anybody used a "soft clutch"
gerico
gerico is offline
PostPosted: Sat Mar 28, 2009 8:31 pm    Post subject: anybody used a "soft clutch" Reply with quote
Have any of you guys used one of these? If so, what's the verdict?
http://www.thesamba.com/vw/classifieds/detail.php?id=748311
`70 street Ghia, 2276 NA
Thanks to:
Darren at DRD Racing
Jason at VW Paradise
Bill at Shear Speed
Kevin at KCR trans
Terry Cloyd
Banned
Terry Cloyd is offline
PostPosted: Sat Mar 28, 2009 8:43 pm    Post subject: Re: anybody used a "soft clutch" Reply with quote
What size pressure plate do you run?
Bruce
Bruce is offline
PostPosted: Sun Mar 29, 2009 12:32 am    Post subject: Reply with quote
OMG! What a mickey-mouse contraption!
Why not do this much simpler solution for less than half the money:
http://www.thesamba.com/vw/classifieds/detail.php?id=473781
joescoolcustoms
joescoolcustoms is offline
PostPosted: Sun Mar 29, 2009 1:02 am    Post subject: Reply with quote
WOW! Shocked
Get Bruces long arm and reduce it 40% then get the "Mickey Mouse" unit and reduce it another 50%. You could have a 70% reduced peddle pressure and run a KEP Stage 3 on the street as a DD.
Then the wife could drive it to the store.
Now if someone could come up with a device that would make dual 48 IDA's act like a single 34 PICT, I could have it all. Laughing
Bad News Racing 2018 NORRA 1000 3rd in Class
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
Mongo63
Mongo63 is offline
PostPosted: Sun Mar 29, 2009 1:13 am    Post subject: Reply with quote
Ricky Rat indeed! Long arm it and be done!
Southside Buggistas VW & kit car club
www.southsidebuggistas.com
Mongo only pawn in game of life...
mharney wrote:
Behold the true power of the extractor! Mongo has it right!
Terry Cloyd
Banned
PostPosted: Sun Mar 29, 2009 7:08 am    Post subject: Reply with quote
Bruce you do have a way with words. What about the pedal end?
http://www.autopartswarehouse.com/popup.php?type=m...&text=
flashburn2020
flashburn2020 is offline
PostPosted: Sun Mar 29, 2009 8:15 am    Post subject: Reply with quote
If someone changes over to a longer throwout arm, is clutch pedal travel affected? I guess pedal effort is easier (?) but takes longer pedal travel to activate clutch??
The Noof
The Noof is offline
PostPosted: Sun Mar 29, 2009 8:26 am    Post subject: Reply with quote
Yes...travel is traded for leverage.If everything else works as it should, it's seldom an issue.I have had to back the pedal cluster stop plate a little to gain a little more travel on my own car, and thats with a Stage III kep and turbo disc.
Bruce
Bruce is offline
PostPosted: Sun Mar 29, 2009 8:29 am    Post subject: Reply with quote
... but takes longer pedal travel to activate clutch??
That is correct. A buddy of mine was telling me one thing he hated about his car with a Stage 2 clutch was that the engagement was either on or off, he had no control in between, so street driving was not fun. When he put the long arm on, he had full control of how the clutch engaged. Plus a lighter pedal.
MAYHEM
MAYHEM is offline
PostPosted: Sun Mar 29, 2009 8:31 am    Post subject: Reply with quote
I think the long arm is a great solution to a heavy pedal.
Seems to me that a pulley, by simple engineering theory, would be very effective for this type of application as well.
And OldSpeed is not known for "junk".
I have no need for it, as I only run 1700#. I actually like the heavier clutch pedal feel. Now, at 2100# it may be a bit too much.
Greg
Model Citizen
johnnypan wrote:
I digitize myself in the privacy of my own home.
The Noof
The Noof is offline
PostPosted: Sun Mar 29, 2009 8:35 am    Post subject: Reply with quote
Long arm and a Stage III are still easy to manipulate.A good lady friend of mine has no trouble whatsoever with the clutch in my car.It's smoother and more progressive than a Stage I with a short arm.Thanks to Bruce...lol
Terry Cloyd
Banned
PostPosted: Sun Mar 29, 2009 8:59 am    Post subject: Reply with quote
The Kennedy stage lll is about 2600 lbs. Most people run a matched flywheel to crankshaft. The first thing that goes is your matched flywheel. It's better to see CNC clutch setup.
http://www.cncbrakes.com/sc.asp?grp=sc&subgrp=pull&series=300&subseries=standard
Alan_U
Alan_U is offline
PostPosted: Sun Mar 29, 2009 9:23 am    Post subject: Reply with quote
Bruce's OE long arm with a stage 1 with black magic disc (a perfect transmission grenade combo) was an insanely soft pedal like my all original 67.
