summerof78 Samba Member
Joined: March 31, 2023 Posts: 206 Location: Wichita, Kansas
Posted: Tue Nov 04, 2025 8:48 am Post subject: Swing axle parts compatibility |
Which model years of gear box parts can be used interchangeably?
Specifically, I need a new differential for my '66 sedan. I need to narrow the search down. _________________ Lookin' for a wheel stamped 5/66 |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 874 Location: Eastern north carolina
Posted: Tue Nov 04, 2025 4:59 pm Post subject: Re: Swing axle parts compatibility |
| Since no one answered you I will give you my best recollection and if slightly off, hopefully someone will correct it. My recollection is that around 62 to 66 US bug used the same gearing so in that range would probably be be your best shot. |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1900 Location: Warren, PA
Posted: Tue Nov 04, 2025 5:40 pm Post subject: Re: Swing axle parts compatibility |
Pretty much anything from 61 to 68 will work. 67 and 68 axle length and end castings are longer but will still bolt right up. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop (Arschloch)
1973 standard bug (Dirty Gertie)
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17658 Location: Left coast, Canada
Posted: Sat Nov 08, 2025 1:57 pm Post subject: Re: Swing axle parts compatibility |
| summerof78 wrote: |
| Specifically, I need a new differential for my '66 sedan. |
Do you know if your car has its original gearbox?
If it does, and you only need a new differential, you need to look for one from a 61-66 Beetle trans. Your 66 ring gear is attached using 6 bolts. After 67, they used 8 bolts, so the diff is different. _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
Posted: Tue Nov 11, 2025 10:29 am Post subject: Re: Swing axle parts compatibility |
| Bruce wrote: |
| summerof78 wrote: |
If it does, and you only need a new differential, you need to look for one from a 61-66 Beetle trans. Your 66 ring gear is attached using 6 bolts. After 67, they used 8 bolts, so the diff is different. |
99% sure, though I haven't scraped off the sludge to get the numbers and verify. It is indeed 6 bolt.
That's the info I needed and no matter how many Google searches I did it wasn't coming up. Their stupid AI was useless.
Anyway, many thanks. _________________ Lookin' for a wheel stamped 5/66 |
brian rogers Samba Member
Joined: April 14, 2002 Posts: 157 Location: Salt Lake City, Utah
Posted: Wed Nov 12, 2025 11:54 am Post subject: Re: Swing axle parts compatibility |
| 62 to 66 are all the same. 67 is unique to 67 with long axel and short splines. 68 has long axel long splines. The difference is the bearing will interchange but axels, housings and bearing caps will not. IF the trans is complete they will interchange. |
