johnlynch47 Samba Member
Joined: July 17, 2008 Posts: 271 Location: Bradenton, Fl
Posted: Thu Jul 31, 2025 7:29 pm Post subject: 73 bus 78 motor |
So I bought a bus, see above. Motor moves like a qtr of the way by hand, I cant get it to move more and im scared to put a battery and key to it, really nothing to grab onto to move it. I tried tightening the middle bolt and only tightened the bolt. I took spark plugs out and put marvels mystery oil in cylinders. Any help would be appreciated. _________________ "My shovel is sharp, my pick is sharp, and my will is outstanding." - Rod Marinelli
"I've got a good heart, but this heart can get ugly" Rapper DMX
"Bring your face over here so I can smack it" My Mom
1973 orange camper |
wiscowesty Samba Member
Posted: Thu Jul 31, 2025 8:35 pm Post subject: Re: 73 bus 78 motor |
Harbor china freight has economy minded boroscopes to peek inside spark plug holes. There in may clues be viewed. Take time to drain oil and search for evidance of thing gone askew. Some time looking over your valve train may shed light on the resistance you are encountering. Least on the top end. Certainly those in the know here on the forums, Will be of greater help than me. Good luck and fair roads to you. _________________ 78 westy. F.I., wrassling her back together |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42679 Location: at the beach
Posted: Thu Jul 31, 2025 9:28 pm Post subject: Re: 73 bus 78 motor |
amazon has depstech cameras at pretty good prices. ($54). Has a main lens and one on the side. That is probably the least costly way to find what is stopping the piston from moving without taking the engine apart. They also have articulating lens cameras for a little more but the $54 is probably adequate. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
timvw7476 Samba Member
Posted: Thu Jul 31, 2025 10:08 pm Post subject: Re: 73 bus 78 motor |
If you want the quick answer just select second gear & shove it several feet .
Then recheck the crankshaft, turning it via the alternator nut . The little 13mm bolt at the center is just to jam the three bolt flange down on the crank snout.
Not breaking rings loose. Don't use it for that. |
