Raising Front - Adjustable Beam
RCJH77
RCJH77 is offline
PostPosted: Sun Nov 16, 2025 3:55 pm    Post subject: Raising Front - Adjustable Beam Reply with quote
I've looked through all of the "how to raise the front" posts and I'm not finding the specific details I'm looking for. All I've seen is: "Jack up the car, loosen the adjuster nuts, adjust accordingly." I get that.
What I'm wanting to know is exactly how to do it without the dramatic (and slightly terrifying) torsion leaves tension release. Anyone have a method for accomplishing this?
I guess another way to ask the question is: At what point are the torsion leaves under the least amount of tension?
Jeff Geisen
Samba Chaplain
Jeff Geisen is offline
PostPosted: Sun Nov 16, 2025 5:33 pm    Post subject: Re: Raising Front - Adjustable Beam Reply with quote
just as wheel lifts off ground/floor
I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab
pondoras box
pondoras box is offline
PostPosted: Sun Nov 16, 2025 6:45 pm    Post subject: Re: Raising Front - Adjustable Beam Reply with quote
Put the front on ramps. Jack under the beam with just a tickle of tension to hold the weight of the car. Loosen adjusters raise the front with the jack retighten the adjusters and season to taste. Put the car back on the ground and sit in a chair drink your beer and admire your new stance.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop (Arschloch)
1973 standard bug (Dirty Gertie)
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion
Schnitzelfuss
Schnitzelfuss is offline
PostPosted: Mon Nov 17, 2025 3:21 am    Post subject: Re: Raising Front - Adjustable Beam Reply with quote
This should help https://www.youtube.com/watch?time_continue=5&...MiwyMzg1MQ
RCJH77
RCJH77 is offline
PostPosted: Wed Nov 19, 2025 6:57 pm    Post subject: Re: Raising Front - Adjustable Beam Reply with quote
Okay, so I was able to loosen up the adjusters and tested the tension by lowering the front to the lowest point. When attempting to raise it, it seems to stop at the halfway point, even with the wheels completely off the ground.
Do I need to disconnect the shocks to get the adjusters to move beyond the middle point?
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Wed Nov 19, 2025 7:13 pm    Post subject: Re: Raising Front - Adjustable Beam Reply with quote
I guess you have Avis adjusters, those gear teeth style …. They suck.
You need to remove the shocks.
Depending on how much you want to raise the front, due to the limits of the ball joints, you may also need to separate the spindles from the trailing arms. I suggest the upper ones since they have a larger hole for the camber adjuster.
RCJH77
RCJH77 is offline
PostPosted: Sat Nov 22, 2025 6:14 am    Post subject: Re: Raising Front - Adjustable Beam Reply with quote
After disconnecting the shocks, I had to give the hubs a good whack to get them to drop the rest of the way, but it worked. Thanks for the input, everyone.
