Schepp Samba Member
Posted: Sat Nov 08, 2025 7:49 pm Post subject: Pertronix SVDA failure |
Add this thing to the junk pile.
Less than 1500 miles and it’s toast.
Pertronix coil tested good.
I was loaded up for a Rallycross event this weekend. Had just got gas and was heading back home. Spent months getting the car prepared for this weekend.
Then outa nowhere the car just died while waiting at a red light at the busiest intersection of town during commute time on Friday.
These two dudes were chilling on their porch smoking a joint when I broke down in front of their house. They helped me push the car onto the sidewalk. Super cool dudes.
My buddy towed me home with his 4Runner.
Missed the round 1 of the race today as I spent the day troubleshooting and tuning. Thankfully I had save the old crusty Bosch 009 points distributor and rusty black no name coil.
The car fired right up. Got the timing dialed in and drove great. It starts much quicker than the Pertronix did. I’m wondering if that was an indication it was having problems?
Not all is lost as I’ll be able to compete in round 2 tomorrow. No chance of winning as I missed round 1 but at least I can get the seat time.
I’m pretty upset because there’s so much hype around these things. We we’re literally just talking about the hit or miss quality of these units a couple weeks ago.
Now that I’ve experienced the death of one of these electronic units, I’ll never get another.
I’m pretty much convinced that I’ll be going back to points.
I could have had it back on the road in 30min if it were a points setup.
I learned a lot today.
Once this weekend is over it’s time to figure out what’s next.
I’m thinking a restored 034 svda?
While yes, the performance factor may not be as high, at least it will be reliable.
For me reliability more important than performance.
_________________ Bandit #19
1972 Baja Rallycross Bug |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80533 Location: Sneaking up behind you
Schepp Samba Member
Posted: Sat Nov 08, 2025 8:15 pm Post subject: Re: Pertronix SVDA failure |
Glenn,
5yrs new.
I’ve never see that thread before. Time to start reading… _________________ Bandit #19
modok Samba Member
Joined: October 30, 2009 Posts: 27754 Location: Colorado Springs
Posted: Sat Nov 08, 2025 8:57 pm Post subject: Re: Pertronix SVDA failure |
Sorry for your trouble, but glad to see the lessons we learned are still true.
Transistor ignition is a great invention.
but it can leave you high and dry
As it tends to work 100% or not at all
so the solution is
Just have a spare ready to plug in.
If your system makes it hard to "plug another one in", Change the system. |
oprn Samba Member
Joined: November 13, 2016 Posts: 15247 Location: Western Canada
Posted: Sat Nov 08, 2025 10:44 pm Post subject: Re: Pertronix SVDA failure |
Nothing like good old points for dependability and quick starting! In my limited experience electronic ignitions seem to have to turnover for a bit before they will lite the fire. This is not only with the pointless distributors but also the crank trigger I have.
Point in case, I needed to move both Buggies out of the hay shed today to get at something. Both have been sitting for about 6 weeks. The good old points engine started almost instantly but the crank triggered one would not fire on the first 4 tried but eventually did. Not even cold yet just a few degrees below freezing!
This by the way was my experience with Pertronics. https://www.thesamba.com/vw/forum/viewtopic.php?t=711733&highlight= _________________ Our cars get old, we get old but driving an old VW never gets old!
Schepp Samba Member
Posted: Sat Nov 08, 2025 10:45 pm Post subject: Re: Pertronix SVDA failure |
Not all of us have 40 or more years of VW or otherwise antique automotive experience.
Us youngsters have some catching up to do.
I don’t ask for handouts.
I drank the Koolaid, lessons were learned.
It took 6yrs to build my first VW. I’ve been driving it for just over a year. I’m about to race it off road for the 2nd time. _________________ Bandit #19
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3446 Location: Hamble, Hampshire, UK
Posted: Sun Nov 09, 2025 2:11 am Post subject: Re: Pertronix SVDA failure |
Pertronix got a good name for themselves by selling a simple bulletproof points replacement unit - the Ignitor 1. But just like points, if you left the car with the ignition on and the engine stopped, it could burn out the coil if the points were "closed".
