LeeFred Samba Member
Joined: October 13, 2023 Posts: 119 Location: Arizona
Posted: Thu Aug 14, 2025 10:23 am Post subject: 74 SB Windshield Washer Nozzle Adjustment |
| Is it possible to adjust the windshield washer nozzle at the base of the windshield so that the stream hits the windshield? I installed an aftermarket electric pump/reservoir as suggested by Cusser, but the two streams launch over the top of the windshield with just a very small portion hitting the windshield. |
Mben Samba Member
Posted: Thu Aug 14, 2025 10:57 am Post subject: Re: 74 SB Windshield Washer Nozzle Adjustment |
| Should be able to place a small pin in the nozzle outlet and then be able to move it around. This worked on my original 71. I have a replacement nozzle and this does not appear to be adjustable. |
a8ked Samba Member
Joined: April 06, 2024 Posts: 62 Location: Seattle area
Posted: Thu Aug 14, 2025 10:58 am Post subject: Re: 74 SB Windshield Washer Nozzle Adjustment |
| I've used a VERY fine drill bit that will fit into the hole in the nozzle. The nozzle has a round ball with a hole in it that can be swiveled to adjust the spray location/direction. I'm talking about a drill bit much smaller diameter than a paperclip, its almost like a strand of stiff wire. This same bit works to clean out wax that sometimes gets into the nozzle. |
jinx758 Samba Member
Joined: October 04, 2014 Posts: 1046 Location: half a bubble from plumb
Posted: Thu Aug 14, 2025 10:59 am Post subject: Re: 74 SB Windshield Washer Nozzle Adjustment |
Had to do this WAY back on my '69 Dart.
I used a medium gauge sewing needle inserted into the metal sleeve & gently pulled down.
Worked a treat !
Not sure if this will work on a VW, never owned one with a working squirter.
Good luck ... stay safe
jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
Posted: Thu Aug 14, 2025 11:09 am Post subject: Re: 74 SB Windshield Washer Nozzle Adjustment |
| Thanks everyone. I'll give it a try when I get home tonight. |
