75-911S Samba Member
Joined: May 22, 2010 Posts: 73 Location: Hartsville, SC
Posted: Sun Nov 02, 2025 10:09 am Post subject: engine out timing |
| I've never heard of this, but is there a way to set the static timing my 1600DP while it's still on the engine stand? By using a battery and coil or something? |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26632 Location: Douglas, WY
Posted: Sun Nov 02, 2025 10:30 am Post subject: Re: engine out timing |
Is this points or electronic ignition?
If it's points, yeah that's not hard. Points are just an on off switch and you clip an ohms/continuity meter up to the condenser wire and the rim of the distributor and see when the points change from connected to open... that is the firing point. _________________ Andy T.
"What is Glutamodo, Horror of Toyko, besides total, fiendish, quality-a-you brain!" |
Posted: Mon Nov 03, 2025 6:04 am Post subject: Re: engine out timing |
| Thanks Andy. Souinds easy enough. |
Schnitzelfuss Samba Member
Joined: September 18, 2024 Posts: 164 Location: North Alabama
Posted: Mon Nov 03, 2025 4:32 pm Post subject: Re: engine out timing |
| If you don’t have a Bentley manual there are videos on YouTube that will show you how to do it as well. |
Posted: Tue Nov 04, 2025 5:57 am Post subject: Re: engine out timing |
| Okay. I'll check my Bentley. |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6396 Location: 37.5N 77.1W
Posted: Tue Nov 04, 2025 9:12 am Post subject: Re: engine out timing |
| Quote: |
| see when the points change from connected to open |
be sure you're on the 'leading' edge of the distributor lobe for #1 cylinder _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
