Jeremy Samba Member
Joined: August 01, 2002 Posts: 300 Location: gilbert, az- not anymore- now in co
Posted: Sat Jun 11, 2005 11:59 am Post subject: cb lifters - worth it? |
I'm getting ready to build a 2110 for my notch
Here's my setup / plans so far
Dell 45's with shorty manifolds matched to
p/p cb 044 heads
dual springs / chromoly retainers
cb or scat 1.25 rockers ( don't have yet)
aluminum push rods
forged scat crank w/ h beams
web 119
total seal seconds
full flowed
compression around 9.5:1
this motor will see around 7k rpm max
hopefully about 170 - 180 hp
This car will be driven HARD almost daily
Now I can't decide on lifters
scats - too many problems
reground stockers - NO
ceramics - My #1 choice but $$$$
CB - look good, I can afford them
I want this to be reliable and not have to be torn down after 4500 miles cause a lifter went and royally screwed up EVERYTHING.
Any suggestions are appreciated
BTW here's the link
http://www.cbperformance.com/catalog.asp?ProductID=68 |
danimal Banned
Posted: Sat Jun 11, 2005 1:30 pm Post subject: |
as always, you should get the lifters at the same place you get the cam... so cb lifters with a cb cam... i believe that they grind their own cams.
beyond that, i'm thinking that slr reground stock lifters are as good a bet as any these days. _________________ ... |
Dazed42 Samba Member
Joined: May 01, 2004 Posts: 1148 Location: Copperas Cove, Tx
Posted: Sat Jun 11, 2005 2:11 pm Post subject: |
I'd like to hear some opinions on those also, maybe from someone who has used them before. _________________ Proud owner of a super fatty.
Do you love the KAC?
www.dallasaircoolers.com |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15600 Location: Deep in the 405
Posted: Sat Jun 11, 2005 4:58 pm Post subject: |
Who actually makes CB lifters? I have heard that there are only 2-3 companys that actually MAKE lifters. The rest just buy somebody else's and put them in their own packaging. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
clearsurf2001 Samba Vaccinator
Joined: February 26, 2004 Posts: 1671 Location: Dave-AKA-fortyeye-Oceanside, Ca
Posted: Sat Jun 11, 2005 6:32 pm Post subject: |
Web Cam Part #00-213
Assuming your cam is new ... that's what Web recommends. _________________ Get ready for the injection
EverettB wrote: |
Make sure it is coherent. Rodney |
mharney wrote: |
I think Glenn has an EMPI crank in his engine. |
BoredandStroked Samba Member
Joined: May 31, 2003 Posts: 169 Location: South East of Disorder
Posted: Sat Jun 11, 2005 10:13 pm Post subject: |
CB=Scat lifter
Web=Scat lifter
The 2 piece CB is probably not a scat. I love the old eaton lifters, also old made in the usa bugpacks are good. Reground version of a good proven set of used lifters would be my pic. I'm done with new lifters. _________________ That little yellow box at the back of the car is the 330' timer
If the ocean were whiskey, and I was a Duck, I'd swim to the bottom and drink it all up. But the ocean ain't whiskey, and I ain't a Duck, so I'll just sit on the beach and watch Pelicans fuck... |
Jeremy Samba Member
Posted: Sun Jun 12, 2005 1:10 pm Post subject: |
If the web lifters are scat, those are out of the question.
The 2 piece cb's look like what I'm going with, unless someone has heard bad things about them. |
The Noof Samba Member
Posted: Sun Jun 12, 2005 1:27 pm Post subject: |
I also used a web cam shaft and lifter set, and the stuff is first class. Excellent product and service there. |
Kaferfiend Samba Member
Joined: August 15, 2004 Posts: 439 Location: Selah WA
Posted: Sun Jun 12, 2005 2:32 pm Post subject: |
Jeremy wrote: |
What's wrong with the scat's? I've heard nothing but good stuff from Scat stuff....
On a side note, if you're looking for people that have had problems with every part.... you'll never complete a motor. There are people out there that can't make a cable tie work correctly... and these people have no voice as far as I'm concerned.
-kf |
Posted: Sun Jun 12, 2005 3:24 pm Post subject: |
Kaferfiend wrote: |
Jeremy wrote: |
-kf |
rotflmao...excellent point.  |
Posted: Sun Jun 12, 2005 3:42 pm Post subject: |
Kaferfiend wrote: |
-kf |
I'll get the zip ties to work someday  _________________ Proud owner of a super fatty.
Jeremy Samba Member
Posted: Sun Jun 12, 2005 4:56 pm Post subject: |
Kaferfiend that is true.
