Joined: May 17, 2003 Posts: 4875 Location: Harmony, PA
Posted: Wed Aug 17, 2011 7:33 pm Post subject: High % Ethanol gasoline eating float needles? |
| So after 12 years of trouble free service from my 40 IDF Webers, I developed a leaky float needle/seat that would allow one of the bowls to overflow. This was from the original all brass Weber Seat that came with the carbs new. For the rebuild, I found a deal on some genuine Weber 40 IDF rebuild kits. I was pleased to find that the new kits came with a float needle that had a Viton rubber tip that I felt would seal better. After two years of, again, trouble free service, I developed a miss on one side of the engine. After disassembling the carb to check for an oddball chunk of dirt, or something, I found that the rubber tip had come off of the needle. Is this just another casualty of the crappy gas with the 5% to 15% Ethanol that's been eating/dissolving almost every other rubber component it comes in contact with? Has anyone else had an issue with this? |
Bajaman65 Samba Member
Joined: January 16, 2007 Posts: 469 Location: Borrego Springs
Posted: Wed Aug 17, 2011 8:13 pm Post subject: |
This may date me but, way back in the days of 3 Wheelers I ran 100%
Methanol in my bored and stroked engine and found that anything that
was rubber or plastic would melt. I used nothing but Brass everything and that
little puppy would haul ass, oh back to the question. I still use
all Brass Needle and Seats in my Weber’s and Dell's with no problems
but I had a customer with some HPMX 44's with the rubber melted away
on the tips of the Needles, I replaced them with the all Brass set's and the
car has been running fine for several years. I would not take the chance
anymore with 'whatever' they may put in the Gas now days.
Also double check to make sure your float isn't getting heaver by slowly
soaking up fuel. |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7542 Location: Whittier,CA
Posted: Wed Aug 17, 2011 8:47 pm Post subject: |
Viton should not be harmed by gasoline, ethanol or methanol - provided they chose the right type of Viton to make the seal from. There are 4 families of Viton, type F is specific for automotive fuels, it's absolutely impervious. Now if they made the seals from the wrong type of Viton the life of the seal would be compromised. No reason to expect they would choose the wrong type but how would one go about verifying this? _________________
| Mitey62 wrote: |
| Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
| RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum.  |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Wed Aug 17, 2011 10:23 pm Post subject: |
You might be able to find ethanol free gasoline in your area. I started using pure gasoline once I found it in my area and it has increased my mileage by a substantial amount. My small SUV was getting right at 21 with the 10% mix at my local station - I switched to pure gas and I'm getting 23.5 mpg. I went back to a tank of the 10% a couple of weeks ago to see if the mileage would drop - it did - 20.91 - I filled it up today with the pure gas again. Not a bad jump in mileage for the same price. With my Ghia I was getting right at 28mpg with the 10% mix - when I switched it seemed to run better and I was getting almost 30. I'm hoping to get near that with my 2110 - we'll see. The motor is getting closer to completion.
Anyway you might find a station near you that has pure gas here:
http://pure-gas.org/ _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Wed Aug 17, 2011 10:52 pm Post subject: |
| DarthWeber wrote: |
| No reason to expect they would choose the wrong type but how would one go about verifying this? |
Yeah, but there's also not reason to expect they would choose the right type of Viton either.....
RC _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
ALB Samba Member
Joined: August 05, 2008 Posts: 3506 Location: beautiful suburban Wet Coast of Canada
Posted: Thu Aug 18, 2011 4:19 am Post subject: |
| OLD VW NUT wrote: |
http://pure-gas.org/ |
Theoretically we should see a slight running temperature difference in the aircooled motor with the 2 fuels- the 10% mix should run a little cooler. Did you happen to notice? Interested in running another tank through the Ghia for comparison?
Also, if setting a motor up ethanol blended fuel you should be able to cheat on the compression a little; alcohol fuels allow higher c.r.'s _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Posted: Thu Aug 18, 2011 5:47 am Post subject: |
| ALB wrote: |
| Also, if setting a motor up ethanol blended fuel you should be able to cheat on the compression a little; alcohol fuels allow higher c.r.'s |
Compression is based on Octane for any given engine combo. Alcohol fuel has the same octane because then they just use a lower octane fuel to mix with the alcohol to come out to the same octane as without and then on top of it all, you have less BTU's to play with and the same knock sensitivity. That's why 10% alcohol cars seem to need a small bump in the jetting since the alky is actually making the mix lean. It just sucks all the way around.
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Thu Aug 18, 2011 5:55 am Post subject: |
We have had exclusively 10% Ethanol fuel in the Chicago area for at least 10 years. I have never had a fuel related issue with any of my carburated cars, including Weber carbs. _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
ALB Samba Member
Posted: Thu Aug 18, 2011 6:03 am Post subject: |
RC wrote:
"Alcohol fuel has the same octane because then they just use a lower octane fuel to mix with the alcohol to come out to the same octane as.."
