SAWI Samba Member
Joined: September 08, 2018 Posts: 12 Location: United Kingdom
Posted: Sat Dec 20, 2025 2:59 pm Post subject: 1300 with Twin dellorto Drla 36s |
Hi Guys
Just brought a pair of Dellorto DRLA 36s to go on my 1300 dual port . Only reason for it being a 1300 is it’s a classic trials car and can’t go over 1300cc.
Does anyone have any idea on jetting sizes . It’s a standard 1300 with dual port heads and a Bus cam from gene berg .
Also will a standard fuel pump work or do I need to consider going electric.
Vaccum dizzy?
That’s in advance for any help
Sam |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11652 Location: Oregon
Posted: Sat Dec 20, 2025 3:21 pm Post subject: Re: 1300 with Twin dellorto Drla 36s |
I can't help with the jetting on an engine that small. Lol.
On the fuel pump, the standard pump should be ok as long as you verify the fuel pressure is below 3.5PSI. Otherwise, you'll need something like a Carter low pressure fuel pump to do the deed.
I currently have a Bosch 010 distributer in my twin port 1679cc 67 beetle. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7976 Location: Videbaek Denmark
Posted: Sat Dec 20, 2025 4:12 pm Post subject: Re: 1300 with Twin dellorto Drla 36s |
A bus cam... Thats probably an Engle/Berg W100.
I hope you raised the compression ratio somewhat, or it will be a bit of a dawg.
That said, you want the smallest venturi´s you can get for them, which is 27 mm.
Idle, probably 55
# 2 E tubes
180 air
115 main.
Since it is a track car the SVDA is probably "overkill" unless you do a lot of in between stuff (Regular driving) If you want to go SVDA a good starting point would be a 043 905 205 or 205L. Then adjust the curve to what your engine wants. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
txoval Samba Member
Joined: January 23, 2004 Posts: 3916 Location: The Woodlands, TX
Posted: Sat Dec 20, 2025 9:55 pm Post subject: Re: 1300 with Twin dellorto Drla 36s |
I had a pair on a 1200 Okrasa (dual port) 36hp engine.
Jets were very similar to what Alstrup posted, but I had Jaycee fabricate 25mm vents
SAWI Samba Member
Posted: Sun Dec 21, 2025 2:50 pm Post subject: Re: 1300 with Twin dellorto Drla 36s |
That’s for the advice guys , didnt build or commission the engine so just have to hope the guy who did knew what he was doing with regards to compression ratios
Will just have to wait for the carbs and see if we are anywhere close to those jet sizes or if not will have to get an order in |
TheRookie Samba Member
Joined: September 24, 2022 Posts: 141 Location: Western Cape
Posted: Fri Dec 26, 2025 10:48 pm Post subject: Re: 1300 with Twin dellorto Drla 36s |
Hi
Have Rick Hunt machine you a set of 25mm venturies
Id say 170 air
110 to 115 mains
48 idles |
