weinerwagen Samba Member
Joined: May 10, 2004 Posts: 1548 Location: Monterey, CA -Laguna Seca--Coats, Kansas
Posted: Tue Aug 10, 2004 8:43 am Post subject: Changing side window in a Vanagon |
Gotta change a window in one of my Vanagons. The stationary one behind the sliding door.
Any suggestions? Tricks? Shortcuts, (glass cuts?????)  _________________ Retired attorney--Tort King. |
TeamSpatula Samba In The Rain
Posted: Tue Aug 10, 2004 10:19 am Post subject: |
depends on whether or not you're going to try to reuse the old seal, or if you have a new seal. If you have a new seal, you can just cut out the old one with a box cutter, and install the window like any other piece of flat glass. If you're going to reuse the old seal, you have to be a lot more careful pushing it out from the inside. This will be tedious, but if the seal is suppe enough, it will work. _________________ <---Air Cooled Search & Rescue Team - STICKERS & T-shirts for sale!
1981 Diesel Rabbit
I NEED A CAMPER!!!! (1971 is ideal but will consider other years)
http://www.TeamSpatula.com |
Posted: Tue Aug 10, 2004 2:15 pm Post subject: |
Old seal is in good shape. Thanks to California's nasty winters! HAHAHA
I watched a shop put in a windshield once, may try their technique. Lots of silicon spray, and a rope. Need to put in actually several windows, hate to have them shatter in my hands  _________________ Retired attorney--Tort King. |
Posted: Wed Aug 11, 2004 5:16 am Post subject: |
weinerwagen wrote: |
I watched a shop put in a windshield once, may try their technique. Lots of silicon spray, and a rope. Need to put in actually several windows, hate to have them shatter in my hands  |
Cool. I usually use a good, strong string, that will be thin enough to fit into the groove in the seal where the metal goes eventually, and wrap it around 3 times. Usually the first time gets it, mostly the second time, but occasionally you need that third go round, and if you didn't wrap it, you have to do it all again.
If you have another person on the outside, pushing the window in *gently*, it'll help a lot.
good luck. I've got to replace the sliding side window on my westy when I can afford a replacement. _________________ <---Air Cooled Search & Rescue Team - STICKERS & T-shirts for sale!
1981 Diesel Rabbit
DanJReed Samba Member
Joined: July 30, 2004 Posts: 548 Location: Riverton NJ
