1969 Under Dash Pics
adventurebob
adventurebob is offline
PostPosted: Sat Aug 09, 2025 9:03 am    Post subject: 1969 Under Dash Pics Reply with quote
Im looking for a pic of the wiring from the steering column through the bulkhead into the frunk. How's it routed? Is it in a loom? Whats the loom material? Is it the smooth viynl or is it braided? Is through a grommet? The original just had a bunch of wire run through a hole drilled by a PO.
If someone with a 69 could grab a couple of happy snaps Id be grateful.
Have a great morning.
redhot
redhot is offline
PostPosted: Sat Aug 09, 2025 10:49 am    Post subject: Re: 1969 Under Dash Pics Reply with quote
Fom the gallery pages; stated as ยจ78 while to my recollection it is not much different on the earlier '70s, while may be some differences as on especially get closer/into the late 60's.
Multi-pin connectors on the steering column/switch housing, with the harness going throug a grommet close to the fuse box
redhot
redhot is offline
PostPosted: Sat Aug 09, 2025 10:50 am    Post subject: Re: 1969 Under Dash Pics Reply with quote
Similar for the gallery; stated as '70
redhot
redhot is offline
PostPosted: Sat Aug 09, 2025 10:53 am    Post subject: Re: 1969 Under Dash Pics Reply with quote
Stated as 1974;
redhot
redhot is offline
PostPosted: Sat Aug 09, 2025 10:54 am    Post subject: Re: 1969 Under Dash Pics Reply with quote
Stated as '68
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Sat Aug 09, 2025 3:41 pm    Post subject: Re: 1969 Under Dash Pics Reply with quote
From my '69:
There was originally a vinyl sheath (factory) over these wires which needed to be cut away when I installed a new turn signal switch. I didn't bother wrapping them since they aren't really visible unless you crawl under the dash.
Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
viiking
viiking is offline
PostPosted: Sat Aug 09, 2025 4:25 pm    Post subject: Re: 1969 Under Dash Pics Reply with quote
OldSchoolVW's wrote:
From my '69:
It also helps the Hollywood hero in the movies to rip the wires out with his bare hands and instantly find the right two wires to fire up that beast.
adventurebob
PostPosted: Sun Aug 10, 2025 3:46 pm    Post subject: Re: 1969 Under Dash Pics Reply with quote
Thanks folks, very helpful.
