spiritkid Samba Member
Joined: October 07, 2024 Posts: 19 Location: Los Angeles, California
Posted: Wed Nov 26, 2025 1:40 pm Post subject: Sapphire I - Audio Troubleshooting Help Needed |
Hi Volks Folks!
I recently acquired a Sapphire I by Bendix radio for my 1960 Type 1 Beetle and am hoping someone can help me troubleshoot it. I've searched the forums and haven't found an adequate solution to my problem.
Here is a video I made to help demonstrate:
My car has been converted to 12v, and since this radio is 6v, I am using an EMPI 12v to 6v Inline Voltage Drop Resistor.
For testing purposes, I’m using a fully charged, 12V test battery.
I’m also using a brand-new, correct speaker from Wolfsburg West and have my car’s antenna hooked up.
The problem:
Radio powers on, but no audio comes through. There is, however, a ~120bpm (or 60 cycle) beating/blinking happening both visually (with the light) and audibly (through the speaker).
When I turn the volume pot, it produces a scratching noise through the speaker, in addition to a very low-volume hiss unaffected by the pot. I’m not getting any radio static (or stations) with or without the antenna connected.
I also have the lamp connected to the same side of the voltage drop resistor as the radio’s positive terminal. I realize this would typically be connected to the dash lights, but in my case, what would I do if everything else in the car is 12v?
As you can see in the video, when it’s all connected this way, the light and pulsing are always happening. When I disconnect the lamp from power, the pulsing only occurs when switching power on, but it also makes the light blink! Shouldn’t the light not work if the lamp wire isn’t connected?
My multimeter shows that I am getting ~8.25v coming out of the voltage drop resistor. Does this seem right? Shouldn't it be 6v?
I have very basic soldering and electronic knowledge and am doing my best to read the schematic. Hopefully someone here can point me in the right direction of which component(s) might be the issue, or if I'm just doing something obviously wrong!
Thanks! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26312 Location: Olympia Wash Rinse & Repeat
Posted: Wed Nov 26, 2025 2:47 pm Post subject: Re: Sapphire I - Audio Troubleshooting Help Needed |
| spiritkid wrote: |
My car has been converted to 12v, and since this radio is 6v, I am using an EMPI 12v to 6v Inline Voltage Drop Resistor. |
First off would not use a resistor like that. Those as they heat up let more and more voltage thru to burn up the delicate electronics in the radio. Should be no more than 7.2 volts for a 6 volt system. _________________ In Stereo, Where Available! |
Posted: Wed Nov 26, 2025 2:56 pm Post subject: Re: Sapphire I - Audio Troubleshooting Help Needed |
| spiritkid wrote: |
I also have the lamp connected to the same side of the voltage drop resistor as the radio’s positive terminal. I realize this would typically be connected to the dash lights, but in my case, what would I do if everything else in the car is 12v? |
Connect the bulb wire to the headlight switch and install a 12 volt bulb. _________________ In Stereo, Where Available! |
Posted: Wed Nov 26, 2025 3:04 pm Post subject: Re: Sapphire I - Audio Troubleshooting Help Needed |
| spiritkid wrote: |
| As you can see in the video, when it’s all connected this way, the light and pulsing are always happening. When I disconnect the lamp from power, the pulsing only occurs when switching power on, but it also makes the light blink! Shouldn’t the light not work if the lamp wire isn’t connected? |
Should not be pulsing. Need to check if somehow bulb circuit is connecting to the radio circuit, would suspect on off switch. _________________ In Stereo, Where Available! |
Posted: Wed Nov 26, 2025 5:36 pm Post subject: Re: Sapphire I - Audio Troubleshooting Help Needed |
| Eric&Barb wrote: |
| spiritkid wrote: |
First off would not use a resistor like that. Those as they heat up let more and more voltage thru to burn up the delicate electronics in the radio. Should be no more than 7.2 volts for a 6 volt system. |
Thanks for your answers!
