61karmann Samba Member
Joined: January 01, 2004 Posts: 157 Location: south San Francisco
Posted: Sat Oct 25, 2025 11:26 am Post subject: Pulley size 36hp 40hp |
In my 36hp, the generator pulley is 98mm. My 6v generator is from a 1960 so thats a 40hp.
Would anyone recommend using a 40hp pulley at 107mm?
Or the 36hp at 98mm? Im not sure if the newer generator needs to be accommodated for, or the fan cooling is more important _________________ www.tonydegrazia.com
www.analogtattoo.com |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1863 Location: Warren, PA
Posted: Sat Oct 25, 2025 11:42 am Post subject: Re: Pulley size 36hp 40hp |
I know people use larger pulleys opposite of the power pulley theory to get better cooling. But you got to be careful not to over drive your fan the can explode. But I don’t really think it’s going to be a issue on a stock 36 horse. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop (Arschloch)
1973 standard bug (Dirty Gertie)
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26197 Location: Olympia Wash Rinse & Repeat
Posted: Sat Oct 25, 2025 3:26 pm Post subject: Re: Pulley size 36hp 40hp |
| 61karmann wrote: |
Or the 36hp at 98mm? Im not sure if the newer generator needs to be accommodated for, or the fan cooling is more important |
Would first figure out if you have a cooling problem EG what is the highest oil temp you are getting to in the summer heat, especially when climbing a long slope uphill. _________________ In Stereo, Where Available! |
