KBH67 Samba Member
Joined: October 09, 2024 Posts: 13 Location: Florence Arizona
Posted: Tue Nov 04, 2025 4:56 am Post subject: ODD "THUMP" |
| My 73 Super Beetle has an odd thump when coasting. It runs great, but when I let off the gas and start braking, you can hear a thump coming from the rear. Not from the motor but it's definitely in the back end. Any ideas? |
NJ John Samba Member
Joined: September 21, 2007 Posts: 3047 Location: HdG, MD & NJ
Posted: Tue Nov 04, 2025 6:46 am Post subject: Re: ODD "THUMP" |
A constant thumping or a single thump? _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
KBH67 Samba Member
Posted: Tue Nov 04, 2025 6:57 am Post subject: Re: ODD "THUMP" |
| NJ John wrote: |
| A constant thumping or a single thump? |
Constant |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80544 Location: Sneaking up behind you
Posted: Tue Nov 04, 2025 6:58 am Post subject: Re: ODD "THUMP" |
CV joint? _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
doug bugg Samba Member
Joined: March 08, 2003 Posts: 398 Location: Minneapolis
Posted: Tue Nov 04, 2025 7:45 am Post subject: Re: ODD "THUMP" |
Is it when you start braking and keep braking or after you let up off the brakes?
Are your rear shoes somehow wonky? _________________ "Knowledge is Good" - Faber College |
KBH67 Samba Member
Posted: Tue Nov 04, 2025 8:06 am Post subject: Re: ODD "THUMP" |
| doug bugg wrote: |
Are your rear shoes somehow wonky? |
It's not in the brakes. Does it when coasting, braking or whatever. |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4569 Location: viroqua wi.
Posted: Tue Nov 04, 2025 8:21 am Post subject: Re: ODD "THUMP" |
| Coasting in neutral? |
KBH67 Samba Member
Posted: Tue Nov 04, 2025 10:17 am Post subject: Re: ODD "THUMP" |
| bsairhead wrote: |
Coasting in neutral, or in gear. |
Glenn  Mr. 010
Posted: Tue Nov 04, 2025 10:41 am Post subject: Re: ODD "THUMP" |
This _________________ Glenn
Member #1009
#BlueSquare
Posted: Wed Nov 05, 2025 6:55 am Post subject: Re: ODD "THUMP" |
| KBH67 wrote: |
| bsairhead wrote: |
You can only coast out of gear in neutral or with the clutch pedal depressed. The engine under a load, or engine braking, is not coasting. _________________ "Knowledge is Good" - Faber College |
Posted: Wed Nov 05, 2025 7:15 am Post subject: Re: ODD "THUMP" |
| doug bugg wrote: |
| KBH67 wrote: |
| bsairhead wrote: |
You can only coast out of gear in neutral or with the clutch pedal depressed. The engine under a load, or engine braking, is not coasting. |
What about my question confused you? |
Posted: Wed Nov 05, 2025 8:14 am Post subject: Re: ODD "THUMP" |
Oh, nothing. Just saying that the only time you can coast is in neutral. _________________ "Knowledge is Good" - Faber College |
Posted: Fri Nov 07, 2025 7:56 am Post subject: Re: ODD "THUMP" |
| doug bugg wrote: |
| Oh, nothing. Just saying that the only time you can coast is in neutral. |
Am I not coasting when I depress the clutch in gear ? |
Posted: Fri Nov 07, 2025 8:32 am Post subject: Re: ODD "THUMP" |
| doug bugg wrote: |
| KBH67 wrote: |
| bsairhead wrote: |
Ummm, yeah. Like I said... _________________ "Knowledge is Good" - Faber College |