I was under the impression that this resistor is precisely for this type of application, no? If not, what you you use? |
Posted: Wed Nov 26, 2025 5:38 pm Post subject: Re: Sapphire I - Audio Troubleshooting Help Needed |
| Eric&Barb wrote: |
| spiritkid wrote: |
Connect the bulb wire to the headlight switch and install a 12 volt bulb. |
A simple solution I overlooked, thanks! |
Posted: Wed Nov 26, 2025 5:39 pm Post subject: Re: Sapphire I - Audio Troubleshooting Help Needed |
| Eric&Barb wrote: |
| spiritkid wrote: |
Should not be pulsing. Need to check if somehow bulb circuit is connecting to the radio circuit, would suspect on off switch. |
Good call, I'll have to open it up again and get a good look when I have the chance. Could this be affecting the audio functioning properly? |
Posted: Wed Nov 26, 2025 6:18 pm Post subject: Re: Sapphire I - Audio Troubleshooting Help Needed |
| spiritkid wrote: |
Sure, according to the place that sells that item, but just try to get them to warranty your radio if it cooks it's electronics. There have been and are still many things sold out in the real world that supposed to make the VW engine go faster and have more HP, but kills the engine all too soon. Too many people out in the world will sell you anything to make a buck, and be happy to leave you with a piece of junk, and less $$ in your pocket.
Here an older thread talking about the problem. Plus a reducer that right now is not being sold, but you could always inquire with Wayne if he would make one for you.
https://www.thesamba.com/vw/forum/viewtopic.php?t=390598&highlight=radio+voltage+drop
You can also try several off the shelf 12 volt to 6 volt reducers off Ebay from China and see if one works well enough. Please do keep in mind that the 12 volt system will put out as much as 14 volts when fully charging the battery. So that 8.25 will likely be more 10.25 or even higher as that resistor gets even hotter with more power flowing thru it heating to ever higher temperature. If I were you would try out several of those (since they are very inexpensive) with a light bulb of same or a bit higher Amperage as the radio, and see if they stay stable. Would be very interested in what you find, if you would post them here. Do go for higher Wattage than you think you need, seem the Chinese tend to over rate the electronics and will burn out too soon. So if say you need 5 Amps, find those with rating of at least ten Amps.
Personally have collected enough vintage Bendix, Blaupunkt, and other radio brands of 12 volt to 6 volt radio voltage drop units over the years that we do not need to find a new one.
Just checked the Thesamba classifieds several ways and found none of the vintage units up for sale right now. You could put up a "WTB" advert in there and see if someone has a unit gathering dust on the shelf, that otherwise will be going into the trash.
Also do a search for "Radio" in the classifieds at least once a week. Sure it will be a lot to scroll thru, but if you do it often you will keep up and perhaps find someone that puts one up, but has not a clue what it is, so it will not be titled properly. If you do find something you are not sure about, post it on this thread and we or other old farts can tell you if you found what you are looking for. _________________ In Stereo, Where Available! |
Posted: Wed Nov 26, 2025 6:54 pm Post subject: Re: Sapphire I - Audio Troubleshooting Help Needed |
| spiritkid wrote: |
| Eric&Barb wrote: |
| spiritkid wrote: |
Sure any sparking will not help a radio work properly. Electric fences and lightening storms are why FM was invented.
Should also mention that EMPI sells some of the best VW garbage..... _________________ In Stereo, Where Available! |
zerotofifty Samba Member
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 3385 Location: Memphis
Posted: Wed Nov 26, 2025 9:39 pm Post subject: Re: Sapphire I - Audio Troubleshooting Help Needed |
It's really common for older electrolytic capacitors to leak out and stop capaciting.. usually losing just one or two will just give you a crappy sound or bad volume adjustments, but losing a handful, or all, will disable all the circuits they're in.
Its such a common repair that the radio guys just refer to it as "re-capping" a radio. Most or all electrolytic caps will be replaced leaving just the original vintage ceramic capacitors, which are non-electrolytic and don't contain any liquid. It's the liquid that leaks or evaporates rendering the capacitor non-functional. Radios have lots of them.
That is most likely what your radio needs. Since you aren't getting any sound at all, at bare minimum the amplifier circuit or tuning circuit is/are defective.
All vintage radios will have this problem, some worse than others. You would need to get a radio guy to recap and address any other issues if you want a functional original radio.
I did avionics for the last two years but I never got too far down into the component level to be of more help than that _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Thu Nov 27, 2025 1:40 am Post subject: Re: Sapphire I - Audio Troubleshooting Help Needed |
Thank you all so much for the thoughtful replies so far. A bit of good news... I connected 4 AA batteries in series to create 6V, wired it to the radio, and BAM, it works! See the video:
Now I am sure the voltage drop resistor is not functioning as I expected. I'll read the threads you linked and see if there is an elegant solution to get this radio working in my car!
