veegish Samba Member
Joined: November 17, 2008 Posts: 20 Location: Salt Lake City
Posted: Mon Nov 17, 2008 1:56 pm Post subject: *SOLVED* Hesitation and Stumbling Under Load |
Hey friends, I just found this site and joined right up! I have read all the posts on stumbling I could find and nothing quite matched what I am experiencing. Here's the scoop:
Engine is a '71 DP with dual Weber 34 ICT's, Bosch Blue coil and 009 dist. Timing is at 30 degrees at advance, carbs are fully sync'd, new NGK plugs with gaps at .024
A week or so ago my baby started running rough, it was cold and snowy and so i didn't want to get into it at the time (first mistake). After two or three trips to work and back (22 miles each time, freeway) I decided to figure out what the heck was going on. No real surprise, the dist. clamp was loose and toast! I replace it and got everything timed up just as above, but have a serious problem. The engine hesitates and stumbles under load at higher rpm's, seems fine in neutral if i gun it. I can only get to freeway speeds by gently and oh so minutely pumping the pedal, constantly finding the sweet spot that let's the rpm's get up there.
Help! I can't think of anything else to do besides the 'ol standby, start replacing parts (i.e. distributor, coil, carbs, engine, etc.). My wife HATES it when I do that, so I really gotta figure this out! Oh, yeah, and I don't have the cash to take it in...
Thanks,
Zak
Randy in Maine Samba Member
Posted: Mon Nov 17, 2008 2:28 pm Post subject: |
Dwell angle?
Timing? |
Posted: Mon Nov 17, 2008 2:52 pm Post subject: |
Pertronix Elec. Ignition
30 degrees BTDC at 3600+ RPM's (fully advanced) |
gregthomas Samba Member
Joined: March 24, 2008 Posts: 927 Location: Big Blue Nation
Posted: Mon Nov 17, 2008 2:54 pm Post subject: |
Just off the top of my head... bad, fuel filter, clogged up carb, bad plug, bad plug wire, valve adjustment or bad condenser. When was the last time it had a tune up? _________________ Checkout my church's website: http://www.ebcky.com
We offer podcasts of Sunday Sermons, articles and more! |
Posted: Mon Nov 17, 2008 3:06 pm Post subject: |
new plugs, wires look fine, new fuel filter, no condenser.
this seems to have been a direct result of driving three days with a moving dist. as it was great before and now it's not. i know that random coincidence does happen, but not that often. why would my valves all of the sudden go out of adjustment after running with bad timing for 60 miles? or my plug wires fail? I am willing to replace what I need to, but don't want to replace what I don't have to. Oi
I will clean the carbs as well. |
Posted: Mon Nov 17, 2008 5:50 pm Post subject: |
Start by adjusting th evalves since that is free and easy to do.
See if any are tight. |
jamesdagg Samba Member
Joined: August 18, 2007 Posts: 3364 Location: B.C.Canada
Posted: Tue Nov 18, 2008 2:38 am Post subject: |
Test your fuel pump pressure. With a meter. Squirting in a can isn't good enough. Mine was low and had those symptoms.
jim _________________ '72 FI Westy
'71 Super rear inside defrost vents no longer available |
Posted: Tue Nov 18, 2008 3:55 pm Post subject: |
Update: Valves are perfect now, car runs better than it has for a long time, WHEN I PUMP THE FRIGGIN GAS WHILE I DRIVE! Arrgh!
I go back to my original post and pose the question: Is it possible that my distributor has been damaged by driving with the clamp loose for about 60 miles? If timed at 3100 RPMs for 30 degrees total advance, my idle is at 15 degrees. What I am saying is that my total distributor (009) advance is 15 degrees from idle setting to high rev full advance. This seems wrong to me. How can I get the often recommended 28-32 degrees at full advance and the idle setting of approx. 7.5-10 with only a 15 degree window? Or is it one or the other?
Could it be my coil?
Could it be my electric fuel pump, which worked fine before the loose dizzy clamp?
