Rod bearing desigation
Hayden74SB
Hayden74SB is offline
PostPosted: Thu Dec 11, 2025 8:39 pm    Post subject: Rod bearing desigation Reply with quote
I just pulled the rod bearings on a 74 SB I just got. They have the following markings on them.
0.25 U St 71-1950
What does this mean?
Rob Combs
Rob Combs is offline
PostPosted: Fri Dec 12, 2025 8:38 am    Post subject: Re: Rod bearing desigation Reply with quote
I’ll take a swing
The .25 U likely means.25mm or .010” undersize on the rods. The rest could mean anything such as a production code, lot number, etc.
In my view it really doesn’t matter.
You can and should verify by measuring the crank journals with a micrometer.
