zack1 Samba Member
Joined: March 03, 2004 Posts: 28 Location: Brentwood CA
Posted: Tue Jan 29, 2008 3:48 pm Post subject: Dropped lower cargo door plate when removing cargo door |
| I was in the process of removing the passenger side front cargo door, the one closet to the passenger side front door and when I removed the last screw on the lower hinge the plate just dropped!!! Has this happened to anyone before and if so how did you fix it. thanks in advance for any help |
campingbox  Samba Member
Joined: November 14, 2000 Posts: 10264 Location: Petaluma, CA
Posted: Tue Jan 29, 2008 4:16 pm Post subject: |
Bummer. There's no quick fix.
If you use the search function you'll find your answer. |
ratpanel61 Samba Member
Joined: November 04, 2003 Posts: 345 Location: Va Beach, VA
Posted: Tue Jan 29, 2008 6:15 pm Post subject: |
Happens all the time. You'll be cutting a window in to fish it out and rewelding up the hole. Have fun, no easy way. _________________ - '57 Sunroof Beetle (project)
- '73 THING |
Vintagespeed Samba Member
Joined: October 01, 2005 Posts: 579 Location: Westerlo (Belgium)
Posted: Sun Aug 09, 2009 3:49 pm Post subject: |
With a freshly painted bus, and you don't wan't to cut a window, not sure on this one, but isn't it "possible" to bolt it through, without the plate.
For instance drill a little hole in the next post you see trough the holes and bolt it with special measured bolts? Seems like it should be possible.  |
my65vert Samba Member
Joined: November 09, 2003 Posts: 6187 Location: Middleburg, Florida
Posted: Sun Aug 09, 2009 3:55 pm Post subject: |
bolt it to what????? The plate fell down, you wouldnt want to just bolt your heavy swinging cargo door to just sheet metal.
whats the diff between cutting a small window and drilling holes to fix it incorrectly?
Id cut the hole, fix it then weld it up and touch up paint. _________________ OGJHC
Kombisutra;
I'm starting to get little wafts of bus stink coming from the north. Something about the unique scent of drivers seat padding when it's glued together with mouse piss and shit that really gets me going... and I'm smelling it! Oh yeah! Time to start loading up the equipment. |
VintageVulture Samba Member
Joined: May 25, 2003 Posts: 792 Location: Pacific Northwest- USA
Posted: Sun Aug 09, 2009 4:01 pm Post subject: |
I restore Bus bodies frequently and this is a very common problem... I've found a few tricks to making this a quick repair- BUT, do you own a welder? Simply cut the lower portion of the rocker area where the plate is likely to have fallen and retrieve it. Then cut a small window on the outer skin just next to the area where the plate is fixed to the inside of the pillar. I usually am able to repair and reshape the flap that holds the plate in/ allows it to be adjustable. Then place the plate back in, tack weld the flap to hold the plate back in and reverse the cutting with your welder. Once I was able to make the immediate metal repairs in about thirty minutes. Make your cuts in areas that are easiest to grind, putty, repair, etc. Make sense? Again, do you have a welder? Once you complete this task you will feel like a pro! _________________ The best things in life aren't Things
(they're Buses) |
Posted: Sun Aug 09, 2009 4:12 pm Post subject: |
as it is the only way to fix this, it sure still is a nasty way
Someone should design something for that, some kind of adjustable spring type plate that fits trough the small holes or something and then expands  |
zozo Samba Member
Joined: October 15, 2005 Posts: 5216 Location: South of Ol' San Antonio
Posted: Sun Aug 09, 2009 5:21 pm Post subject: |
| Is anyone aware of a method for keeping it from falling in the first place? It seems like it would be easier to prevent, than fix. |
Nor_AL_67 Samba Member
Joined: December 18, 2007 Posts: 663 Location: Huntsville,Alabama
Posted: Sun Aug 09, 2009 5:36 pm Post subject: |
| zozo wrote: |
Yes, Cut the head off an 8x1.25 bolt and dremel a groove for a flat head screw driver. Remove 1 of the orig bolts and install the modified one; this will keep the plate from dropping yet allow the cargo door hinge to slide thru. Remove the orig bolt. The plate now will stay put. Repeat for other hinge plate. Remove the door. To install is reverse.
_________________ 63 Sedan
61 Rag
67 Type 1 Sedan
63 Type 2 Standard Walk-thru
69 Ghia
68 912
Amateur Versus Rusty Bus! |
zozo Samba Member
Posted: Sun Aug 09, 2009 5:59 pm Post subject: |
| Nor_AL_67 wrote: |
| zozo wrote: |
Necessity is the mother of invention. Nice job. |
Alaskan Adventurer Samba Member
Posted: Sun Aug 09, 2009 7:02 pm Post subject: |
| Nor_AL_67 wrote: |
| zozo wrote: |
YA This Cat is useing his brain, good idea _________________ 63 DC
60 SC daily driver |
Posted: Mon Aug 10, 2009 1:05 am Post subject: |
| my65vert wrote: |
| you wouldnt want to just bolt your heavy swinging cargo door to just sheet metal |
The plate itself doesn't look so strong itself. Wouldn't it be possible do bolt through just one hinge in the sheet metal with some big threated metal screws with a large head, similar as the og head? Nobody every did it that way?