Zak
*note* this problem seems to only occur under load, when i am in neutral and behind the car revving it up, it is smooth and neat! |
Posted: Tue Nov 18, 2008 4:12 pm Post subject: |
The tabs on the end of the dizzy that engage the drive gear may have been damaged. Also, pull the cap off and twist the rotor, it should spring back to its original position. I've also had the tab inside the rotor that engages the dizzy shaft wear down and cause the rotor to move around. _________________ Checkout my church's website: http://www.ebcky.com
Posted: Wed Nov 19, 2008 7:40 am Post subject: |
| Rotor springs back, and the tabs looked good when I pulled the dist. to replace the bad clamp... |
Posted: Wed Nov 19, 2008 9:58 am Post subject: |
| veegish wrote: |
IMHO if your only getting 15 degrees total advance I'd say your right. I chucked my crappy chinese 009 in favor of an SVDA because it just didn't run right and it didn't advance very far either. Runs great now. I'd get Glenn's opinion first though. _________________ Checkout my church's website: http://www.ebcky.com
Posted: Wed Nov 19, 2008 3:57 pm Post subject: |
SOLVED!!
The guts of the dizzy went south! I replaced it (with another 009, sorry) and I am back in bizness! All tuned up to boot! Thanks guys!
Zak |
SkrapMetal Samba Hornblaster
Joined: January 18, 2006 Posts: 2558 Location: Dallas, TX
Posted: Wed Nov 19, 2008 4:01 pm Post subject: |
| veegish wrote: |
SOLVED!!
Zak |
The guts? As in your Pertronix? _________________ oo9less since 2007
-72 Ghia- |
swhitcomb Samba Member
Joined: November 05, 2003 Posts: 5785 Location: Inwood WV
Posted: Thu Nov 20, 2008 5:14 am Post subject: |
As far as I know, idle on a 009 should be around 7.5 degrees atc when the timing is correct. Granted, idle isn't what counts, full advance is. That's 7.5 degrees off, and could account for a hesitation. Probably why changing the 009 for another "solved" it. Personally, I'd have spent the extra on a SVDA. I've driven both. 009 just doesn't compare. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Posted: Thu Nov 20, 2008 7:30 am Post subject: |
Just out of curiousity, what's the full advance on the new 009? _________________ Checkout my church's website: http://www.ebcky.com
bugninva Samba Member
Joined: December 14, 2004 Posts: 8857 Location: sound it out.
Posted: Thu Nov 20, 2008 8:09 am Post subject: |
| gregthomas wrote: |
| Just out of curiousity, what's the full advance on the new 009? |
honestly, it depends on the unit... I've seen them that only had 10 degrees of advance and some that had 25 degrees and several points in between... more advance in the lower rpms doesn't really hurt and i've gotten better performance when idle timing is at 10-12BTDC with the total around 31... but every engine is different, and with the quality of the 009's(which are really a comprimise but can work) every one of those are different too.... _________________
| [email protected] wrote: |
| With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
Posted: Thu Nov 20, 2008 9:20 am Post subject: |
| bugninva wrote: |
| gregthomas wrote: |
honestly, it depends on the unit... I've seen them that only had 10 degrees of advance and some that had 25 degrees and several points in between... more advance in the lower rpms doesn't really hurt and i've gotten better performance when idle timing is at 10-12BTDC with the total around 31... but every engine is different, and with the quality of the 009's(which are really a comprimise but can work) every one of those are different too.... |
What would be the "ideal" advance? _________________ Checkout my church's website: http://www.ebcky.com
Posted: Thu Nov 20, 2008 9:26 am Post subject: |
there is no known "ideal" as I stated all engines react differently.. there are general curves and ranges that work well for the majority... as I said, I've had the most luck with around 10-12 initial advance and 31 total mechanical. that is just the total advance, if you get into actually tuning a distributor to an engine it also involves setting the advance curve... this is easily done with aftermarket distributors that are designed with this in mind (I like the Mallory unilite) but not as easy with the stock type (and stock copies) distributors... with the available mechanical distributors, out of the box all you can do is set total advance and let the rest be... or you can open them up and experiment... but it's not really for the faint at heart... _________________
Posted: Thu Nov 20, 2008 9:33 am Post subject: |
| bugninva wrote: |
| there is no known "ideal" as I stated all engines react differently.. there are general curves and ranges that work well for the majority... as I said, I've had the most luck with around 10-12 initial advance and 31 total mechanical. that is just the total advance, if you get into actually tuning a distributor to an engine it also involves setting the advance curve... this is easily done with aftermarket distributors that are designed with this in mind (I like the Mallory unilite) but not as easy with the stock type (and stock copies) distributors... with the available mechanical distributors, out of the box all you can do is set total advance and let the rest be... or you can open them up and experiment... but it's not really for the faint at heart... |
Cool, thanx for the info. _________________ Checkout my church's website: http://www.ebcky.com
