sfizio Samba Member
Joined: November 30, 2014 Posts: 84 Location: Norwalk Connecticut
Posted: Fri Aug 15, 2025 9:30 am Post subject: Vent cable connection. |
I think my flapper is missing. Not sure I ever had one but this is the way I got it back from the body shop after new heater channels and floor boards were installed. When I asked about it, all they gave me was the body shop shrug. To clarify, that y tube is disconnected and propped up on the floor board for the photo. I found that cable hooked onto a small cross member inside the tube (maybe a vent connection pivot point?). That cable is connected to the left lever with the white knob (airflow only?). The cable runs through the trans channel to a steel tube offshoot which has a welding tab although it is unattached. The cable sits inside the tube. The red knob cable is not visible but I can hear it operating a vent somewhere behind the back firewall. So, what does the vent flapper look like? Where to find one? Do I really need it? Where’s the weld point for that cable tube? Any and all info is most helpful. Thanks all.
_________________ Like me, looks good from 10 feet away. |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11183 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Fri Aug 15, 2025 9:36 am Post subject: Re: Vent cable connection. |
https://www.thesamba.com/vw/forum/viewtopic.php?t=261941 _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
sfizio Samba Member
Posted: Fri Aug 15, 2025 9:40 am Post subject: Re: Vent cable connection. |
Thanks! Big help _________________ Like me, looks good from 10 feet away. |
