Cutting out at night on freeway
vw donvieira
vw donvieira is offline
PostPosted: Tue Jan 06, 2026 8:15 pm    Post subject: Cutting out at night on freeway Reply with quote
Dello All.
-I have a 1971 bus with a 2017cc motor
-Dual DRLA 40's with elec fuel pump at 2.5 psi
-Mallory unilite from ACN (mech/Vac advance) with circuit guard.
-Seems to run fine during the day
twice while merging onto the freeway at night (lights on and voltmeter at 12v) the engine started to sputter when I hit 3rd gear. Had to slow down and downshift but it seemed to resolve once I turned the headlight off (running lights still on).
Another note (getting forgetful in my old age) is that my brake lights are not working. I have Flasher/turn/driver side running light in the rear.
Not sure if a tired battery could cause this, is the Mallory malfunctioning.
Carbs were rebuild 6 months ago with high quality kit from the carburettor shop in Europe.
TIA
"No Give Up"
BFB
BFB is offline
PostPosted: Tue Jan 06, 2026 8:27 pm    Post subject: Re: Cutting out at night on freeway Reply with quote
did you do what alot of ppl do and wire your fuel pump off of the power wire to the coil?
if it seems directly related to you shutting off the headlights and not just coincidental, then start looking in the wiring and check you amps not just v.
Most experts aren't.
vw donvieira
PostPosted: Tue Jan 06, 2026 9:38 pm    Post subject: Re: Cutting out at night on freeway Reply with quote
Great point.
I will check since VW Jim in Lodi wired the fuel pump
"No Give Up"
Stripped66
Stripped66 is offline
PostPosted: Tue Jan 06, 2026 11:20 pm    Post subject: Re: Cutting out at night on freeway Reply with quote
vw donvieira wrote:
twice while merging onto the freeway at night (lights on and voltmeter at 12v)...
12V? That suggests your alternator/voltage regulator isn't functioning properly. Start with the basics. Check your grounding straps. Then, determine why the alternator isn't putting out ~13-14.5V (depending on the load). If it is putting out within that voltage range when the lights are off, then drops to 12V when the lights are on, then the alternator/regulator isn't keeping up.
66brm wrote:
Bodacious wrote:
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor.
I don't think electrickery works that way
vw donvieira
PostPosted: Wed Jan 07, 2026 5:04 am    Post subject: Re: Cutting out at night on freeway Reply with quote
Thanks Stirpped66
WIth headlights off I am at 14 volts
I do have HID headlights, probably time for LEDs
"No Give Up"
daveblank
daveblank is offline
PostPosted: Wed Jan 07, 2026 7:11 am    Post subject: Re: Cutting out at night on freeway Reply with quote
vw donvieira wrote:
the day
12v is most likely the issue. The Unilite tends to be voltage sensitive. Still generator or alternator? If alt, how many amp?
mikedjames
mikedjames is offline
PostPosted: Wed Jan 07, 2026 7:26 am    Post subject: Re: Cutting out at night on freeway Reply with quote
The Voltage Guard is described as a voltage regulator as well as a spike protector: when things are near the edge, maybe it is dropping the voltage to lower than 12 volts at the Unilite, causing it to shut off.
A standard ignition system should be working at 9 volts AFAIR.
But the underlying issue is that your charging system is weak. If it is using an alternator it could just be worn brushes.
Ancient vehicles and vessels
mikedjames
A standard points/condenser ignition system should be working at 9 volts AFAIR.
Stripped66
PostPosted: Wed Jan 07, 2026 8:42 am    Post subject: Re: Cutting out at night on freeway Reply with quote
vw donvieira wrote:
Thanks Stirpped66
Before you start throwing parts and money at band-aids (HIDs shouldn't pull more load than a set of halogens), measure the voltage at the alternator with the headlights off vs. on. Determine the voltage drop across the wiring of the main harness under low load (lights off) vs high load (lights on), and confirm that your low-voltage issue is related to the alternator/voltage regulator and not something more serious, like your harness' main hot lead corroding/deteriorating.
vw donvieira
PostPosted: Wed Jan 07, 2026 9:27 am    Post subject: Re: Cutting out at night on freeway Reply with quote
I appreciate all the input and will get back once I have tested the alternator and load test battery at Battery Bill.
Thank you
vwdon
"No Give Up"
vw donvieira
PostPosted: Wed Jan 07, 2026 7:26 pm    Post subject: Re: Cutting out at night on freeway Reply with quote
Went to Battery Bill this morning.
Battery checked out good.
Alternator checked out good with lights off (14v at idle)
Lights on at idle, the alternator registered bad and was down below 12v
I have something excessively draining the alternator's ability to charge with the lights on.
