Bob's 1959 Single Cab Pickup — "Otto"
Page: Previous  1, 2, 3 ... 10, 11, 12
bobrk
bobrk is offline
PostPosted: Mon Feb 28, 2022 11:28 am    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Yesterday, I got a new battery and some Marvel Mystery oil. It's my understanding that I should pour some in the spark plug holes before spinning the engine over? It's been sitting for 20 years or so...
1959 Single Cab “Otto”
1500 single port | 1963 small nut/big brake transaxle | CSP Disc Brakes | dual circuit m/c | Deutsch Polster seats
ach60 Premium Member
ach60 is offline
PostPosted: Mon Feb 28, 2022 2:31 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Drain the gas, check the timing and set with a static timing light.
Buy a can of starting fluid, but use it sparingly.
You may also want to get new set of points & condenser.
On my '78 I'm using a 2042 Compu-Fire Module Kit - 205 1971-on
I don't know if it will work on your distributor, or even if the 2041 Compu-Fire Module Kit - 009, 050, 094 will work for you.
Both of these are available from CB Performance.
When I installed mine I had to sand the base of the rotor to allow for the thickness of the timing ring that goes on the distributor.
I remember I couldn't get Otto started, but I never chased down the issue.
Good Luck
Al
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
blink
blink is offline
PostPosted: Tue Mar 01, 2022 7:11 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Yep best way is to pour some down the cylinders and then use a spanner
and turn the engine over by hand. The starter is great to turn it over but
if you end up having a patch where the engine freezes up the starter motor
will just try and smash passed it which could cause an issue where as by
hand you can slowly rock it either way and work past it with out causing much damage.
just take your time if it does or if to does just turn over nice and easy straight away then you set.
bobrk
bobrk is offline
PostPosted: Sun Mar 13, 2022 5:34 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Chased the flat front tire problem a bit, took the wheel off and got well over 100psi in it, but it's not popping in at that pressure, looks like it's leaking from only one spot along the bead. Will probably take it to the tire store to reseat it, although I bet once I get the truck running, a spin around the block might seat it as well.
Got the new battery in, almost all the electrical stuff works. No generator, oil, or high beam light, though—need to check those bulbs.
Took out the spark plugs and they looked fine. Tried to pour some Marvel in the cylinders, but didn't have the right funnel. Reinstalled the spark plugs...
Put a new fan belt on—that's a fun process!—and turned the motor over a few times by hand. There seemed to be some compression. Then used the starter. It seemed to spin fast, so I think the next job will be to check the valves. It is a 6 volt starter, though, so maybe that's why it was so fast?
Visual inspection of the engine revealed some oil leaks so may have to clean things up and figure that one out.
bobrk
bobrk is offline
PostPosted: Mon May 23, 2022 12:52 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Finally got around to doing something to Otto last weekend.
Took the carb off, took it all apart and checked everything out. Rebuilt it with a new carb kit.
Looked at the air cleaner (some foam thing we bought way back when) and noticed the foam was coming apart and stuck to the cleaner. Bought a new one at CIP
Looked at the fuel line from the pump to the carb, looks fine, good thing we put high quality hose in there. Fuel filter looked super crusty, so bought some fuel filters from CIP.
Also bought some valve cover gaskets and oil change kit from CIP in anticipation of a valve adjustment and oil change.
Didn't take any pics, sorry.
bobrk
bobrk is offline
PostPosted: Mon Jul 25, 2022 11:09 am    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
So I was a dope when I put this bus away 20 years ago. I didn't empty the gas tank, and now I have a huge problem. The gas tank seems to be full of chunky rust and bad gas, so this problem will have to be dealt with.
Yay!
bobrk
bobrk is offline
PostPosted: Mon Jul 25, 2022 8:28 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
At least the tank is easy to get out.
Filler
My buddy used a sender to blank off the tank
Looks bad inside
Bought it at Bugformance in Sunnyvale
It’s Brazilian
Pickup trucks are easy though.
Can’t figure out what’s happening here…
ach60 is offline
PostPosted: Tue Sep 20, 2022 1:26 am    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
If you still haven’t decided what to do, try calling San Jose radiator, they may be able to save that tank.
Good Luck
Al
bobrk
bobrk is offline
PostPosted: Tue Sep 20, 2022 6:41 am    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Already got a new tank, putting it all together now!
bobrk
bobrk is offline
PostPosted: Sun Sep 25, 2022 9:23 am    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Getting there. Rebuilt the fuel tap, sawed off the rusty sender float and grabbed just the top for a blank off plate. Waiting for the felts and another seal to install it.
bobrk
bobrk is offline
PostPosted: Tue Jan 10, 2023 12:41 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Well, I did do something to my truck recently. I had to move it because I was getting a new roof on my garage!
Hopefully when the 40 days and nights of rain stops here, I'll get back to it.
bobrk
bobrk is offline
PostPosted: Sun Feb 12, 2023 11:31 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Aw, my bus turned 64 today.
bobrk
bobrk is offline
PostPosted: Sun Dec 03, 2023 12:34 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Yeah, I've gotten behind on this, too many other projects, but I was looking at the date and chassis numbers of my pickup and they are a little off from the chassis number list at https://www.thesamba.com/vw/archives/info/chassisdating.php
My m-code plate has a date of Feb 12, 1959 and a chassis number of 439093.
The chassis list says:
1959:
Jan: 433713
Feb: 443662
Are those STARTING numbers or ENDING numbers, or are these just inaccurate due to the shifting sands of times? And apologies if this has already been covered...
Stocknazi
Stocknazi is offline
PostPosted: Sun Dec 03, 2023 2:46 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
The VIN numbers in the chassis list are the LAST one of that month.
M-plate you are correct February, 12 1959. MONTH/DAY/YEAR
Congrats on owning this bus for 30 years! You were smart to hang on to it all these years.
WANTED:
Thomas Jefferson
bobrk
bobrk is offline
PostPosted: Sun Dec 03, 2023 3:07 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Thanks, I still love it.
bobrk
bobrk is offline
PostPosted: Sat Dec 30, 2023 8:45 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
I love seeing old buses that are scruffy like mine...
https://sfbay.craigslist.org/nby/cto/d/fairfax-1959-volkswagen-bus-van-split/7702586369.html
bobrk
bobrk is offline
PostPosted: Thu Feb 15, 2024 11:03 pm    Post subject: Re: Bob's 1959 Single Cab Pickup — "Otto" Reply with quote
Welp now my bus can apply for Medicare.
The weather is turning nicer so I may start to finish up some things on it.
Page 12 of 12