So they created the Ignitor II - which detects that the engine is not running by measuring the time between ignition events and turns off if it is too long.
However, it seems that once the module has got hot at some time, it sometimes decides that cranking is too slow and turns off. And also can develop high speed faults giving misfires..
Then they created the Ignitor III that attempts to use the four lobes of the points cam with a sensor as timing references. The slopes of that cam are fairly gentle, and so it is difficult to get stable and accurate timing out of this kind of design. Leads to rough idling if the engine speed varies much between the lobes of the cam - which it does- and the effect builds up until it ends up with unstable idling.
For most people, if you have a good points and condenser setup, it will work.
And if you want vacuum advance go for a 123 distributor. If you want an electronic 009 replacement, then there are a few American suppliers who will provide you with an 009 replacement. _________________ Ancient vehicles and vessels
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 962 Location: Eastern north carolina
Posted: Sun Nov 09, 2025 5:42 am Post subject: Re: Pertronix SVDA failure |
| Sorry to hear of your electronic failure schepp. I have always used points and as said many times on this forum, I have gotten many miles out of them and never had a failure even though I usually carried a spare dizzy on long trips. Good quality points and condenser are getting hard to find which makes more people inclined to go with a module. I think Glenn mentioned that standard motor products currently makes a good quality set of points which I will look into. Bosch used to make the Tiger Stripe heavy duty points and if I see those NOS I will buy them. |
Glenn  Mr. 010
Posted: Sun Nov 09, 2025 6:17 am Post subject: Re: Pertronix SVDA failure |
| Bobs67vwagen wrote: |
Yes, SMP points and condensers are the best out there... unless you find NOS Bosch. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
oprn Samba Member
Posted: Sun Nov 09, 2025 6:35 am Post subject: Re: Pertronix SVDA failure |
| mikedjames wrote: |
And if you want vacuum advance go for a 123 distributor. If you want an electronic 009 replacement, then there are a few American suppliers who will provide you with an 009 replacement. |
Thanks for this explanation! That explains why all my modern cars have been/are what I call "slow starters". They seem to want higher starter speed and a longer time before they catch and run. Not at all like the old points equipped cars that could be "bump started" by pushing them then hopping in and pop the clutch.
The quickest starting vehicle I own is a 1946 IH tractor with a factory compression ration of 6/1 and is so worn out that is uses a 2 quarts of oil every 4 hours and needs #2 spark plug cleaned daily. That sucker will start on the first compression every time if primed right. I know this because the starter has never worked, I used the hand crank for the whole 10 years I hayed with it!
That one has a magneto of course. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Zed999 Samba Member
Posted: Sun Nov 09, 2025 6:40 am Post subject: Re: Pertronix SVDA failure |
| In general defence of electronic ignition modules, they don't have to be bad, my Ignitor 1 c/w "flame thrower" (lol at the name) coil have been in constant service since I got them 25 years ago and it starts on the button every time. |
vamram  Samba Member
Posted: Sun Nov 09, 2025 7:01 am Post subject: Re: Pertronix SVDA failure |
Schepp, I've had the same experience years ago - 2012-13? - w/multiple Pertronix-branded ignition parts failing: the SVDA vacuum can lasted a year, and the centrifugal advance by itself was awful, impossible to tune as just an "009." Flame Thrower coil died after 6 months. On a different car, the Pertronix ignition module failed in a short time.
I've had much better luck w/the Compu-Fire and its Accu-Fire knock-off, running them for years in both of my cars. I do keep a spare timed distributor w/me at all times and even a set of points and condenser just for the heck of it. But the Compu-fires have been pretty bullet-proof.
Cylinder coils are a whole other story. Most are pure crap. _________________ "Men are qualified for civil liberty in exact proportion to their disposition
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!! |
Glenn  Mr. 010
Posted: Sun Nov 09, 2025 7:52 am Post subject: Re: Pertronix SVDA failure |
| Zed999 wrote: |
The older ones seem to be more reliable, it's the newer ones then have a higher failure rate. _________________ Glenn
Member #1009
#BlueSquare
Glenn  Mr. 010
Posted: Sun Nov 09, 2025 7:55 am Post subject: Re: Pertronix SVDA failure |
| oprn wrote: |
| Thanks for this explanation! That explains why all my modern cars have been/are what I call "slow starters". They seem to want higher starter speed and a longer time before they catch and run. |
Odd, because new cars have an "auto stop" feature for when you're at a full stop the engine turns off. When you step on the gas it starts in less than a single rotation. The computer knows which cylinder was next to fire.
