oil bath aircleaner
miller0358
miller0358 is offline
PostPosted: Fri Sep 23, 2011 12:54 pm    Post subject: oil bath aircleaner Reply with quote
1971 oil bath stock aircleaner. I searched and couldn't find the answer I was looking for. I want to give the aircleaner a good cleaning and was thinking of having it powder coated. Will the heat from powder coating do any harm to the fiber in the top part of the cleaner. Jeff
Shewster
Shewster is offline
PostPosted: Fri Sep 23, 2011 2:39 pm    Post subject: Reply with quote
Check out this thread. I posted a pic of my 72 rehabed oil bath. It hasn't been engine tested yet, but I used a high quality paint (solvent resistant) from Eastwood. I don't know the answer to your question about powder coating the upper element. If you go that route definately send a picture. I want to see it when it's done.
http://www.thesamba.com/vw/forum/viewtopic.php?t=480390&highlight=
'72 Bug, One-family car, 350k happy miles (ok, a few of those miles were not so happy)
torsionbar
torsionbar is offline
PostPosted: Fri Sep 23, 2011 4:25 pm    Post subject: Reply with quote
the coir fibers in the upper part are natural fibers, and are flammable when exposed to high enough heat. they're also coated with light oil, or they are supposed to be if it was properly maintained (kerosene, mmo, or diesel) which is of course flammable. powder-coating ovens are typically 350 - 400 F and the flash point of these light oils falls within that range.
to summarize, maybe it will work and maybe it will burn. if it were mine, i would paint it.
Max Welton wrote:
[air cooled vw's] are no longer suitable for the general public. The owner has to be be able to maintain the car. And that is after fixing all the deferred maintenance items and ill-conceived modifications. If you can't do those things you are pretty much screwed.
miller0358
PostPosted: Fri Sep 23, 2011 6:09 pm    Post subject: aircleaner Reply with quote
Thats the answer I wanted to hear. No need taking a chance on ruining a 40 yr old air cleaner. Paint it will be the way to go. Jeff
