Is this 019 distributor worth restoring?
jakerot
jakerot is offline
PostPosted: Sun Dec 07, 2025 10:33 pm    Post subject: Is this 019 distributor worth restoring? Reply with quote
Hello all,
got a box of vw parts at a garage sale. thought i scored an 019 distributor…..
noticed the bottom of the housing was loose. took the drive flange off and it was in fact broken right under the o ring.
thinking i could try cleaning up the mating surfaces real good and JB weld it back together? anyone ever try to fix this? worth fixing? thank you all for your help
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Dec 08, 2025 6:10 am    Post subject: Re: Is this 019 distributor worth restoring? Reply with quote
Sure glue the body back together.
Seriously... it's trash, the bushings are in each end and you'll never repair it. If you can find another body then you can use the best parts.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Alstrup
Alstrup is offline
PostPosted: Mon Dec 08, 2025 8:23 am    Post subject: Re: Is this 019 distributor worth restoring? Reply with quote
Carefully drill the badge off. Then you can install it on a 009 and make a copy 019 if you are after that advance curve
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
jakerot
jakerot is offline
PostPosted: Mon Dec 08, 2025 9:21 am    Post subject: Re: Is this 019 distributor worth restoring? Reply with quote
thank you for the quick replies and opinions gentlemen, much appreciated
Mr. 010
Glenn is offline
PostPosted: Mon Dec 08, 2025 9:31 am    Post subject: Re: Is this 019 distributor worth restoring? Reply with quote
Are you implying you can install the internals in a 009 body? The answer is no.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Alstrup
Alstrup is offline
PostPosted: Mon Dec 08, 2025 11:48 am    Post subject: Re: Is this 019 distributor worth restoring? Reply with quote
No, but it is relatively easy to copy the 019 curve into the 009
Mr. 010
Glenn is offline
PostPosted: Mon Dec 08, 2025 11:53 am    Post subject: Re: Is this 019 distributor worth restoring? Reply with quote
Have at it, but you'll still wind up with the poor quality of materials and machining that's in a $49 Chinese 009.
At least you get a cast iron body.
New cast iron 010 style distributor with 009 advance curve.
https://www.thesamba.com/vw/classifieds/detail.php?id=2566735
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Alstrup
Alstrup is offline
PostPosted: Mon Dec 08, 2025 3:30 pm    Post subject: Re: Is this 019 distributor worth restoring? Reply with quote
Kuhltek is just another word for Empi.
No, I would never use one of those later Chinese ones or whereever they are made. I I had to use a 009, whether std or modified I would source an old German or a little later Brazil. The Canadian (?) Accuvance were fair without being exceptional, but I think those are NLA too.
That said, I think the last 009 I used in an engine was probably in 2019 or so.
While there can be - and is sometimes an estetic side of things I am of the opinion that all those older dizzy´s have outlived themselves, 6V and very early stuff exempt for various reasons. Today there are several much better options on the market, and for very decent money.
Mr. 010
Glenn is offline
PostPosted: Mon Dec 08, 2025 4:27 pm    Post subject: Re: Is this 019 distributor worth restoring? Reply with quote
No, worse.
EMPI is getting better.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
heimlich Premium Member
VWNOS.com
heimlich is online now
PostPosted: Tue Dec 09, 2025 3:30 pm    Post subject: Re: Is this 019 distributor worth restoring? Reply with quote
You can't glue those together. I wouldn't even try to weld it as you need to have that bottom half aligned as it has a lower bushing in it.
The internals from that distributor are worth a little money.
If you can find a 019 with rusted internals you have a match for it.
earthquake
earthquake is offline
PostPosted: Tue Dec 09, 2025 9:37 pm    Post subject: Re: Is this 019 distributor worth restoring? Reply with quote
You could make a 1 piece bushing, that would align the 2 pieces of the housing.
eQ
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
tasb
The Distributor Distributor
tasb is offline
PostPosted: Wed Dec 10, 2025 5:03 am    Post subject: Re: Is this 019 distributor worth restoring? Reply with quote
I have an 019 housing you can have for the price of shipping. PM me.
Roads Scholar
Member# 2059
Mr. 010
Glenn is offline
PostPosted: Wed Dec 10, 2025 6:17 am    Post subject: Re: Is this 019 distributor worth restoring? Reply with quote
Problem solved.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
