Remove fan from generator
Ct92404
Ct92404 is offline
PostPosted: Tue Nov 11, 2025 6:23 pm    Post subject: Remove fan from generator Reply with quote
Hi all,
After a LONG time, I'm finally getting back on to the project of restoring/repairing a 1972 Super Beetle I bought a while back. The engine is out of the car, and I actually have a rebuilt engine that hopefully soon will be ready to be installed. I'm just working on some of the external parts. Right now I'm trying to remove the fan off the generator because I want to see what condition the original generator is and if it's worth reusing or getting rebuilt. The generator and fan are already out of the fan shroud. But the problem is that I'm having a really hard time trying to get the nut/bolt off the fan. I'm using the right size 36mm socket, but the nut is EXTREMELY tight. I can't get it off.
Is the nut a reverse thread and I'm trying to turn it the wrong way, or is it just THAT tight??
- Chris
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Nov 11, 2025 6:30 pm    Post subject: Re: Remove fan from generator Reply with quote
Impact gun.
If you don't have one, bring it and the socket to a shop and ask them to remove it.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
busdaddy
busdaddy is offline
PostPosted: Tue Nov 11, 2025 6:34 pm    Post subject: Re: Remove fan from generator Reply with quote
X2, and it is RH thread.
Слава Україні!
Cusser
Cusser is offline
PostPosted: Tue Nov 11, 2025 6:38 pm    Post subject: Re: Remove fan from generator Reply with quote
You should be able to use a screwdriver in the generator pulley wedged against one of the generator screw heads to prevent from turning. The big 36mm nut "should" not be tight like a gland nut or rear drum nut, and it is right-hand thread, as others have posted.
busdaddy
busdaddy is offline
PostPosted: Tue Nov 11, 2025 7:20 pm    Post subject: Re: Remove fan from generator Reply with quote
Well......... if the generator is out of the shroud the fan makes a much better place to hold on, don't stick anything through the blades, a ratchet strap around the rim makes a great strap wrench to stand on the end of while you grunt and groan working on the nut.
Слава Україні!
Ct92404
Ct92404 is offline
PostPosted: Tue Nov 11, 2025 7:27 pm    Post subject: Re: Remove fan from generator Reply with quote
Thank you for the replies, everyone.
After I posted, I was able to find more info and yeah the bolt IS reverse threaded so I was trying to turn it the wrong way. But when I tried to turn it clockwise, I STILL can't get it to loosen! Arnold Schwarzenegger must have put that thing on. I'm going to have to take it to a shop.
Unfortunately though, I made a dumb mistake. I had already taken off the generator pulley earlier, and instead I was trying to hold the generator from turning by putting a wrench on the square end of the shaft. I stupidly didn't think the fan bolt would be on THAT tight and I thought I wouldn't be putting too much force on it. Well, in all the struggling, the wrench slipped a few times and kind of chewed up the square. I hope I didn't mess it up too much and a pulley will still go on right. Otherwise I just wasted all this time and will have to get a new generator anyway. It's not the first time I've made dumb little mistakes trying to work on this car. I've never tried restoring an old car before. I haven't actually broken anything yet (until now?), but I get in over my head sometimes!
I just don't understand why the bolt is on so tight. Normally in repair manuals they expected you to loosen the bolt by reaching around the fan shroud with a wrench! Someone must have put it on WAY too tight at some point, or over time it just worked itself on tighter? It's crazy. Not even the pulley was on that tight. Even the crankshaft pulley was a piece of cake compared to this.
Mr. 010
Glenn is offline
PostPosted: Tue Nov 11, 2025 7:44 pm    Post subject: Re: Remove fan from generator Reply with quote
Lefty loosey.
It's not reverse thread.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
bsairhead
bsairhead is offline
PostPosted: Tue Nov 11, 2025 8:37 pm    Post subject: Re: Remove fan from generator Reply with quote
Take your stuff to a qualified mechanic. No, really.
PostPosted: Tue Nov 11, 2025 9:15 pm    Post subject: Re: Remove fan from generator Reply with quote
Glenn wrote:
Lefty loosey.
Correct.
If it's the vehicle, this can work, put a big wrench on the generator pulley center:
If it's out of the car, I put the generator face down with that piece in my vice to hold it while I turn the fan nut.
Ct92404
Ct92404 is offline
PostPosted: Tue Nov 11, 2025 9:22 pm    Post subject: Re: Remove fan from generator Reply with quote
Glenn wrote:
Lefty loosey.
Well, I've tried both ways now and couldn't loosen it. Sad
It's insanely tight. I never in a million years thought a bolt for the fan would be THAT tight.