[/youtube] |
Posted: Thu Nov 27, 2025 7:34 am Post subject: Re: Sapphire I - Audio Troubleshooting Help Needed |
resistor MUST equal to the resistance of the radio in order to cut the 12 volts in half to 6 volts the wattage of the resistor must be high enough to handle the draw that so that it dont over heat a burn out. basically you want half the current to through resistor and half through the radio, you need that half and half balance
also note that a resistor will increase in resistance as it heats up!
so you need the correct resistor. your getting over 8 volts to the radio, so you need a higher ohm resistor to get 6 volt. you want to cut the 12 volt voltage in half. you only cut it by about 1/3 extended use of the radio on high voltage may not be good for it
cause of the heat issue and need to select the correct ohms, these divider resistors are not ideal
in the linked diagrams, your radio is consider one of the two resistors as you run the radio in series with the resistor, that is why the radio and resistor must be same effective resistance, they must draw same watts to cut volt in half at the radio
if you use two resistors and take your radio voltage off a center tap and the two resistor are equal ohms and or high enough wattage, you will get half volts on the center tap BUT to not drain your battery when radios off, you also need to switch the resistors off, with a switch added
using one resistor as you are is the crudest method.
Voltage divider using two resistors, but you need to add the switch , which is not shown...
https://duckduckgo.com/?q=voltage+divider+resistor...iax=images
You need the switch at the input else the resistor will always be drawing load as the long as the battery power is connected. however using a single in series resistor, the switch in effect is the radio on off switch
There are solid state 12 to 6 volt converters for radios, I recommend using them, I have one, installed 45 years ago. these are much better _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
Posted: Thu Nov 27, 2025 11:44 am Post subject: Re: Sapphire I - Audio Troubleshooting Help Needed |
| zerotofifty wrote: |
There are solid state 12 to 6 volt converters for radios, I recommend using them, I have one, installed 45 years ago. these are much better |
Thank you for all that info. I am a novice when it comes to electronics, but I am learning!
Do we think that this device would suit my needs?
https://www.amazon.com/Converter-DROK-Regulator-Waterproof-Efficiency/dp/B00CGQRIFG/ |
Posted: Thu Nov 27, 2025 12:19 pm Post subject: Re: Sapphire I - Audio Troubleshooting Help Needed |
Should, but does it put out RF noise on AM band? _________________ In Stereo, Where Available! |
Posted: Thu Nov 27, 2025 12:42 pm Post subject: Re: Sapphire I - Audio Troubleshooting Help Needed |
| Eric&Barb wrote: |
Should, but does it put out RF noise on AM band? |
One review says he uses it on a regeneration radio without noise or interference. It's cheap enough that I might give it a try, as long as we don't think it'll cause any problems! Unfortunately, I'm going out of town for 10 days, so I'll have to wait until I get back to continue this quest! |
viiking Samba Member
Joined: May 10, 2013 Posts: 3466 Location: Sydney Australia
Posted: Thu Nov 27, 2025 1:51 pm Post subject: Re: Sapphire I - Audio Troubleshooting Help Needed |
I know this is very messy but why couldn’t you just have a small rechargeable 6V battery tucked away just for the radio? Unless it’s a show car you wouldn’t have to worry about the step down voltage changer.
The ones I see being sold are acid or Lithium based and you could calculate how long the battery would work for say with a 5AH battery.
Or am I stupid for suggesting this? _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Thu Nov 27, 2025 1:55 pm Post subject: Re: Sapphire I - Audio Troubleshooting Help Needed |
| viiking wrote: |
Or am I stupid for suggesting this? |
Not stupid, it is just another factor to fuss with. Say he wants to travel long distance and having to recharge the 6 volt battery every 5 hours.
If one does go with a radio battery, suggest only using a LiFePo4 battery. Far less weight than lead and little to no danger of fire as the Li-ion batteries have. _________________ In Stereo, Where Available! |
Posted: Fri Nov 28, 2025 11:41 am Post subject: Re: Sapphire I - Audio Troubleshooting Help Needed |
| viiking wrote: |
I have considered this, but do think it might be more trouble than it’s worth. I will likely try the converter next and see how that goes.
I’m also looking into having a simple, hidden Bluetooth amplifier to have in addition to the original Sapphire, as my car has already been retrofitted with some extra, more modern speakers. |