I really hate to cut open the pillar and weld it back up  |
Mikee Samba A.D.D. Boy
Joined: March 22, 2004 Posts: 3514 Location: Puyallup WA
Posted: Mon Aug 10, 2009 8:57 am Post subject: |
| Vintagespeed wrote: |
| my65vert wrote: |
so you would rather put big nasty screws thru it?  _________________
| localboymark wrote: |
| One man's "patina" is another man's cancer. |
| bugnut68 wrote: |
| I would have kicked the guy right in the dick, balls, ass and face and destroyed his weed. Hippies suck. |
Rick Samba Member
Joined: December 17, 2003 Posts: 1539 Location: Soquel, California
Posted: Mon Aug 10, 2009 12:40 pm Post subject: |
| what about a magnet? I've used this in a similar situation where I needed a nut welded to the inside of some square tubing. I drilled a hole where the bolt would go through then tossed the nut in the tube from the open end (the tube was long, about 8 feet and we needed it near the middle). I then put a magnet on the outside of the tube, picked up the nut on the inside and slide the magnet over to the hole. Now with some finesse I was able to get a bolt in the nut to pull in into place and tacked it in. I'm not familiar with the inside of that pillar in your situation, but it might be worth attempting since it requires only a magnet and no damage to the car. Even if it took me 3 hours of fiddling with a magnet I'd rather do that than cut, weld, paint, etc. |
hugheseum Samba Member
Joined: February 11, 2004 Posts: 2690 Location: oregon
Posted: Mon Aug 10, 2009 12:56 pm Post subject: |
you need a endoscopic tool,surgeons use them,and in the last 356 registry mag theres a retired dr. with a endoscopic tool that retreived a socket from a freshly painted 356,it had fallen down the heater vent and into the longitudinals (rockers to bus guys) _________________ Have a great day! |
Dropped Metal Customs Samba Member
Posted: Mon Aug 10, 2009 2:10 pm Post subject: |
| hugheseum wrote: |
| you need a endoscopic tool,surgeons use them,and in the last 356 registry mag theres a retired dr. with a endoscopic tool that retreived a socket from a freshly painted 356,it had fallen down the heater vent and into the longitudinals (rockers to bus guys) |
yeah sergeons use these when they drop there tools inside you and they show up in an xray  _________________ BUSDROPPINGBEAMNARROWINGSTEERINGBOXRAISING"C"NOTCHINGRUSTREPAIRINGBEETLEDROPPING
@DroppedMetalCustoms |
kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1207 Location: Woodstock, NH
Posted: Mon Aug 24, 2009 6:31 pm Post subject: no hole needed |
I just spend a couple days, about two hours each time, but I was able to do it without cutting a hole.
It takes a lot of patience, other things to do when you start to get frustrated, and some 19 gauge steel wire-although I'm sure 18 or 20 would work, 19 is what they had at the local hardware store.
You need that and some good flashlights to be able to look down the hole. Flash light from underneath, and fish from above. pull out plate, then use wire to reinstall. |
Redlocker Samba Member
Joined: January 25, 2010 Posts: 107 Location: I'm in southwestern PA, USA
Posted: Tue Dec 04, 2012 10:11 pm Post subject: |
| Nor_AL_67 wrote: |
| zozo wrote: |
I'm so glad I found this BEFORE I removed my front cargo door. It sounds like it will save me alot of frustration.
Thanks! _________________ Search my other want ads. A wise man once said, "Do unto others, as you would have done unto you". We should all try that.
71 Super Beetle (stolen)
71 Squareback (rusted, junked)
71 Squareback (factory-dealer A/C, sold)
68 Bus, sold
68 Beetle (baja'd, sold)
78 "Golf" (total burn)
81 Scirocco S (sold, bought back, sold again)
81 Scirocco S (sold)
86 Scirocco (sold)
83 GTI (DSP auto-crossed, sold)
84 GTI (sold)
2000 New Beetle
'60 Microbus Std. / Mango (project in progress) |
Ragman The Sambinator
Posted: Wed Dec 05, 2012 11:29 am Post subject: |
| There is a coat hanger trick you can do as well, hooking and holding the plate in place while removing the cargo door. Ian and I just did it on a 23 window in his shop while remove these doors. Trick worked fine. Hard to describe on in a post, but basically the coat hanger holds via one removed bolt hole the plate in place...remove door. Place bolt back in, being careful not to knock it down the chute from hell. |
Posted: Wed Dec 05, 2012 2:46 pm Post subject: |
Thanks, that sounds even easier. _________________ Search my other want ads. A wise man once said, "Do unto others, as you would have done unto you". We should all try that.
68 Bus, sold
86 Scirocco (sold)
84 GTI (sold)
2000 New Beetle
