throttle cable through engine tin (single weber db)PROBLEM!!
vw72hippy
vw72hippy is offline
PostPosted: Sun Jan 16, 2005 6:56 am    Post subject: throttle cable through engine tin (single weber db)PROBLEM!! Reply with quote
1972 2000cc pancake what type of throttle cable tube holder could i use for holding the throttle tube in place once i moved it over to aline with the carb.
Westy Racer
Westy Racer is offline
PostPosted: Sun Jan 16, 2005 10:12 am    Post subject: Reply with quote
Drill a hole and hand thread a Flare Adapter in the tin. I've done this lots of times. It works great. They're available in lots of size combos.
Get em at any plumbing supply or auto parts store. Wink
Looks like this...
If it don't werk, mess with it!
If it breaks, it needed replacing anyway...
74 Westy Custom werk in progress!!
Bus #10 - VW #27 I'm a freak... so are U!
