drwecki Samba Member
Posted: Mon Aug 04, 2025 8:28 pm Post subject: Can’t get turn signal switch installed. |
Hey all,
I simply can’t get the switch to seat. I can consistently screw in the upper right screw. But not the other 3 that seat the switch. I can screw them in with no switch in the way. Not stripped.
Any tips? I have no idea what’s going on there but no matter what I try, I can’t get the screws in when the switch is in.
Am I missing something here?
1969 bug |
OldSchoolVW's  Samba Member
Joined: July 03, 2020 Posts: 1596 Location: San Diego
Posted: Mon Aug 04, 2025 8:33 pm Post subject: Re: Can’t get turn signal switch installed. |
Check to see if you can pull the wires further forward and allow the switch to seat further into the column. _________________ Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
Posted: Mon Aug 04, 2025 8:46 pm Post subject: Re: Can’t get turn signal switch installed. |
| OldSchoolVW's wrote: |
| Check to see if you can pull the wires further forward and allow the switch to seat further into the column. |
I’ve tried that. No luck. I’ll keep at it, though. Thank you. |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11474 Location: Huntington Beach, CA
Posted: Mon Aug 04, 2025 10:51 pm Post subject: Re: Can’t get turn signal switch installed. |
This sounds like a shitty part. Is it? Where did you get it from? This part is typically poorly manufactured, from the aftermarket section. Even when the cars were still new, the cheap aftermarket stuff stunk! It has only become more putrid as time has marched on.
On the other hand, do all 4 screw holes align with the housing?
Did you keep your old (I hope it is a VW OG one) switch. You may have to rebuild it! You can (sometimes) rebuild an OG switch using the shitty aftermarket switch (after disassembling it) as a parts source. Might be worth a try. You have no way to make it worse! _________________ Jimbo
| TDCTDI wrote: |
| Basically, a whole bunch of fuckery to achieve a look. |
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Posted: Tue Aug 05, 2025 6:33 am Post subject: Re: Can’t get turn signal switch installed. |
| VW_Jimbo wrote: |
Did you keep your old (I hope it is a VW OG one) switch. You may have to rebuild it! You can (sometimes) rebuild an OG switch using the shitty aftermarket switch (after disassembling it) as a parts source. Might be worth a try. You have no way to make it worse! |
It’s the original part. I removed it when troubleshooting my horn and wanted to test the switch. I don’t know how to get it realigned. You can’t really see through the switch. I have used some small screwdrivers to line up the holes, but I can’t get it in far enough to get the screw to catch. I bought a new switch last night as I think my old one may be done, but I’ll keep trying. Has anyone else had this problem? Is it hard to get in? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33492 Location: Hot Arizona
Posted: Tue Aug 05, 2025 6:52 am Post subject: Re: Can’t get turn signal switch installed. |
| drwecki wrote: |
Depends on the gal....
The turn signal switch itself needs to be pushed further towards the front of the VW, the wires are getting hung up somehow in the channel/opening. I just replaced the TS switch in my own 1970 maybe a month or two ago and had similar issue. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
