anniewyo Samba Member
Joined: December 06, 2024 Posts: 28 Location: Sheridan, WY
Posted: Tue Aug 05, 2025 7:24 am Post subject: Headlight Removal - Screw Help |
Hi, I am sure this is just redundant and it has probably been addressed in these forums before, but I just need advice on removing my headlight on my 56. There is a short in the turn signal wire and I need to get to the wire coming from the headlight area. I don't want to slip with the large screwdriver to remove the bottom screw as it is stuck -- but I can't figure out if I use liquid wrench if it will seep past the spacer and do any good. Headlights have not removed since 1986.. Any thoughts or advice. I am on my own here. Thanks for all your help -- Ann E. |
finster Samba Member
Joined: May 26, 2012 Posts: 10128 Location: not far from the madding crowd
Posted: Tue Aug 05, 2025 8:07 am Post subject: Re: Headlight Removal - Screw Help |
it's worth giving it a blast of penetrating oil - it wont do any harm. if you're worried about scratching the paint then tape thick cardboard to the area. if a screw is stubborn I often try turning it tighter first, just enough to break the grip of the rust. another tip is to use an adjustable wrench to grip the blade of the screwdriver and give better leverage. _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
panicman Samba Member
Joined: December 18, 2011 Posts: 2654 Location: Canby, OR
Posted: Tue Aug 05, 2025 8:12 am Post subject: Re: Headlight Removal - Screw Help |
You can try Liquid Wrench from both sides. Inside the fender, just below the bucket, you should see the back side of the weld nut that the headlight screw is threaded into. Apply your lubricant there and then on the front, where it should creep in. Repeat applications over time always helps.
I personally would try using a large screwdriver on that screw, when it is time, and grab the shaft of the screwdriver with vice grips, and use it to add leverage to your twist. |
Joined: April 27, 2002 Posts: 6805 Location: Pentwater, Michigan
Posted: Tue Aug 05, 2025 12:21 pm Post subject: Re: Headlight Removal - Screw Help |
Use the big screwdriver! Try some light taps on the back end of the screwdriver with a hammer. The vibration will help break the screw loose. _________________ Roads Scholar
Member# 2059 |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26062 Location: Olympia Wash Rinse & Repeat
Posted: Wed Aug 06, 2025 3:08 pm Post subject: Re: Headlight Removal - Screw Help |
Also best to not only turn to loosen, but also turn to tighten. Tightening can crush the rust in the threads to turn it to dust. Then work the fastener back and forth working in the penetrating oil. Beware just turning out the fastener, the rust can bunch up in the threads shoving the shaft over hard enough to cause it to weld the threads together. If the fastener feels like it is getting harder to turn, reverse the turning and work in more oil. _________________ In Stereo, Where Available! |
my59 Samba Member
Joined: August 13, 2003 Posts: 3983 Location: connecting the dots
Posted: Wed Aug 06, 2025 4:43 pm Post subject: Re: Headlight Removal - Screw Help |
I go for Kroil if PB Blaster doesn't do the job on penetrating, and leave it overnight to soak in. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Wed Aug 06, 2025 8:46 pm Post subject: Re: Headlight Removal - Screw Help |
Thanks everyone for your help. Good old-fashioned liquid wrench and a little patience spraying it a few times over a 24 hour period, a couple hammer taps as someone mentioned, and both screws broke loose! Problem solved! Ann |
kintail Samba Member
Posted: Thu Aug 07, 2025 12:44 am Post subject: Re: Headlight Removal - Screw Help |
Using an air powered rivet gun on the headlight screw from the backside carefully would work to loosen it very quickly as well. Another option.. _________________ Scott
August 1954 Beetle Canadian Deluxe |
