TC/TeamEvil Samba Member
Posted: Sun Nov 20, 2011 6:42 pm Post subject: Trimming the torsion bar end caps . . . ? |
Is it possible to take a sawz-all to those tubes protruding from the end caps on the IRS rear torsion housing and shorten 'em up a bit? I have a small import body shell that need about one inch of that tube removed per side in order to slide all of the way down over the pan and "sit" with the right stance. I know that the swing axle is missing them entirely, I suppose that I could somehow use that set up in conjunction with the IRS diagonals and all, but I really just need a smidge of room and was wondering if a bob-job on the ends could be done without a big-assed hole in the world opening up and swallowing everything around me.
Excluding me, of course, 'cause I've got WICKED good luck ! ! ! ! !
Thanks !
TC |
slalombuggy Samba Member
Posted: Sun Nov 20, 2011 7:07 pm Post subject: |
Those tubes that stick out are actually the torsion bars and spring plates, you can't cut them. You can however, go to a shorter torsion bar and aftermarket springplates that get rid of the protrusion. I'm using them on my current Beetle project becasue hte raised torsion housing is now up in the body of the car
brad |
kustoms Samba Member
Posted: Sun Nov 20, 2011 7:12 pm Post subject: |
No, The splines are at the ends. You cut them off, "you gots nuttin." Your tail will hit the ground. _________________ Google this.
"Bread and Circuses"
And wondering what the heck happen to my Samba post count?!?
Tom Thompson
Tijuana Kustoms Inc. (TM)
1-516-338-8746
www.tjkustoms.com |
Posted: Sun Nov 20, 2011 7:15 pm Post subject: |
| slalombuggy wrote: |
brad |
This is true. One thing to think about is you will get a much firmer ride. The longer the torsions are the softer the ride. _________________ Google this.
Tom Thompson
1-516-338-8746
www.tjkustoms.com |
jsturtlebuggy Samba Member
Joined: August 24, 2005 Posts: 4627 Location: Fair Oaks/Orangevale, CA
Posted: Sun Nov 20, 2011 8:04 pm Post subject: |
Switching to the shorter torsion bar can be done. I have done it with several buggies I have owned.
Use to cut down the swing axle spring plates to fit the IRS supension before they started selling them.
Now just buy the cheap adjustable spring plates, it is a lot less work.
What I have found is using the torsion bars out of 1967-68 Bugs which are 21mm diameter. These are 1mm smaller in diameter then both the stock IRS and earlier 60s swing axle.
The 21mm short torsion bar is very close in spring rating of the 22mm IRS long bar.
Going to them really improved my ride being softer like what you would feel with using the longer bars and they will clear a 31in plus, tire with out any interference. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Mon Nov 21, 2011 3:27 pm Post subject: |
PERFECT ! ! !
Thanks guys, I KNEW that you would have the answer for me ! ! ! !
TC |
Posted: Mon Nov 21, 2011 11:46 pm Post subject: |
To bad CIP1 does not post the diameter of the torsion bar.
It may be that Bettles shipped to Canada did not come with the smaller diameter bar and the Z-bar overrider system.
This is the rating of the torsion bars I was talking about.
The 21 3/4in long 21mm diameter bar is rated at 488 in lb for 1 degree of twist.
The 26 9/16in long 22mm diameter bar is rated at 464 in lb for 1 degree of twist.
Really close in spring rate.
The 21 3/4in long 22mm diameter bar is rated at 588 in lb for 1 degree of twist.
From experience you can feel the difference the 1mm smaller make a big difference.
I still finding 67 and 68 Bugs in Pick N Pull yards. There out there.
And if you do use the aftermarket spring plates, they are a 1/2in wider across the face than stock one.
Without modifying the springs by notching or modifying the stops on torsion housing you may not get even stock travel.
This was on a Tow'd project that was using axles and CVs from a Porsche 924 and I was trying to get the most travel I could get. _________________ Joseph
Elrod Motorsports
LeeVW Samba Member
Posted: Tue Nov 22, 2011 12:58 am Post subject: |
| Also notice how Joseph rounded the corners of the spring plate close to the three slotted mounting holes. If you don't clearance the corners like he did, you won't be able to slide the trailing arm far enough forward to acheive the proper amount of toe-in. |
Posted: Tue Nov 22, 2011 6:50 am Post subject: |
We got Zee bars, far longer than you did. We had swing axle rear ends up untill 70s on some cars.
brad |
Posted: Tue Nov 22, 2011 7:07 am Post subject: |
If you had the Z-Bar for a longer period of time, then it should be easier to find the smaller 21mm diameter torsion bar. _________________ Joseph
Elrod Motorsports
vincent9993 Samba Member
Joined: November 09, 2006 Posts: 2025 Location: Montreal
joescoolcustoms Samba Member
Posted: Mon Jan 23, 2012 6:38 pm Post subject: |
Don't forget these fairly new on the market spring plate covers.
3c http://www.thesamba.com/vw/classifieds/detail.php?id=1235293 _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
crowe66 Samba Member
Posted: Tue Jan 24, 2012 3:35 pm Post subject: |
What outer bushing does it use?? _________________ 65 Beetle
Berrien Nostalgia Buggy - 67 chassis |
Posted: Tue Jan 24, 2012 3:42 pm Post subject: |
| crowe66 wrote: |
What outer bushing does it use?? |
Round, 1 7/8" hole standard bushing.
He also makes these for the long IRS spring plate caps. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6768 Location: Northern California
Posted: Tue Jan 24, 2012 5:18 pm Post subject: |
Those look nice. |
Posted: Tue Jan 24, 2012 5:23 pm Post subject: |
| BL3Manx wrote: |
Those look nice. |
I was thinking the same thing. Maybe I will add them after the build is done....$100 can be spent someplace else right now. _________________ 65 Beetle
| BL3Manx wrote: |
Those look nice. |
I ordered a set, thanks.
Now I just need confirmation on the best torsion and plate to get. |
Posted: Tue Jan 24, 2012 9:26 pm Post subject: |
| Quote: |
What will your use be on this buggy? Harsh off roading, mild off road, mostly on road, high horse power, carry a lot of weight, want a soft ride for those old bones, desire to be adjustable?
The 61 to 68 swing torsion bars are the stiffest VW made and will carry the most load per inch of stock OEM bars. The late long IRS is the softest bar and give the smoothest ride for a stock OEM bar. After market bars will put you anywhere you want to be.
Regarding the spring plates, the aftermarket plates lack in one thing, they are not made of spring steel. The OEM stock spring plates are made of spring steel. Every notice how a swing spring plate will be twisted when the suspension is at full droop, but then returns to flat once taken apart from the axle tube? The after market spring plates do not offer that same kind of spring twist as the suspension cycles from droop to compressed. This makes the suspension react somewhat stiffer, giving a slightly rougher/harsher ride.
If at all possible, stay with rubber rear spring plate bushings. They make a much better ride quality in the long run.
Just some data to chew on when making your decission. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Tue Jan 24, 2012 10:09 pm Post subject: |
Get adjustable spring plates, the longer the torsion bar, the better the ride.
Standard Sway-a-way adjustable spring plates are high quality spring steel. The race ones are even better.
http://www.swayaway.com/springplates.php |