I don't have an impact gun. I'm going to take it to a mechanic. I should have done that from the beginning, but I just didn't think the fan would be SO hard to get off, and I figured just a big ratchet and socket would be enough. Nope...
Ct92404
Ct92404 is offline
PostPosted: Tue Nov 11, 2025 9:37 pm    Post subject: Re: Remove fan from generator Reply with quote
EverettB, it's off the car, and already out of the fan shroud. (Thankfully, in this model Beetle, the fan can fit through the hole in the shroud and the generator and fan can come off the shroud as one unit.
But I tried to use a wrench to hold the generator shaft like in your picture, and the square end got a little chewed up because the wrench slipped while I was struggling with the stupid bolt on the fan. I hope I didn't fatally mess up the generator. Crying or Very sad
My dad knows a mechanic and I'm going to take the generator/fan to him to take it off. I probably should have done that from the beginning, but I thought this was going to be simple enough to do myself, I never figured the bolt just for the fan would be THAT hard to take off. Someone must have put it on WAY too tight at some point.
Cusser
Cusser is offline
PostPosted: Wed Nov 12, 2025 8:37 am    Post subject: Re: Remove fan from generator Reply with quote
Glenn wrote:
Lefty loosey.
As stated, it's NOT reverse thread !!!
Some Goober or Gomer way overtightened and/or used string thread sealer on this in the past. We call this "a gift from a previous owner" !!!!
Rob Combs
Rob Combs is offline
PostPosted: Wed Nov 12, 2025 12:00 pm    Post subject: Re: Remove fan from generator Reply with quote
I had to go to harbor freight and buy an electric impact to remove mine the first time.
Car was in pieces and I needed it running that day.
I guess if 36 lb ft is good, 360 is better right?
Some people just feel the need to impact everything together, way beyond where it was designed to be torqued.
slayer61
slayer61 is offline
PostPosted: Wed Nov 12, 2025 12:28 pm    Post subject: Re: Remove fan from generator Reply with quote
My wife, for example, has absolutely zero mechanical empathy. She has twisted off more small hardware than anyone i know Sad "every bolt should be as tight as i can make it, right?"
Cusser wrote:
... Most folks are idiots when it deals with electrical !!!
67rustavenger wrote:
3/4 race cam? What's missing, one of the lobes? Shocked
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
Tim's stage II turbo heads
MSD Box and distributor
Car Craft turbo header
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
PostPosted: Wed Nov 12, 2025 3:51 pm    Post subject: Re: Remove fan from generator Reply with quote
Yes, just listing a couple different ways for anyone reading - no big deal.
Yes, sometimes they are insanely tight.
Or maybe frozen from rust/age/whatever?
Yeah, I guess it's mechanic time with the impact wrench.
This reminds me that I have a generator here that I cannot get the inner pulley off. It's rusted in place. I pulled on it with a 2 arm puller off and on for months in between dousing it with Kroil and it hasn't moved at all. I need to buy a torch!
Ct92404
Ct92404 is offline
PostPosted: Thu Nov 20, 2025 2:53 pm    Post subject: Re: Remove fan from generator Reply with quote
Sorry for the long delay in posting an update. If anyone still sees this ...
The mechanic got the fan off the generator, and apparently it was super easy with an impact drive. I wasn't there, but my dad said it just took like 2 seconds to get the bolt off.
Great. Here I was struggling and going crazy and he got it off like it was nothing...well I figured it would be easier for someone who has the right tools and actually knows what they're doing (unlike me). Rolling Eyes
Unfortunately though, with all the manhandling on the generator with a ratchet and wrench, I mangled the square end on the shaft. I had bought a new generator earlier, but I got it on eBay and it's a cheapy one. It's supposed to be the correct one, a 12 volt generator 1972 Super Beetle, but probably not the best quality. So I was having second thoughts and wanted to try to get the original generator rebuilt if it was worth it. I think I may have ruined that possibility now. Crying or Very sad
I'll post a picture of the generator, but I don't know if that is something that can be fixed
Mr. 010
Glenn is offline
PostPosted: Thu Nov 20, 2025 3:08 pm    Post subject: Re: Remove fan from generator Reply with quote
Told you so Wink
Uh... the shaft is round. The pulley has a square boss that locks the 2 halves together. The pulley is replaceable.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
MTT3107
MTT3107 is offline
PostPosted: Thu Nov 20, 2025 4:12 pm    Post subject: Re: Remove fan from generator Reply with quote
Just remember:
First comes loose
then snug
then tight
then very tight
and after that, it's loose again......
slayer61
slayer61 is offline
PostPosted: Thu Nov 20, 2025 7:22 pm    Post subject: Re: Remove fan from generator Reply with quote
Just remember:
First comes loose
then snug
then tight
then very tight
Thumbs Up
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