I am checking the brake switches tomorrow and then go from there.
"No Give Up"
Dale M.
Dale M. is offline
PostPosted: Wed Jan 07, 2026 7:29 pm    Post subject: Re: Cutting out at night on freeway Reply with quote
Weak alternator, needs replacement brushes or voltage regulator..... IF you have that serious of drain with lights on you would probably have a hand full of blown fuses.... Takes a real server load to pull a 55 amp alternator down to low voltage....
BFB
BFB is offline
PostPosted: Wed Jan 07, 2026 8:19 pm    Post subject: Re: Cutting out at night on freeway Reply with quote
55 amps isnt shit , its nothing for a more modern vehicle to have 120 , 150 and were so used to having so much electronics that we dont think about how much it adds to straining our older systems when we add more & more to them.
I actually had to do a bit a reading because i thought stripped66 was wrong because the set of HID’s i added to my rail are the reason it got a 95 amp alternator. They draw a lot. But turns out he’s right, HID should draw less while running than halogen. BUT i bet the difference is in the fact that i didnt go with a similar equivalent, i went with some mega out put HID’s.
vw donvieira
PostPosted: Thu Jan 08, 2026 12:24 am    Post subject: Re: Cutting out at night on freeway Reply with quote
[quote="Dale M."]
All fuses intact
Gonna take the alt off and get it checked.
"No Give Up"
94touring
94touring is offline
PostPosted: Thu Jan 08, 2026 5:10 am    Post subject: Re: Cutting out at night on freeway Reply with quote
Since I have a large power inverter in my bus to run various items occasionally, a trailer with all it's lights, and h20 injection pump, I upgraded to an 85amp. It came with a sheet with it's power curve output based on rpms as I recall. Anyways, whatever boost it gave me showed up on my volt gauge. Lights off no accessories went from 14-14.2 to 14.5 and all lit up and max power being drawn to 13.3-13.8, up from maybe 12.8 at it's lowest. I run led brake lights.
vw donvieira
PostPosted: Thu Jan 08, 2026 4:47 pm    Post subject: Re: Cutting out at night on freeway Reply with quote
Thank you.
I am going to a 75amp alternator.
I have a retired alternator/magneto/generator/starter rebuilder that is going to test the alternator for me before I install.
"No Give Up"
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Thu Jan 08, 2026 10:53 pm    Post subject: Re: Cutting out at night on freeway Reply with quote
Check your ground path from the alt body to the battery negative. A voltage drop check should do fine. If you get more then .25 vdc, you got a ground issue!
You need a solid ground for the alternator to tell how much juice to put out! Not saying it is good. Just saying a wire can read good with only one strand connected. A voltage drop test will let you know if you wiring and connection are good or bad.
I have seen a lot of good parts changed due to a bad wire terminal!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
vw donvieira
PostPosted: Thu Jan 08, 2026 11:05 pm    Post subject: Re: Cutting out at night on freeway Reply with quote
Thank you VW Jimbo
-I will check the ground from the alternator. I did not go directly to the battery. I had a spot on the deck lid area that I grouped a few grounds to, but should have a wire from there to the battery negative. I use a military grade fully tinned copper stranded wire 10 gauge for my critical grounds.
-I have had this configuration for over 15 years, so it is odd.
-I am checking the brake light switches tomorrow and then will check the grounds.
"No Give Up"
vw donvieira
PostPosted: Sat Jan 10, 2026 6:24 pm    Post subject: Re: Cutting out at night on freeway Reply with quote
This should be moved to 1968-1979 bus forum, but I do not know how.
-Took bus on freeway today, just under 14v., then I turned the lights on, while at 3300 rpm and volts went to about 12.2
I checked the brake light switches on the master cylinder and they had continuity when I pressed the brake pedal.
I got a power probe, so it is time to learn how to use it.
Thanks for all the help.
"No Give Up"
74 Thing
74 Thing is offline
PostPosted: Sat Jan 10, 2026 8:16 pm    Post subject: Re: Cutting out at night on freeway Reply with quote
You have a serious voltage drop.
Check your grounds first as advised above and clean them to bare metal.
Check the hook up at the starter as well since the battery/alt/and headlight and fuse box wires all connect there.
Then pull your headlight and start doing voltage drops at the ground wire then low beam then high beam.
You need to get a voltmeter and learn how to use it-I had to and solved my problems-some wires at the headlights were really and needed to get cut back and a new 3 wire pigtail put on. Re did the grounds throughout.
Your alt should be putting out approx 14v at 3k rpm checked at the battery.
Ashman is a great resource and very helpful on electrical problems.