Thanks RC; that's the tidbit I was missing. In the past I've seen guys blend good gas with alcohol and then be able to run higher c.r's for more power. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Almost Alive Samba Member
Posted: Thu Aug 18, 2011 9:50 am Post subject: |
| lostinbaja wrote: |
| We have had exclusively 10% Ethanol fuel in the Chicago area for at least 10 years. I have never had a fuel related issue with any of my carburated cars, including Weber carbs. |
Jerry, The first set of 34's I had were eaten from gas and we probably buy at the same gas station. They were brand new, lucky me. |
Posted: Thu Aug 18, 2011 9:57 am Post subject: |
| ALB wrote: |
Ethanol/alcohol does allow higher compression but there is little to gain since it also comes with less power so its a trade-off at best.
As for the Ghia once I get the 2110 installed I'll be using straight gas for as long as it is available in my area. Since Washington State does not mandate ethanol mix in my area (yet) I won't be doing a comparison.
I looked at the fuel log I keep in my SUV this morning - on ethanol the past 3 tanks averaged 20.96mpg - on straight gas the last 2 tanks I got 22.84mpg. Thats 1.88 miles further per gallon on straight gas and almost 30 miles per tank. Not much difference but enough to keep me burning it since its the same price. And the motor seems to run just a bit smoother. On ethanol it would start up and immediately die on a warm/hot startup maybe 2 times in 10 - on straight gas it doesn't have that problem. _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
74 Thing Samba Member
Posted: Thu Aug 18, 2011 10:57 am Post subject: |
Thats a 9% gain in fuel mileage for the same price.
Ethanol blends are no good IMO, but unfortunately pure gas is not available everywhere-thanks politicians. |
Posted: Thu Aug 18, 2011 11:36 am Post subject: |
It's a well known fact that you need 2 x's the alcohol to make the same energy a gasoline.
I used to run Methanol in my go cart and I literally needed double the jet sizes. _________________ Jerry...
RIP Morgan
My photos
neil68 Samba Member
Joined: March 17, 2007 Posts: 3453 Location: Calgary, Canada
Posted: Thu Aug 18, 2011 5:41 pm Post subject: alcohol |
Similar to the Chicago poster, we've had 10% alcohol in our fuel in Canada for years...I'm going to say at least 15 years. I've run stock carbs, Kadrons, IDA's, never a problem with fuel lines, carb parts, etc. There must be other contributing issues...perhaps older fuel lines or low quality products.
Back in the day, we used to add various alcohols in the winter to promote better starts and less icing...usually a pint per tank. _________________ Neil.
Der Kleiner Rennwagens
‘68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 108 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Thu Aug 18, 2011 9:12 pm Post subject: |
| lostinbaja wrote: |
I used to run Methanol in my go cart and I literally needed double the jet sizes. |
You're talking about Methanol. Ethanol is not the same.
E85 is about 30% more fuel vs. gasoline. _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4671 Location: Oklahoma City, OK
Posted: Fri Aug 19, 2011 5:54 am Post subject: |
| Being stuck with the 10% blend in New Nexico, too many tree huggers here, I have not had any carb problems as to failure of internal parts, although you have to be picky as to what fuel line you use. The cloth wraped "VW" hose does not stand up very well, switched over to Gates fuel hose and have not had any more issues. The jetting did change, using one size larger main, but had to drop two sizes in Air Correction. Oh yea, lost 2mpg, which is 10%. |
Posted: Fri Aug 19, 2011 8:01 am Post subject: |
| Eaallred wrote: |
| lostinbaja wrote: |
E85 is about 30% more fuel vs. gasoline. |
I'm aware they are different. The affect on the jetting is about the same. _________________ Jerry...
RIP Morgan
My photos
earthquake Samba Member
Joined: January 10, 2008 Posts: 4006 Location: SANDY VALLEY, NEVADA
Posted: Fri Aug 19, 2011 10:02 am Post subject: |
Are "Grosse Jet" needle valves still available? I have heard they impervious to any fuel, I seem to remember that Jay-Cee used to sell them.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Fri Aug 19, 2011 2:32 pm Post subject: |
| earthquake wrote: |
Casey |
I tried to find some for a Weber a few years ago and had no luck. I used to run them in my Super 1650 off road car and never had a problem. The glass ball in the Grosse Jet doesn't care what is in the fuel. _________________ Jerry...
RIP Morgan
My photos
dan devin Samba Member
Joined: January 14, 2005 Posts: 114 Location: youngstown, ohio
Posted: Fri Aug 19, 2011 4:32 pm Post subject: |
| I should have a couple if you need one. |
