kendalwpg Samba Member
Posted: Thu Sep 16, 2004 9:32 pm Post subject: Barndoor Doors |
| I have a '53 with rotten driver and passenger doors.Will only doors up to '55 work? If so can later doors be retrofitted? Also am wondering what years cargo doors fit. |
BUCIOBATISTI Samba Member
Joined: April 17, 2002 Posts: 6969 Location: San Diego, California, USA
Posted: Thu Sep 16, 2004 10:08 pm Post subject: |
Later doors will fit both in the front and the cargo doors but are different of course and not correct. _________________ Please check us out on Instagram at @holygrailgarage
That's the best place to see the latest things we are up to as well as catch an occasional sneak peek of our latest car and parts listings! |
Posted: Thu Sep 16, 2004 10:39 pm Post subject: barndoor doors |
| Thanks for the imfo. Do you think it is feasible to rebuild my doors using parts of newer doors ? It's the bottoms that are gone on mine.Or am i better to find another set from a barndoor?I have several newer doors and the equipment to fabricate, cut, and weld them. |
Posted: Thu Sep 16, 2004 11:05 pm Post subject: |
You could easily cut and weld the front doors as the only difference I'm aware of is the "finger indent" below the handle. The Barndoor has a very small and thin indent. As for the cargo doors, they are a completely different beast and certainly wouldn't be easy to do. Good luck. _________________ Please check us out on Instagram at @holygrailgarage
EverettB  Administrator
Joined: April 11, 2000 Posts: 71946 Location: Phoenix 602
VWBobby Samba Member
Joined: April 21, 2004 Posts: 1537 Location: Central Oregon Coast
Posted: Fri Sep 17, 2004 7:25 am Post subject: |
| The other difference is the 'check rod' in the door. I think from '64-67 is the years of the check rod/door stop, so those doors would need to be modified slightly.. |
