Early/Late 40hp heads
DaveM
Mad Samba Scientist
DaveM is offline
PostPosted: Tue Nov 09, 2004 4:59 pm    Post subject: Early/Late 40hp heads Reply with quote
Hi all,
I'm in search of an early set of 40hp heads. I read from my original Speedwell sprint carb instructions that there are two different 40hp heads. Digging through my stuff, I find some 40hp heads that have the intake studs too far apart for the speedwell manifolds and I find one pair that have studs that match the dimensions.
So, I guess I'm trying to understand whether I do have these two different heads... or is one set actually a 36hp set.
TIA
Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices.
tuna
tuna is offline
PostPosted: Wed Nov 10, 2004 11:25 am    Post subject: Reply with quote
You'd know it if you had 36hp heads. They feature half circle stands where the rocker shaft lays, whereas the 40hp and later have a flat stand.
The 1300 and later heads had angled intake ports, so they're easily identifiable.
That leaves you with the two types of 40hp heads. Break out with the measuring calipers and figure out which is which.
DaveM
Mad Samba Scientist
DaveM is offline
PostPosted: Thu Nov 11, 2004 10:15 am    Post subject: Reply with quote
I don't think they are 36hp heads... but the only reference I have are some 36hp okrasa pieces which dont answer my question.
Now, the weird part is the number on them is 311 101 373 A which I've seen reference in places that these are 1500 parts but the intakes are definately flat on these heads.
Slow 1200
Slow 1200 is offline
PostPosted: Fri Nov 12, 2004 1:51 am    Post subject: Reply with quote
That doesn't sound like a 1200 part number at all, maybe it's an early 1500 head? (bus or type 3)
PostPosted: Fri Nov 12, 2004 9:55 am    Post subject: Reply with quote
311 = Type 3 and Type 3s never had anything less than a 1500 so...
DaveM
Mad Samba Scientist
DaveM is offline
PostPosted: Fri Nov 12, 2004 10:01 am    Post subject: Reply with quote
I know, I know... 311 is a type 3 part... but I'm 99.9% sure the surface of the intake is flat, not angled like the 1500 heads. this is why I'm stumped.
Can someone measure the distance between the two studs that secure the intake manifold to the head? the stud spacing on these heads are just over 2 inches apart.
kekonaiii
kekonaiii is offline
PostPosted: Tue Nov 16, 2004 5:56 am    Post subject: Reply with quote
311 doesn't always mean T3, lots of 311 parts are for 211 and 111 and 113 Wink
How are you doing Dave? How's the family??
