bluvw69 Samba Member
Joined: January 27, 2005 Posts: 333 Location: Chesapeake, Virginia
Posted: Sun Jan 29, 2006 11:21 am Post subject: Engine Trouble! Help! -Fixed, Thanks! |
This morning, on the way to work, I was cruising along at about 65 mph when all of a sudden my engine started to stutter. It felt like it would intermittently cut out for a couple of seconds, then start up again. So, I eased off the accelerator and that seemed to help but it still cut out on me, only not as frequently as if I was going faster. It did this all the way to work. What is going on with my car? Will I be able to/should I drive it home? I have been keeping up with oil changes and valve adjustments so I don't understand what could be wrong. Any help would be great. Thanks.
P.S. Everything under the hood is all stock. _________________ 1965 Beetle Sedan (OU|U/O)
Volkswagen Club of Tidewater
http://sites.google.com/site/vcot81/
61 BUS  Samba Member
Joined: January 05, 2005 Posts: 708 Location: Tucson, Arizona
Posted: Sun Jan 29, 2006 11:25 am Post subject: |
It sounds like you're not getting fuel. A common problem is that the old gas tanks get rust and crud in them, and then clog up the fuel filters. Try changing your fuel filter and see if that helps. If that does end up being the problem, you'll need to either clean and seal your tank, or get a new one. In the mean time, carry some extra fuel filters with you.
________________________________________________________________
61 Bus, 76 Standard Beetle, 81 Vanagon, 84 Porsche 928, 2000 Beetle |
Posted: Sun Jan 29, 2006 11:35 am Post subject: |
61 BUS wrote: |
It sounds like you're not getting fuel. A common problem is that the old gas tanks get rust and crud in them, and then clog up the fuel filters. Try changing your fuel filter and see if that helps. If that does end up being the problem, you'll need to either clean and seal your tank, or get a new one. In the mean time, carry some extra fuel filters with you. |
I just cleaned the gas tank last October. I can imagine the tank would get dirty again that quickly. _________________ 1965 Beetle Sedan (OU|U/O)
http://sites.google.com/site/vcot81/ |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79831 Location: Sneaking up behind you
Posted: Sun Jan 29, 2006 12:32 pm Post subject: |
Sounds like fuel or ignition. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
brice Samba Member
Posted: Sun Jan 29, 2006 1:05 pm Post subject: |
It's @ that time of year to make sure your heat risers are in check & icing isn't occuring -- (NOT A PROBLEM w/ Dual Carbs) -- check: http://www.vw-resource.com/heat_risers.html for a great article describing the scenario. |
Posted: Sun Jan 29, 2006 1:56 pm Post subject: |
brice wrote: |
The engine was warm when I started having troubles. So icing wouldn't be an issue. _________________ 1965 Beetle Sedan (OU|U/O)
John M. Samba Member
Joined: July 22, 2005 Posts: 3833 Location: Boulder, CO
Posted: Sun Jan 29, 2006 1:58 pm Post subject: |
How long has it been since you replaced the points and condensor? _________________
Current: 1972 Beetle - 96V EV
Previous:
1966 Beetle - Sea Blue - 1300SP
1966 Beetle - Sea Blue - 1600SP
1974 Beetle - African Red - 1914CC
Posted: Sun Jan 29, 2006 2:43 pm Post subject: |
John M. wrote: |
How long has it been since you replaced the points and condensor? |
In the 6 months that I've owned the car, I haven't done a thing with the points or condensor. I've never messed with them because I really have no idea how to work on them. Everything that has to do with the distributor is a big puzzle to me. I guess it's time I learned. _________________ 1965 Beetle Sedan (OU|U/O)
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Sun Jan 29, 2006 2:50 pm Post subject: |
Check the point gap. Adjust as required.
if that doesn't help
Replace the fuel filter. They're cheap.
and
If it's making a ticking sound, check the left front cylinder (#3) exhaust valve clearance. |
Posted: Sun Jan 29, 2006 2:55 pm Post subject: |
bluvw69 wrote: |
John M. wrote: |
In the 6 months that I've owned the car, I haven't done a thing with the points or condensor. I've never messed with them because I really have no idea how to work on them. Everything that has to do with the distributor is a big puzzle to me. I guess it's time I learned. |
Purchase Volume 1 from bugmevideo.com. Very easy to replace the points and condensor. And it's something you should learn to do anyways. _________________
Previous:
Randy in Maine Samba Member
Posted: Sun Jan 29, 2006 4:03 pm Post subject: |
John M. wrote: |
bluvw69 wrote: |
John M. wrote: |
Purchase Volume 1 from bugmevideo.com. Very easy to replace the points and condensor. And it's something you should learn to do anyways. |
What he said plus invest in a dwell tach. They are cheap money and will save you tons of dough. Example http://cgi.ebay.com/ebaymotors/Actron-CP-7676-Digi...dZViewItem |
Posted: Sun Jan 29, 2006 8:39 pm Post subject: |
Thanks everyone for your help! I cleaned out the fuel filter and cleaned the filter in the fuel pump, and now I'm trouble free. I will definately look into getting a tach/dwell meter and the Bugme video. _________________ 1965 Beetle Sedan (OU|U/O)
