Parts for hand / parking brake handle
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Sun Dec 11, 2022 5:47 pm    Post subject: Parts for hand / parking brake handle Reply with quote
While working on replacing my front carpet I unbolted the hand brake lever to get it out of the way, and I figured it could use a cleaning and re-lube. It's been kinda sketchy lately.
Found that one of the pins that hold the device together is missing the E-clip and that two of the pins are getting wallowed out where the E-clip goes.
https://volkswagen.7zap.com/en/usa/vanagon/va/1990-78/7/711-70001/
Buslab is out of stock of these pins # N90209501 (#12 in diagram)
https://www.buslab.com/product-p/n90209501.htm
And the E-clip # N0124373 (#13 in diagram)
https://www.buslab.com/product-p/n0124375.htm
Have checked the other usual sources and came up empty. Any ideas for suitable replacements?
Also have a question about the silver cup shaped device at the end of the spring # 481-711-327 (#4 in diagram).
On mine it's kinda mushed, I have managed to bang it back into shape but there does not seem to be a definitive location for this thing. It's just sorta jammed at the end of the flare. Wondering why it got mangled.
(I'll post picture in a bit)
Currently:
All that's needed for evil to prevail is for good people to do nothing.
ALIKA T3
ALIKA T3 is offline
PostPosted: Sun Dec 11, 2022 5:54 pm    Post subject: Re: Parts for hand / parking brake handle Reply with quote
You could prolly get the pin machined for fairly cheap (not as cheap as the NLA part though). What's the E clip size? 8mm ballpark? Fit a 5/16" clip or have the groove machined to accept an imperial clip ( yuck).
kevinm
kevinm is offline
PostPosted: Sun Dec 11, 2022 6:13 pm    Post subject: Re: Parts for hand / parking brake handle Reply with quote
Regarding items 12 and 13: would one of the clevis pins from this site work?
https://www.mcmaster.com/clevis-pins/clevis-pins-with-retaining-ring-groove-6/
MsTaboo is offline
PostPosted: Mon Dec 12, 2022 12:37 pm    Post subject: Re: Parts for hand / parking brake handle Reply with quote
OK, I got lucky and found the missing E-clip. It had fallen off and dropped down into the plastic cup the brake rod/cable goes through.
Fortunately for me it was well wedged under the rod at the very bottom so didn't get sucked up while I was vacuuming all the old contact cement flakes.
Just fyi, Weedle does stock the E-clip, it's also used on the bay transmissions.
However the groove in the pin is so worn the clip will most likely pop off again so I still need to replace these.
Haven't been able to find a metric version so might have to use imperial and oversize the holes.
Stock pin is 15 mm long, 13mm diameter, 12mm groove, with 9mm between shoulder and groove. Groove is just over 1mm wide.
(edit per below; should say 8mm diameter, 7mm groove)
Wish I had a lathe, could easily turn one out of 7/16" (should be 5/16") stock. Neutral
Currently:
syncroserge
syncroserge is offline
PostPosted: Mon Dec 12, 2022 1:15 pm    Post subject: Re: Parts for hand / parking brake handle Reply with quote
Wish I had a lathe, could easily turn one out of 7/16" stock. Neutral
A lathe would do a better job..but with those dimensions and a Dremel you can make one from an M14 or 9/16" bolt pretty quick.
Steve M.
Steve M. is offline
PostPosted: Mon Dec 12, 2022 8:35 pm    Post subject: Re: Parts for hand / parking brake handle Reply with quote
You could put the bolt in a drill and spin it while using the cutting disc on a Dremel to make the ring groove. Then use the cutting disc to cut the bolt to the length you need.
jimf909
jimf909 is offline
PostPosted: Mon Dec 12, 2022 9:21 pm    Post subject: Re: Parts for hand / parking brake handle Reply with quote
While we're all spit-balling, is there a shoulder screw that can serve this purpose or provide a headstart on machining a suitable replacement?
https://www.amazon.com/SZHKM-Tolerance-Industrial-Applications-SD5SL4-M3TL6/dp/B07R3JMTJM
- Jim
Butcher wrote:
Guilty as charged.
MsTaboo is offline
PostPosted: Tue Dec 13, 2022 12:28 pm    Post subject: Re: Parts for hand / parking brake handle Reply with quote
Thanks for the ideas. I might just use a bolt and nylock nut until I can find (or make) the real thing. There's enough room under the cover to hide the (gasp) counterfeit fasteners for now.
The assembly is way more stable with all three pins holding it together, and a cleaning plus lube has smoothed the action.
Still not sure how that little cup at the end of the spring got chewed up.
Currently:
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Dec 14, 2022 10:49 am    Post subject: Re: Parts for hand / parking brake handle Reply with quote
13mm diameter is a rare thing with the Germans, it's usually 12 or 14 for shafts Rolling Eyes They really wanted to make it hard to drop in something else! Or maybe a gross 1/2" pin from the link Kevinm posted would match then just make the groove?
MsTaboo is offline
PostPosted: Fri Dec 16, 2022 9:21 pm    Post subject: Re: Parts for hand / parking brake handle Reply with quote
Here's that picture I forgot to post.
Currently:
syncroserge
PostPosted: Fri Dec 16, 2022 9:59 pm    Post subject: Re: Parts for hand / parking brake handle Reply with quote
Not sure they are the right dimensions but those sure look a lot like the clutch and brake clevis pins.
https://vancafe.com/clutch-brake-pedal-pin/
pathao
pathao is offline
PostPosted: Fri Dec 16, 2022 10:18 pm    Post subject: Re: Parts for hand / parking brake handle Reply with quote
looks like there's enough space on the nose of those to drill for a small cutter-pin. Along with a regular flat washer and call it a day
1982 AC P27 - 2.0 FI FED - 091 - BA6
English is a second language to me
RGS Paul
RGS Paul is offline
PostPosted: Sun Dec 18, 2022 3:18 pm    Post subject: Re: Parts for hand / parking brake handle Reply with quote
The diameter is 8mm, not 13 mm. One of mine is also worn, I'm ordering a shoulder screw from McMaster to try and I'll report back.
Paul
'87 Syncro 7-Pass. Adventure Touring Vehicle
"Simplicate, then add lightness." Colin Chapman
djkeev
djkeev is offline
PostPosted: Sun Dec 18, 2022 4:25 pm    Post subject: Re: Parts for hand / parking brake handle Reply with quote
Paul
8mm ..... 5/16" ........ virtually identical.
5/16 inch = 7.9375 mm
Dave
Ghia
Vanagon
Beetle
MsTaboo is offline
PostPosted: Sun Dec 18, 2022 6:51 pm    Post subject: Re: Parts for hand / parking brake handle Reply with quote
RGS Paul wrote:
The diameter is 8mm, not 13 mm. One of mine is also worn, I'm ordering a shoulder screw from McMaster to try and I'll report back.Paul
HA! Good catch. Total embarrassing brain fart. Misread the metric scale on my calipers while scribbling down the measurements, d'oh! should have caught the fact that they're not a 1/2" in dia. Embarassed
Yep, 8mm diameter with 7mm groove.
Currently:
RGS Paul
RGS Paul is offline
PostPosted: Sun Dec 18, 2022 7:04 pm    Post subject: Re: Parts for hand / parking brake handle Reply with quote
I was having to convert manually so I was extra paranoid. Mine has the same worn groove yours probably does so your three was timely. We’ll see how things sort out. It’s such a short pin I was having a hard time finding something off the shelf, it would be easy enough to machine though. The tolerances on the stock ones don’t seem especially tight.
Paul
