EvilMogan Samba Member
Posted: Fri Jan 07, 2005 8:19 pm Post subject: Newbie floor pan HELL!!! help please |
Hi everyone, Im a new VDub/forum guy. I pick up a 73 standard for $150 with almost no rust except the right pan is rotted. I triple checked the bolts, and I got them all. I cant get the pan to drop, it's hanging on the corners. Am I missing a spot wield somewhere? It's hanging between rear pan head lip and the heater channel. Any help would be appreciated, as this one thing has completely halted my rebuild.
Mogan |
Cobey Samba Member
Joined: March 31, 2004 Posts: 2022 Location: Lost in NorCal Space
Posted: Fri Jan 07, 2005 8:21 pm Post subject: |
Look for the recent post by Kalen1970. She has been doing the same thing. _________________ (0)(=|=)(0) 68 Ghia Vert - Gina
N.A.G
Home Solar Power |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Fri Jan 07, 2005 8:23 pm Post subject: |
Did you get the bolts located below the rear seats? |
Posted: Fri Jan 07, 2005 9:07 pm Post subject: |
the two that attatch the compartment tin to the raised part of the floor pan? yup got it, although that part isnt coming out very easy either. It's all gummed up. I've had to incorporate the BFH method, lol..
BTW, I am doing it as a body on replacement, I dont have the space to do the body off. |
USMCbug Samba Yoda
Joined: April 29, 2004 Posts: 2573 Location: Wichita, KS
Posted: Fri Jan 07, 2005 10:18 pm Post subject: |
The pans are the only thing I paid to have done on my 73. If memory serves, they are welded on some spots? _________________ 72 Super Beetle
73 Standard Beetle
79 Baywindow Bus
65 Split Window Bus
79 Baywindow Bus
71 Super Beetle (current)
"When war does come, my advice is to draw the sword and throw away the
scabbard."
- General Thomas "Stonewall" Jackson |
Cobey Samba Member
Posted: Fri Jan 07, 2005 10:29 pm Post subject: |
Okay, reading the instructions for a '65...
Remove all eighteen 8mm bolts (9 per side) that hold the body to the pan that run the length of the pan from underneath. With the rear tires removed, unbolt the tow (one per side) shock tower/body mount bolts. Underneath the rear seat you will find two 10mm bolts and four 8mm bolt that will need to be removed.
Hope that helps a bit! _________________ (0)(=|=)(0) 68 Ghia Vert - Gina
N.A.G
Home Solar Power |
