RobzKombi Samba Member
Posted: Wed Nov 09, 2005 11:25 am Post subject: Empi GTV/Nardi steering wheel |
I want to install an Empi GTV steering wheel or a Nardi steering wheel on my Kombi and I need to know if there is an adapter out there or if I even need one? Who else is using either one of these steering wheels? any issues with using one of these steering wheels? any pics? is the diameter of the wheel larger or smaller than the OG?
Thank you. |
Posted: Wed Nov 09, 2005 5:24 pm Post subject: |
Anybody? |
EmpiGT Samba Member
Posted: Wed Nov 09, 2005 6:00 pm Post subject: |
If you get an after market wheel you will have to have an adapter made. The Nardi is a small diameter wheel, I don't think I would like driving with that small of a wheel. If you can find an empi gt wheel made for datsuns, you can take it to a machine shop and have them machine it to fit. Datsun empi's are flat dish and just a tad larger in diameter than a regular bug empi gt. They aren't very easy to find though  |
EmpiGT Samba Member
Posted: Wed Nov 09, 2005 6:11 pm Post subject: |
Here's a pic of one that Coolrydes posted in the gallery. It is a Datsun empi machined to fit
Posted: Wed Nov 09, 2005 8:22 pm Post subject: |
EmpiGT wrote: |
I knew I had seen a pic of a GT wheel on a bus, thanks for the info and the pic EmpiGT |
lonslo Samba Member
Joined: December 17, 2003 Posts: 1110 Location: Osideornoside
Posted: Wed Nov 09, 2005 9:17 pm Post subject: |
I had a small wheel on my bus and it was a pain to turn. 'especialy with 195x 50. |
coolrydes Samba Member
Posted: Thu Nov 10, 2005 12:15 am Post subject: |
dubluv
You can find thease wheels but it takes a bit of looking.... I will tell you this the machining is easy though.... Let me know if you find one and I'll do up the hub for you......
Coolrydes |
Posted: Thu Nov 10, 2005 7:06 am Post subject: |
I just recently started looking into one of these wheels and your bus is the reason why. I think it compliments the style of the bus. I soon as get a hold of one I will definitely get a hold of you coolrydes and get it installed. Just to make sure, Im looking for a GTV wheel for a Datsun? What is the diameter of a stock bus steering wheel? Thanks again guys. |
Posted: Thu Nov 10, 2005 7:59 am Post subject: |
no problem dubluv... thank you for the compliment... It is off a Datsun, I'll check the diameter.... When you get one all I need is the hub and I'll maching it up..... |
c.davis419 Samba Member
Posted: Thu Nov 10, 2005 10:35 pm Post subject: |
Hey Dennis,
what did you end up doing with that wheel I gave you? _________________ 1967 beetle
1974 Thing |
Posted: Fri Nov 11, 2005 7:57 am Post subject: |
coolrydes what is the max dish I can use? or should it be flat? I have found a couple of wheels and just want to make sure before buying. thanks. |
Posted: Fri Nov 11, 2005 8:32 am Post subject: |
the flatter the better. the more dish the higher the rim.... The hole in the hub just needs to start out smaller in diameter then the shaft on your bus |
Posted: Fri Nov 11, 2005 8:41 am Post subject: |
My bus is in the shop so I cant take a measurement, do you happend to have that measurement? Thanks |
lonslo Samba Member
Posted: Fri Nov 11, 2005 6:57 pm Post subject: |
c.davis419 wrote: |
Hey Dennis,
what did you end up doing with that wheel I gave you? |
It's a nice wall hanger. |
massvwnut Samba Member
Posted: Sat Nov 12, 2005 1:24 pm Post subject: |
I had a nardi wheel in my bus, it's for sale in the classifieds. Did not mind driving it, just liked the look of a stock wheel. email me if interested.. |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4121 Location: Margaritaville.....24/7
Posted: Tue Nov 15, 2005 12:04 am Post subject: |
Of course if you can't wait to have the wheel you want, just fab it up!
_________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
El Guero Samba Member
Joined: January 03, 2004 Posts: 1199 Location: I.E. Y-QUE
Posted: Wed Apr 21, 2021 2:22 am Post subject: Re: Empi GTV/Nardi steering wheel |
On the hunt for a Empi Datsun wheel. Anyone? _________________ Praise the Lowered... |
ach60  Samba Member
Joined: May 14, 2001 Posts: 4137 Location: Santa Maria
Posted: Sun Apr 25, 2021 2:11 am Post subject: Re: Empi GTV/Nardi steering wheel |
try this:
https://jhpusa.com/products/nardi-personal-steerin...&_ss=r
The Nardi-Personal steering wheel adapters use a unique design that incorporates a collapsible steel center section for added safety as well as a the correct PCD pattern for both Nardi and Personal steering wheels. This is covered by a plastic bellows to give it a professional finished appearance.
Features
Brand new in factory box with all hardware
Made in Italy from the finest high grade aircraft quality aluminum
Includes tapered Allen bolts w/tool and horn button retainer ring
This hub replaces your factory steering wheel allowing you to install any 6-hole aftermarket steering wheel with a 2.875" PCD bolt pattern in your vehicle
Fits Nardi, Personal, and most other 6 pcd hole steering wheels with a 2.875" bolt pattern
Vehicle Applications: Volkswagen vehicles from 1960-1973: 1960-73 1/2 Type 1 & 3, Ghia, Bug, 1959-67 Type 2.
Install Note: Reuse blinker device from original vehicle steering wheel assembly to complete installation.
NOTE: MOMO, Sparco, Mugen, Spoon, and NRG steering wheels are NOT COMPATIBLE with this hub. However, a Nardi/Personal hub ring adapter can be purchases separately in order to adapt these steering wheel brands to this hub. _________________ Good Luck
Al |
ezcamper Samba Member
Joined: January 10, 2001 Posts: 915 Location: Atlantic Beach, FL
Posted: Sun Apr 25, 2021 12:03 pm Post subject: Re: Empi GTV/Nardi steering wheel |
The guy that runs flat4 said they were going to remake the Datsun wheel... but that was over 2 years ago when we spoke. _________________ I make HWE style roof racks, Jim-Dandy racks, SO-33 metal parts, Dormobile racks, HWE style ladders, engine crank start handles, Westy rack tags, Binz tags, Sundial badges, State of California tags, steering lock electrical covers and single / double cab gate latch friction blocks.
instagram is http://instagram.com/bullidriversteelworks |
panel Samba Member
Joined: December 02, 2001 Posts: 1188 Location: Victoria B.C. Canada
