ChiTwnVW Samba Member
Joined: November 18, 2004 Posts: 1174 Location: Home. Sweat home.
Posted: Thu Jun 15, 2006 12:16 pm Post subject: Case Sealant |
Hopefully a simple question.
Do I put the case sealant everywhere the two case halves meet or just on the outside perimeter?
Also, how close do I get to the bearings?
If it matters, it's a type4 1700.
Thanks. Todd. |
drrnsk8ter4 Samba Member
Joined: December 14, 2004 Posts: 340 Location: simi valley, ca
Posted: Thu Jun 15, 2006 1:15 pm Post subject: |
where else would u put it other than the perimeter? the sealant is to stop oil from getting out of the engine case...no reason to put it on the inner parts of the case halves that touch...just the perimeter _________________ (O\U|U/O)--->74 std bug... |
Posted: Thu Jun 15, 2006 2:00 pm Post subject: |
I don't know, you might not want the oil seeping from one are to another, I mean the metal partions are there for a reason. Does the metal w/o the sealant mate close enough for this purpose.
Maybe around the case through bolt holes might stop oil from seeping out.
Neither the Wilson book, or the Bug Me video really give much detail.
Do I need to worry about keeping the sealant off of the bearings? |
Posted: Thu Jun 15, 2006 3:14 pm Post subject: |
keeping sealant off of the bearings is extremely important...when i did mine, i followed around the perimeter of the case thinking about whether or not when the case halves touched if there was a place for oil to seap...the only places i can think where the case halves touch other than the edges are where the bearings are but there's no need to seal there as long as u have the o-rings around the main bearing studs... _________________ (O\U|U/O)--->74 std bug... |
buggnuttz Samba Member
Joined: January 28, 2006 Posts: 404 Location: southern cheeseland
Posted: Thu Jun 15, 2006 4:12 pm Post subject: |
If you think about it the sealant does have some thickness to it so a CAREFUL application at the main bearing webs will help stabalize everything _________________ owned 39 different VWs so far |
Bottomend Grease
Joined: September 20, 2003 Posts: 1500 Location: Smell Aye! via Nude Hamster!
Posted: Thu Jun 15, 2006 4:47 pm Post subject: |
I was taught to only use enough so you can still see a bit of the metal underneath. No gaps or clear spaces, but a nice even coating that doesn't "pool up". |
EZGZ Samba Member
Joined: October 10, 2005 Posts: 923 Location: Loveland, Colorado
Posted: Thu Jun 15, 2006 6:02 pm Post subject: |
And with all the care in the world you still end up with bits of it showing up on the first 20 minute break in oil change.
At least I do.
What are you guys using for sealer these days?
What is that locktight product they have for sealing? 211 or something? Buddy of mine used it and said it worked great...... _________________ 64 custom Ghia, 66 Bug, Sandrail, Barrien tub
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8586 Location: All Across The Country
Posted: Thu Jun 15, 2006 10:53 pm Post subject: |
Sealant should not be applied to any of the main bearing saddle or cam saddle areas. This would affect your bearing crush, which may seem fine when you are assembling an engine at 70*, but could allow them to loosen and fret at high engine temperatures.
Colin _________________ www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/ |
