C pillar pads
meranda
meranda is offline
PostPosted: Mon Jan 05, 2026 8:36 pm    Post subject: C pillar pads Reply with quote
I am getting old and can't remember the orientation of these things when I took them out. Any Ideas?
Currently filling the garage
1961 beetle cabrio
1971 Superbug
1974 Porsche 911S Targa
1968 1500 Beetle A Project!
Past Garage fillers dozens of type1 &type3 VWs
Jaguar Mk5 & XK120
Lancia Flavia Coupe
Alfa Guilia sedan
KTPhil Premium Member
KTPhil is offline
PostPosted: Tue Jan 06, 2026 10:15 am    Post subject: Re: C pillar pads Reply with quote
This thread has a VW pic (the second one) showing how it is stuffed. It's apparently NOT "pointy end forward" as you might expect.
https://www.thesamba.com/vw/forum/viewtopic.php?p=5140098
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
redhot
redhot is offline
PostPosted: Wed Jan 07, 2026 10:54 am    Post subject: Re: C pillar pads Reply with quote
Not sure if these are equal to the later material, but if it is - maybe not re-install? At the same time you may not have the "vents" that allows humidity to be absorbed llike the same later...
A lot of the 70's cars rust from inside out in the C-pillar area due to the "death foam" that you can search and see a lot of pictures / text of in here on TheSamba.
viiking
viiking is offline
PostPosted: Wed Jan 07, 2026 5:04 pm    Post subject: Re: C pillar pads Reply with quote
I went back through ny archival photos and came across this one of the pad before I pulled them out.