Now with a stage 2 with my trusty copperhead the long arm is perfect.
The arm from Bruce is a no brainer.
11.92sec pump gas true daily driver. Who says it cant be done.
No more time for VW's.......
mynameistory
mynameistory is offline
PostPosted: Sun Mar 29, 2009 12:01 pm    Post subject: Reply with quote
Agreed... 1776 turbo with stage 1 and copperhead with bruce's long arm pedals as nicely as my stocker.
-tory
Daddybus
Daddybus is offline
PostPosted: Thu Apr 02, 2009 10:19 am    Post subject: Reply with quote
Installed the kit in my '67 bus (type 1 IRS). It took longer than 10 minutes. I suppose that if I had a lift and the clutch cable wingnut was already off the cable and the cable was new and clean and I only had to replace one nut (swing axle kit), then I could've installed it in ten minutes. Since my bus is converted to IRS, I needed to swap out the bowden tube bracket. It took a while to get the wing nut off the cable, then one of the bowden tube bracket studs backed out with the nut. After reinstalling the stud, the bracket went on without a hitch. The guys at Old Speed told me that I could've just drilled a hole in my old bracket and installed an 8mmx1.25 bolt. I bought the bracket so I could keep my old one as a spare. No need to disasseble the pulley, just slipped the cable through, then guided it back, around, then back through the other side of the pulley. Installed one nut on the end and then installed the wingnut. Took up the slack at the cable end and then installed the second jam nut. Adjusted the wingnut as stock.
The verdict...
you penny-pinching macho, he-man 2300# clutch dudes who are trading increased pedal travel for the benefits of using a longer lever arm...dust the cob webs off your wallets and spend the $$ on this kit.
Being a former science teacher, I examined the physics involved in the soft clutch kit. There are two basic ways of getting a mechanical advantage...use a longer lever arm (you cheap skates know that one already) or use a pulley system (the softy clutch kit). The pulley system in the soft clutch kit effectively spreads the load over two cables instead of one. For you knuckle-dragging doubters...let me ask you this...which is easier...lifting an engine with a longer pry bar or lifting an engine with a chain hoist (pulley system)?
If you install a soft clutch kit, you'll wonder what happened to your pedal pressure. My clutch is only an OG 1700# Kennedy. (Before you macho he-man 2300# haters pipe up...I have a dodgy left knee that acts up from time to time.) The soft-clutch kit makes my knee a non-issue. The clutch pedal is feather light with a decrease in the pedal travel needed to engage/disengage the clutch.
Good job Russell
joescoolcustoms
PostPosted: Thu Apr 02, 2009 10:31 am    Post subject: Reply with quote
I had intended to try this out on my Baja build, but you beat me to it. Having left knee problems also.
I would much rather go this route than remove another pivit arm from a throw out shaft on a installed tranny.
gerico
gerico is offline
PostPosted: Thu Apr 02, 2009 12:20 pm    Post subject: Reply with quote
Daddybus,
Thanks for the report. Being a charter member of the "Over the Hill Gang" and also having a funky knee, I appreciate the input.
Thanks to:
Bill at Shear Speed
Kevin at KCR trans
Bugorsh
Bugorsh is offline
PostPosted: Thu Apr 02, 2009 12:34 pm    Post subject: Reply with quote
The physics of the kit makes sense but the clutch cables were not designed to have that severe a bend in them. I'll bet you'll be changing it soon and often.
In pursuit of superior handling!
SuperBeetlesOnly.com
VeeDub Parts Unlimited
Topline Parts
joescoolcustoms
PostPosted: Thu Apr 02, 2009 12:42 pm    Post subject: Reply with quote
I would bet you would wear out a boden tube before wearing out a cable running across a smooth rotating pulley. My garage door cables are less than half that size and they have been in service for 12 years carring industrial rated doors and show no signs of needing replacing and they see more use than my VW does.
As you state, time will tell.
ACTION IS GO
ACTION IS GO is offline
PostPosted: Thu Apr 02, 2009 3:23 pm    Post subject: Reply with quote
I have the Old Speed Soft Clutch on both my cars and it is an easy install and works stellar. And travel is not traded for leverage.
Just another quality engineered part by Russell.
