insert. on the original 4 tab emblem the tabs are bent inwards then back so they match the diameter of the slot circle (which is smaller than the outer emblem diameter) as in this photo, the tabs are longer and also split
your options are to replace the tabs on the original by using thin sheet jb welded to the rim or buying one with tabs intact from the classifieds
lardawge
lardawge is offline
PostPosted: Thu Sep 04, 2025 4:49 pm    Post subject: Re: Four tab hood emblem Reply with quote
As Finster pointed out, you need to shape the tabs to line up with the holes.
11/2/54 L227 Strato Silver Ragtop - Build Thread
1/7/55 L275 Light Beige - Build Thread
9/1/56 (57 model) L331 Horizon Blue - For Sale
