Thingdude Samba Member
Joined: February 23, 2004 Posts: 8 Location: Jefferson City, MO
Posted: Wed Jun 02, 2004 9:46 pm Post subject: isocyanates in primer? |
| I have everything ready to start spraying primer onto my car but I am trying to figure out all the proper health precautions before I start (first time to paint a car). Right now I will just be spraying PPG epoxy primer and then the high build or sanding primer that I have yet to buy. The labels on the epoxy primer and hardner cans just reccomend a NIOSH approved respirator which is what I have already. I also have new pink and yellow cartridges ready to put on it. One post says they are good for 6-8 hours. If I keep it in a ziplock bag is that 6-8 hours of use or do I need new filters everyday that I paint? I just want to make sure that the respirator is adequate to keep me protected for both primers. Also, I will be painting outside and probably also use a fan to help blow away the mist. Is it just the base and clearcoats then that have isocyanates? One post said painting in an open garage would be ok with a respirator and I will be outside but I don't want to push my luck. Let me know what you all think. Also, where can I get the nitrile or butyl gloves? Thanks |
E-boyz67 Samba Member
Posted: Thu Jun 03, 2004 1:12 am Post subject: |
If you have a charcoal filter you'll be fine but make sure you got some eye protection as well. _________________ 2-67
1-67vert |
VintageVulture Samba Member
Joined: May 25, 2003 Posts: 791 Location: Pacific Northwest- USA
Posted: Sun Jun 06, 2004 12:28 pm Post subject: respiration |
Hey-
Epoxy primers don't really kill people as fast as urethanes... Either way, it's the charcoal filters that age in hours, so keep the respirator bagged up tight- I use a Folgers coffee can, but ony after I throw the crappy coffee away!
You ought to be fine in the driveway with what you have planned, the garage is also just as fine- it's all in the amount of exposure you give yourself. Walk out in between coats, and if you SMELL the paints and primers as you are working with them, you are taking in some amounts of their toxins... Have fun!
Ryan |
Tim rag'59 Samba Member
Posted: Sun Jun 06, 2004 1:18 pm Post subject: |
| to my kowledge ALL paints contain iso's some more than others. that's the chemical you can't see or smell, if I'm not mistaking and voc's are the ones you can. 3m's 7192 is usually a good cheap filter you can buy to get the job done it's only about 18 bucks and it lasts for 40 hours(total spray time) with your filter set up you should be fine just don't leave it out and yes use it ALL the time,just some useless info for ya,Tim |
daslowguy710 Samba Member
Posted: Mon Sep 13, 2004 10:03 pm Post subject: resperators |
i know my posting is way after the fact but if it helps someone else then so be it
the disposible resporators (charcoal type)don't remove the isocynates from the air you are breathing in they will remove some of the volital organic compounds (voc's) that's why with urathane paints & primers you need to use a fresh air supply mask
also one thing to remember is you absorb more in through the pores in your skin and your finger nails |
Bklyn63 Samba Mafioso
Joined: August 24, 2002 Posts: 966 Location: "What am I, a mirage?"
Posted: Tue Sep 14, 2004 4:59 pm Post subject: |
| do youself a favor and dont take any chances with charcoal filters. get a hobby air respirator forced air system they are $150 and well worht the money. |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Wed Sep 15, 2004 6:24 am Post subject: |
| Bklyn63 wrote: |
Do you have a link? |
