r39o Samba Polizei
Posted: Sat Sep 03, 2011 11:40 pm Post subject: Subaru conversion temperature gauge reading |
Where does your temp gauge now read with a Subaru engine in it?
I have a new stock VW sending unit in the coolant manifold right next to the stock Subaru sender.
I have the following cooling system:
http://www.thesamba.com/vw/forum/viewtopic.php?t=445880&highlight=subaru+gauge
I have a new radiator, water pump, aluminum coolant lines, etc...all new.
How about you????
NOTE: The search was not strong with me and I found no reference to this sort of question other than my blinky light is wacky, or my gauge is broke, but no where does your gauge read in a converted van. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
thummmper Samba Member
Joined: November 25, 2009 Posts: 2015 Location: Meadow Valley, California Republic
Posted: Sat Sep 03, 2011 11:51 pm Post subject: |
90 2.2 in 90 gl
needle hangs on the bottom edge of the red led
it only goes up when I cruise through campgrounds |
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Sun Sep 04, 2011 5:03 am Post subject: |
Mine also stays at the bottom edge of the LED, but temps go up and down quicker with in town driving then the wbx did, I would say my temps are the same during normal operating temps (post rebuilting my wbx) I have the same radiator that came with it....temps are even on the rad, so ill wait till it explodes. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17113 Location: Brookeville, MD
Mofus Samba Member
Joined: February 21, 2008 Posts: 369 Location: San Diego
Posted: Sun Sep 04, 2011 12:21 pm Post subject: |
Hi Walt,
Glad you're up and running. Mine almost always hangs out just below the LED. Heavy stop and go traffic will make it creep up to the middle, or high side of the LED. My temp gauge normally reads about 170.
The only time I have seen significant fluctuation was a couple weeks ago when I went camping up at White Mountain/Bristle Cone Pine trees. There is a 4000 feet climb from Bishop, and for the first time since I did the conversion the temp climbed to over 200 degrees. The radiator fan didn't seem like it wanted to kick in, but once it "remembered" it had a job to do it worked normally. It's also the first time I had ever heard the high speed fan kick in. I was getting pretty nervous, but the blinky light never came on. _________________ '87 Syncro passenger w/ 2.2L Subaru
'10 Passat Wagon (keeps Mrs. Mofus away from my van) |
edgood1 Samba Member
Joined: September 30, 2004 Posts: 2104 Location: Plymouth, MA
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7150 Location: Honolulu,Hawaii and France
ranchero Samba Member
Joined: October 11, 2006 Posts: 360 Location: Salida, CO
Posted: Sun Sep 04, 2011 2:48 pm Post subject: |
2001 EJ25. New rad, stainless lines, etc. Consistent 175 on the scangage unless going up a long grade at speed - then 180-190. _________________ '90 Westy Syncro EJ25 (money pit #1)
'96 FZJ80 (cheap by comparison^^)
'13 Golf R. Daily driver. |
GrindGarage Samba Member
Joined: October 14, 2008 Posts: 710 Location: Ocean City, NJ
Posted: Sun Sep 04, 2011 5:27 pm Post subject: |
I'm right below the LED as well.
Been wondering the same.
Gotta get out the scanner and see what the ECU sees temp wise.
If I let it idle for over .5 hour the needle will go into the LED and the fan will kick in. _________________ -cliff
91 Vanagon AUTO
97 Single Port EJ22 all smallcar.com |
Escorial Syncro  Samba Member
Joined: May 02, 2004 Posts: 449 Location: Manitou Springs, CO
Posted: Sun Sep 04, 2011 7:28 pm Post subject: |
1983.5 full camper with 1992 EJ22 with non-reversed old school cooling design. I have a bypass "t" into the cooling hoses, and a bleeder on the main return hose so it should be self bleeding. Original radiator. Brand new water pump and thermostat. I tapped the original VW sender into the cooling manifold. Gauge needle rides right on the leading edge of LED in normal driving conditions, IR thermo says 185 degrees on block. Fan cycles when needle gets just over the right hand side of LED. First test drive today, love it, runs like bat out of hell. _________________ Joel Lane
1985 Vanagon converted to syncro, ALH TDI w/GTB2056 turbo, Reimo clone top with Westy interior
2002 Toyota Tundra 4x4 |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Mon Sep 05, 2011 5:36 am Post subject: |
GrindGarage wrote: |
If I let it idle for over .5 hour the needle will go into the LED and the fan will kick in. |
Are you running a genuine Subaru thermostat?
It shouldn;t take that long for the fan to come on. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
molson88 Samba Member
Joined: April 28, 2004 Posts: 143 Location: Gabriola Island, BC
Posted: Mon Sep 05, 2011 8:13 am Post subject: |
88 Westalia with 1990 Subaru 2.2L...
After the conversion, the temp gauge needle was always right near the bottom of the LED.
After removing the rear heater core and the tees in the heater lines, the needle now always sits just above the LED. _________________ Cliff
99 Eurovan Camper (current)
88 Vanagon GL Camper with Subaru EJ22 (gone)
83 Vanagon Camper (best forgotten...)
2012 Audi Q5 3.2L |
r39o Samba Polizei
Posted: Sun Sep 11, 2011 9:41 pm Post subject: |
My needle hovers around the bottom and top of the LED.
I have yet to figure out what it means because even if I coast down hill a long time it never changes from where it lands.
The other day with a full load of kids and heavy traffic it got above the LED. BUT, BUT, BUT, driving again for a long time on the freeway, it just stayed there. When I restarted after an hour stop, it again hovered around the LED. It was hotter outside then.
