sopru Samba Member
Posted: Tue Jul 29, 2025 12:22 pm Post subject: Brake lights faulty |
My Brake lights are not working when driving, if i press brakes when van is stationary they will come on but only after really pressing hard on the brake pedal, any help would be appreciated |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36033 Location: Conejo Valley, CA
Posted: Tue Jul 29, 2025 12:42 pm Post subject: Re: Brake lights faulty |
Do the brakes work fine despite the lamp behavior?
If so, it's likely failed pressure switch on the master cylinder. Even new ones are of suspect quality. Some have worked up a mechanical switch on the pedal assembly. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26118 Location: Olympia Wash Rinse & Repeat
Posted: Tue Jul 29, 2025 12:49 pm Post subject: Re: Brake lights faulty |
Sounds like you need a quality made brake sender to replace you old one. There are lots of cheap junky ones being sold out there.
Also good to install ground wires from each of the taillights to the body point the battery ground cable attaches to. VW finally installed ground wires there in 1971 at the factory to fix all the faulty ground problems that had plagued all the previous buses. _________________ In Stereo, Where Available! |
sopru Samba Member
Posted: Tue Jul 29, 2025 2:04 pm Post subject: Re: Brake lights faulty |
KTPhil wrote: |
If so, it's likely failed pressure switch on the master cylinder. Even new ones are of suspect quality. Some have worked up a mechanical switch on the pedal assembly. |
I will order a new switch and see if it solves the problem first, hopefully get a german quality instead of chinese one |
Posted: Tue Jul 29, 2025 2:09 pm Post subject: Re: Brake lights faulty |
sopru wrote: |
if this dosent work ill try earthing the lights as you suggested |
If it does work with the new switch or not, do install the grounding wires. _________________ In Stereo, Where Available! |
sopru Samba Member
Posted: Tue Jul 29, 2025 2:31 pm Post subject: Re: Brake lights faulty |
KTPhil wrote: |
yes brakes work fine |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15304 Location: Casa de Oro, California
Posted: Tue Jul 29, 2025 6:23 pm Post subject: Re: Brake lights faulty |
When you do get under there with the new switch, make the exchange as fast as you can so no fluid leaks out. |
sopru Samba Member
Posted: Wed Jul 30, 2025 2:22 pm Post subject: Re: Brake lights faulty |
BarryL wrote: |
just a thought iv had does it matter what wire goes on what terminal of the switch as there are no markings ? |
Posted: Wed Jul 30, 2025 2:26 pm Post subject: Re: Brake lights faulty |
sopru wrote: |
BarryL wrote: |
No. _________________ In Stereo, Where Available! |
sopru Samba Member
Posted: Wed Jul 30, 2025 2:29 pm Post subject: Re: Brake lights faulty |
Eric&Barb wrote: |
sopru wrote: |
BarryL wrote: |
No. |
thanks |
