bodgoco Samba Member
Posted: Sat Jun 30, 2007 7:06 pm Post subject: rear hatch hinge assembly |
I have a 66 deluxe that was used as a laundry truck for years unfortunately some one backed up with the rear hatch up and damaged the hinges and springs. I have a donor bus that I am using to replace the hinges and spring assembly. Has any one ever taken these things out there killing me! Need to replace so I can put the headliner in any hints. |
campingbox  Samba Member
Joined: November 14, 2000 Posts: 10249 Location: Petaluma, CA
Posted: Sat Jun 30, 2007 9:02 pm Post subject: |
It's a piece of cake. One person job and it only take about an hour to do both sides. The key, is to relieve the spring tension before removing the retaining pins and then the whole thing comes apart. Read you're Bentley manual, or simply use some common sense and your prybar and you'll be set in no time. |
chiroracer Samba Member
Joined: August 03, 2006 Posts: 347 Location: long beach
Posted: Fri Apr 18, 2008 9:38 am Post subject: |
Anyone know where to get one of the pivot bolts for same? _________________ 66 bajawestfalia
2/1600 buggy Kreger chassis 4 baja 1000(waiting to re emerge)
71 911 track car
65 kombi EZ camper (sold to OG owner in oregon)
69 class 11 racecar Sold to GH racing now the famous Dora SCOREchampion
70 class 11 prerunner |
mysamba Samba Member
Joined: March 30, 2008 Posts: 75 Location: California
Posted: Fri Apr 18, 2008 4:21 pm Post subject: |
I am in the same boat, could you post some pictures of your progress... |
Posted: Fri Apr 25, 2008 11:21 am Post subject: |
I am trying to get one of the "pivot pins" that join the sprung lever to the curved pressed hinge piece ratlookvw has them for sure but I need to send him a pic I will get a pic this afternoon and update then. Steve _________________ 66 bajawestfalia
71 911 track car
widehatch Samba Member
Joined: May 27, 2007 Posts: 777 Location: Memphis, TN aka The Armpit of the South
Posted: Tue Jul 06, 2010 7:12 am Post subject: |
i need to replace the rear hatch springs on my 67. i've loaned out my bentley manual and now its skipped town with the borrower. can anyone post some detailed step by step instructions. replacing the first set of hinges looks pretty easy but i'm having a hard time figuring out how to remove the springs. i thought id ask before i screw something up. _________________ Missouri Micros |
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
tubdub Samba Member
Posted: Tue Jul 06, 2010 12:30 pm Post subject: |
Dave, you wanna come by and replace mine sometime? i cannot find the right tool  |
Posted: Tue Jul 06, 2010 9:09 pm Post subject: |
Sorry Bob, I have a definite aversion to strong springy things. I don't heal very fast any more.  |
tubdub Samba Member
Posted: Sun Jul 11, 2010 2:27 pm Post subject: |
picked up the homemade tool from islandveedub and it actually went pretty fast. took the pieces off the parts bus roof and installed them on my bus. anyone in the sac area that needs to do this repair can borrow this tool . pm me |
Posted: Mon Jul 12, 2010 12:39 pm Post subject: |
can you explain the steps you took that made the job so easy. most people are saying its hard as hell. _________________ Missouri Micros |
tubdub Samba Member
Posted: Mon Jul 12, 2010 2:15 pm Post subject: |
mousegrey64 wrote: |
can you explain the steps you took that made the job so easy. most people are saying its hard as hell. |
i just followed the instructions from the link dstfun posted.. might have been easier as the bus only had the hinges and no tension bars and the roof i got the parts from was flipped upside down and laying on the ground  |