I just don't get it..... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
timbo Samba Member
Joined: April 20, 2006 Posts: 194 Location: Port Moody BC Canada
Posted: Sun Sep 11, 2011 10:09 pm Post subject: |
my needle sits just at the top of the LED and travels up about a needle's width when doing a good steep climb. Just had the van loaded up for 2 weeks full of gear for 6 and all the mountain passes it went up but never enough to turn on the fan,,,,except in 1 or 2 traffic waits. I wired a 28 ohm resistor in line when converted, before that the needle sat quite high. Genuine Subie temp sender. 4 1/2 years since converting, and occasional checking wiht the IR laser gun on the coolant manifold outlet and the stainless coolant piping always gives a reading in the 180-195 range.
IMO ?? Get an IR gun, check your temp after a good highway run, that way you can guage what temp yer at in comparison to where the needle sits.
Needle really high but reads 185 ? Maybe wire a resister in-line to drop it to the(comfort zone)LED or below.
Cheers!!
bi-olar timbo _________________ 1988 Vanagon GL/ 1991 2.2 Subie power
"Never tell a lie and you'll never have to play dumb" Anthony Kiedis |
Rhinoculips Samba Member
Joined: August 08, 2005 Posts: 918 Location: Keystone, Colorado
Posted: Mon Sep 12, 2011 9:11 am Post subject: |
In my '89 Westy with '91 EJ22, the needle is half on, half off the top side of the LED. Can go up as much as half way between LED and top of gauge during long uphill climbs. Normal temps hover between 192* and 196*, during long 15+ mile climbs over mountain passes it can get near 198*-200* Temps will drop when using the heater. All temps measured with B10 scan tool. Radiator is new and rear heater core removed. _________________ “May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image |
Farfrumwork Samba Member
Joined: October 10, 2008 Posts: 692 Location: Mile High
Posted: Mon Sep 12, 2011 10:41 am Post subject: |
same as most here. just under the LED most all the time. creeps up in heavy traffic or crawly down slow roads (G or 1st gear), but come back quick with rad fan (manually turned on with AC switch)
EJ22/reversed manifold/newish radiator/no rear heater(capped lines)
WAY LESS movement than with the 1.9l _________________ sold -> '85 Wolfsburg Syncro / 'Built' DOHC EJ25 (a great machine!)
'07 Legacy spec.B, road tuned stgII
'17 4x4 Sprinter, stone grey, SMB pop-top, on 33"s
"Blood stains, speed kills - Fast cars, cheap thrills - Rich girls, fine wine - I've lost my sense, I've lost control, I've lost my mind" |
r39o Samba Polizei
Posted: Tue Sep 13, 2011 2:51 pm Post subject: |
Farfrumwork wrote: |
WAY LESS movement than with the 1.9l |
I have noticed that too.
Today after a long crawl in traffic surrounding my kids school I heard the fan come on. I looked and the needle was pointing a tad higher than the LED. Then the fan went off after less than a minute. The needle pointing to the top the LED.
Later today while cruising at high warp factors on the freeway the needle was pointing to the bottom of the LED.
That's it.
The needle hovers just plus or minus the top and bottom of the LED.
That's all folks..... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
Posted: Tue Sep 13, 2011 4:14 pm Post subject: |
What engine? Years?
Most engine including the VW Boxer should run when fully hot at around 187-190F on highway.
Anything below or above is not right. 175 is way to low and 195 to hot.
About 192-194 in moving traffic or/andslow road.
In heavy traffic or on idle on a warm day the fan should kick in at 200-203 MAX, the engine should then go down as low as 187F. The thermo coupler low speed (????) is design to kick in at about 200F
The infrared gun will give you a slightly lower reading over the heads.
If you are OBD you can check that out with any scanner and it's more precise than most infrared temp gun.
As for the front VW cluster gage... who knows! I never rely on them, NEVER.
Ben _________________ Working with rust, grease, dirt and dust is a sad truth.
FI part for sale: http://www.benplace.com/parts_sale1.htm
My site: http://www.benplace.com/vw2.htm
Subi conversion: http://www.benplace.com/vanaru_eng.htm
Youtube http://www.youtube.com/user/ftp2leta |
Posted: Mon Oct 10, 2011 1:54 pm Post subject: |
ftp2leta wrote: |
What engine? Years?
Ben |
Ben, what temps do you think is normal for long 10+ mile steep uphill/downhill climbs over 12,000 foot mountain passes? My temps seem to be between 192 and 203 going 55mph uphill and 176 to 181 going downhill. Idling at 700rpm the temps are between 187 and 194(when the low speed fan kicks in) and drops back to 187. My highway temps seem to fall into your recommended range of 187 to 190.
FYI- '91 EJ22 in an '89 westy with just installed stainless steel yesterday and Tom Shiels concept 4 coolant layout. _________________ “May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image
Volksaholic Samba Member
Joined: December 26, 2005 Posts: 1771 Location: Salt Lake City, Utah, USA
Posted: Mon Oct 10, 2011 2:05 pm Post subject: |
My VW gauge usually runs just below or at the LED and the ScanGauge reads from about 180° to 190°. That's about the same Summer and Winter. When driving relatively slow up the canyons on a hot summer day the ScanGauge will read above 200°, sometimes as high as 215° and the VW gauge is anywhere from above the LED to halfway between the LED and top of the gauge.
Paul _________________ 1988 Wolfsburg Edition, 2001 Subaru EJ251 |