I had a scat lifter destroy my last motor after about 4000 miles. The head of the lifter broke off and dusted my cam. one other was pitted badly. Who knows maybe it was a bad lifter, since I have never had a problem with any of their other stuff. which IMO is some of the best out there. Btw I am still using a scat crank and rods in this motor but I am somewhat concerned about the lifters. I'm just wondering if there is a better option besides ceramics |
Posted: Sun Jun 12, 2005 8:55 pm Post subject: |
Jeremy wrote: |
Yikes! Did you contact Scat with a lawyer ready to fight?
-kf |
Jeremy Samba Member
Posted: Sun Jun 12, 2005 10:29 pm Post subject: |
LOL
I figured thats what I get for beating on that motor like it was a red-headed stepchild....
The rest of the motor was actually pretty good still.... case was toast, the lifter bore was beat badly. I did get $400 for the balanced crank assembly which is now living as a 1600 in a friends 66. Plus I still have the heads which are going on the 2110. |
MaidenFan Samba Member
Posted: Sun Jun 12, 2005 11:22 pm Post subject: |
Do you suppose you could win if a lifter did wreck your engine??? _________________ +1 post!
The two rules of procrastination: 1) Do it today. 2) Tomorrow will be today tomorrow.
Never put off until tomorrow what you can do the day after tomorrow.
Procrastination is like masturbation. At first it feels good, but in the end you're only f@%king yourself.
horsepower: my anti-drug |
Jeremy Samba Member
Posted: Sun Jun 12, 2005 11:32 pm Post subject: |
Dunno - It would be hard to prove for sure. They would get some "expert" saying that everything wasn't set up properly or some other bs. Plus the lawyer fees would probably be more than just building a new engine.  |
jamestwo Samba Member
Posted: Mon Jun 13, 2005 5:08 am Post subject: |
I had a failure with a SCAT lifter, and know of many others.
Most of the time it's pitting on the face of the lifter. Only people I hear from who like SCAT lifters are drag racer who only use their cars to race with.
If you running SCAT lifters on the street, it's not a matter if they will pit, it's only a matter of when. most of the time it's in the first 10,000 miles.
Search this forum and shoptalk, you'll see SCAT lifters are junk! |
Alan_U Samba Member
Joined: July 10, 2004 Posts: 1762 Location: Vancouver, BC Canada
Posted: Mon Jun 13, 2005 7:50 am Post subject: |
jamestwo wrote: |
Tommy L at scat says theres no problems with those lifters
A friend of mine has used the same exact lifters in his drag car for years and years and years with no problems. He might have a couple hundred miles on them but you must remember its 1/4 mile at a time.
kaferfiend, if your using a set of those scats (not made by them by the way) you'll have nice pits in due time guaranteed without a question. Theres an engine builder I know that had his scats explode on him and destroyed a brand new motor on a dyno. He was using K800 springs that have extremely high spring pressure at the nose of any cam.
I would have to admit that a broken lifter head potentially may not be the cause of the scat product. If per say the lifter bore was out of spec any wobble in the lifter will break any lifter on the market INCLUDING CERAMICS. The location of the lifter bore can vary from casting to casting of the engine case. That is just one of the potential problems I think with our flat 4.
James is generous saying 10,000 miles. I am finding most are experiencing pits in just 3000+ miles. A very high percentage of scat lifters will breakin beautifully but the pitting will follow afterwards in due time.
did I ever tell you how much I just love taking my motor apart. Its just like a cracker jack box and your just eager to see what prize you'll get. Whats the prize??? these babies
by the way those were reground virgin scats with precise maching of the head to promote good lifter spin. All 4 out of the 8 had pits and the other 4 showed signs of major heat spots just ready to get pitted. Had about 3000+ miles on them. NO VALVE FLOAT EITHER TO CAUSE PITTING.
you play you pay. This is just a part of aircooled performance. _________________ 11.92sec pump gas true daily driver. Who says it cant be done.
No more time for VW's....... |
RUI FARIA Samba Member
Joined: July 23, 2004 Posts: 176 Location: Johannesburg, South Africa
Posted: Tue Jun 14, 2005 3:38 am Post subject: |
I have seen many pitted lifters both original German and aftermarket, one thing I can tell you is that I have seen a lot more aftermarket broken or damaged lifters than original German lifters, I have used only original German lifters and mostly refaced, I stay away from the other stuff. Most aftermarket lifters will be pitted or dished in the first 5000 kms, this will not happen even on a refaced original German lifter. |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Tue Jun 14, 2005 11:01 am Post subject: |
RUI FARIA wrote: |
YES, YES, YES!!!! I have really come to love stock reground lifters in almost all applications. I don't see the pitting and they really wear much slower. |
