Electric fan for engine cooling
froger
froger is offline
PostPosted: Tue Sep 16, 2025 4:23 am    Post subject: Electric fan for engine cooling Reply with quote
As above has the picture I've added ever become a thing and do you think it would be successful for cooling a type 4 2L engine cylinders ? Has anyone used electric fans for cooling ? Cheers
airschooled
Air-Schooled
airschooled is offline
PostPosted: Tue Sep 16, 2025 4:50 am    Post subject: Re: Electric fan for engine cooling Reply with quote
That’s really good for drag racing where you don’t run a fan during the pass for maximum hp.
And internet clout.
That’s an extreme performance engine pictured, so it’s likely torn down more frequently than I rotate my tires.
Robbie
www.airschooled.com
Road trip reports and tech blog:
SGKent Premium Member
SGKent is offline
PostPosted: Tue Sep 16, 2025 9:20 pm    Post subject: Re: Electric fan for engine cooling Reply with quote
no but they have some that run off pressurized air in a tank. Only issue is that you'd be stopping at every service station to fill the pressure tank. They were designed for deep river crossing buses where the water shorts out the electric fans. Gotta be careful around male hippopotamuses if you are river crossing in Africa. They get confused about it being a bus and not a female hippo in heat. Wink
George Carlin:
Skills@EuroCarsPlus:
Wildthings
Wildthings is offline
PostPosted: Wed Sep 17, 2025 7:28 am    Post subject: Re: Electric fan for engine cooling Reply with quote
One of the great things about the Type 4 engine, is that the fan is driven directly by the crankshaft, no belts and idler pulleys to fail leave one sitting on the side of the road with a destroyed engine, same with requiring no electricity and electrical components susceptible to engine killing failures.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Sep 17, 2025 7:31 am    Post subject: Re: Electric fan for engine cooling Reply with quote
Wildthings wrote:
One of the great things about the Type 4 engine, is that the fan is driven directly by the crankshaft, no belts and idler pulleys to fail.
I guess that just means you can drive it till the battery dies from no alternator.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
rsbadura
rsbadura is offline
PostPosted: Wed Sep 17, 2025 8:12 am    Post subject: Re: Electric fan for engine cooling Reply with quote
for dimensioning:
the smaller type 1 1600ccm AS engines in-build (behind the alternator) fan generate
620 Liter (or 164 gallons) per second(!)
at 4000 revolutions per minute of the engine.
(Source: page 20 of https://www.volkswagen-classic-parts.com/content/d...en_1_7.pdf)
I have no values for the type 4 engines... sorry.
At a water cooled Bugatti Chiron it is 1000 Liter air per second at top speed.
A mid size industrial vacuum cleaner have only 70 L / second.
Also keep in mind the temperature range is not consumer electronics - it is more expensive automotive.
good luck,
Rolf-Stephan Badura
1970 VW Karmann-Ghia Coupe
1979 VW Bus L camper conversion
1982 Eriba Pan travel trailer
2017 VW CrossPolo
HAZET classic tools collection
Wildthings
PostPosted: Wed Sep 17, 2025 10:23 am    Post subject: Re: Electric fan for engine cooling Reply with quote
If you push start and don't drive at night not having an alternator would limit you to one trip across country. Smile
SGKent is offline
PostPosted: Wed Sep 17, 2025 12:42 pm    Post subject: Re: Electric fan for engine cooling Reply with quote
am available Tuesday if you want to try it but have to be home Tuesday night. Sounds like fun Mike. Laughing An alternative method of starting once the battery has hosed - assuming there is enough to run the ignition. I made it once from Solvang to Anaheim at night when the generator on my 1971 crapped out because I was too late changing the brushes ... It was just starting to misfire from low voltage as I got into Anaheim. Put it on a battery charger for an hour and finished the trip back to Riverside. There I was greeted with a housemate crazed on drugs waving a pistol around at people. Spent the night somewhere else. Drugged crazies are not the best people to be around when they are waving pistols around.
George Carlin:
Wildthings
PostPosted: Wed Sep 17, 2025 3:34 pm    Post subject: Re: Electric fan for engine cooling Reply with quote
Ten'ish years ago I lost the generator on my T-181 Thing in West Yellowstone on a Friday and decided I could just continue my trip through the park and make it to Helena where I was heading on the existing charge on the battery. At some place outside of the park I decide to buy a group 27 battery and hooked it up in parallel with the older one and continued on my way driving only during the day figuring I would be able to get either brushes or a replacement generator in Helena. But it was no dice on a generator in Helena and none of the several VW houses I contacted elsewhere had the generator or if they did were willing to ship General Delivery, the safest way to ship out there Evil or Very Mad . So I just decided I could finish my trip with the setup I had. From Helena I made a 2000 mile road trip home with included using the starter a few times but never the headlights and only bothered to have the dual battery setup recharge once I got close to home. At that point I ordered a factory new generator and put the Group 27 onto my pickup which was in need of one, so overall it had cost me nothing extra.
The guys at the autoparts where I bought the Group 27 thought is was really cool that I was making up a jury rig to stay on the road and even hung around 15 minutes after closing in case I needed anything else, which I thought was pretty incredible.
jjvincent
jjvincent is offline
PostPosted: Wed Sep 17, 2025 4:21 pm    Post subject: Re: Electric fan for engine cooling Reply with quote
Looks like for drag racing. My dad drag raced back in the early 70's with a bug and he had no fan. Living your life a quarter mile at a time and back then, no fan needed. I could see that it would be nice to have today as you can cool it off more consistently between runs.
Formula Vees have no fan and they just use ducted air. Plus they toodle around the paddock all day long. They pretty much are pushing very little weight and the engine is small, not cranking out much power.
For everyday use, it would be a terrible idea. You are relying on the fan constantly and would actually need to start monitoring head and oil temp to set up a strategy for it to run at multiple speed and on and off.
Back when we ran a 356 in SCCA racing we experimented with no fan but just used the two headlight openings to catch air and feed the engine. That didn't work. We were pushing that engine way too hard. Plus it had a front oil cooler on it.
NASkeet
NASkeet is offline
PostPosted: Sat Sep 20, 2025 10:52 am    Post subject: Re: Electric fan for engine cooling Reply with quote
rsbadura wrote:
for dimensioning:
good luck,
Be careful when referring to gallons; keeping in mind that there are proper Imperial Gallons as still used by some in the United Kingdom of Great Britain & Northern Ireland and Olde English Queen Anne wine-gallons (plagiarised by the USA and renamed US gallons! Shocked )
https://en.wikipedia.org/wiki/Gallon
There was some data for the VW Type 4 style air-cooled engine's crankshaft-driven cooling system, which was cited in one of Peter Noad's Pacenotes articles, in the VW Motoring magazine, which I think I later quoted in Transporter Talk magazine.
Regards.
Nigel A. Skeet
https://vwt2oc.co.uk