I had a 2025 Subaru Outback (Service Loaner) and it started in less than 1 second. Personally if I owned the car I would by an aftermarket products that permanently turns it off. _________________ Glenn
Member #1009
#BlueSquare
oprn Samba Member
Posted: Sun Nov 09, 2025 8:28 am Post subject: Re: Pertronix SVDA failure |
Can't confirm or deny the auto stop stuff. I don't own anything that new. The wife's 2000 Forester was one of the slowest starters in our stable when we had it. _________________ Our cars get old, we get old but driving an old VW never gets old! |
BFB Samba Member
Posted: Sun Nov 09, 2025 8:56 am Post subject: Re: Pertronix SVDA failure |
yeh Glenn is right, new cars start "at the push of a button" figuratively and literally. hell, we've had some new diesel trucks in the shop that were push button start and there's virtually no delay in starting, no waiting for glow plugs for 10- 20 seconds like we used to.
im not even going to get strarted on the auto shut off / start thing but yeh ,the vehicles that do that fire up instantly.
far as the electronic pickups for our shit, ive had a few go out, of course the first was from leaving the key on out of ignorance then a few others went out just because they do that. but I think the best ones ive had were the cheapie knock offs and the best of those I think was the style that had the disk that went on top vs the cylinder that went over the lobes. and its easy enough to carry a spare set and just drop into the dizzy, no need to carry a whole other dizzy and jacking with point gap. not saying I dont like points, i do, i like that points tend to give you a little warning ahead of time. I'll run points on any engine I can if the owner is capable of working on them, considering most of my engines go in rails and go off-road it'd be better to limp home on burnt points than be doa out in the trails somewhere.
ive never run the pertronix 2 or 3 though as they seemed too over complicated and also not really compatible with the BB, so I avoided them. _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
DesertSasquatchXploration Samba Member
Posted: Sun Nov 09, 2025 11:05 am Post subject: Re: Pertronix SVDA failure |
I believe its the heat that kills them.
I spent 250 on one in my early days failed too. Total POS never again they wanted 83 for a new pickup screw that. I love my points never let me down. Get an old dwell meter your good to go. _________________ Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out) |
Rob Combs Samba Member
Joined: December 30, 2020 Posts: 876 Location: South Bay LA, California
Posted: Sun Nov 09, 2025 11:10 am Post subject: Re: Pertronix SVDA failure |
| modok wrote: |
so the solution is
This is the philosophy I follow.
Got a spare Ignitor 1 in the glove box, weather pack terminals crimped on and ready for a plug (this way they fit through the hole in the distributor) with a nice Snap On terminal tool in the kit. 3-way weather pack has the power, signal, and oil pressure switch to keep it tidy and easy to remove/install clean and quick. Also easy to unplug if I need the key on engine off for more than a few seconds. |
ZEKE65 Samba Member
Joined: December 16, 2018 Posts: 357 Location: Right Coast, Florida
Posted: Sun Nov 09, 2025 1:38 pm Post subject: Re: Pertronix SVDA failure |
I run an Igniter II, and keep an identical distributor in the car with an Igniter II in it, with the clamp on and pre timed. So its just changing out the distributor. No problems yet with the first one in 3400 miles. _________________ 1965 VW Sedan, 1968 C10 Step BB, 99 C5 |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7577 Location: Houston, Texas
Posted: Sun Nov 09, 2025 4:21 pm Post subject: Re: Pertronix SVDA failure |
I had two different distributors with electronic points in them. One went out while I was driving down the road. The other went out while I was in a store. I walked home each time. I've never had manual points leave me stranded. Usually you can limp home when you feel the condenser going out. _________________ www.vwnos.com [email protected]
