DesertG Samba Member
Posted: Sat Mar 04, 2023 5:41 pm Post subject: Oil Cooler Wiring |
Unfortunately, the prior owner put an external oil cooler with a fan on this car. I will remove it eventually, but I want to make sure it was done right.
I there was no thermostat, so I have one now to put in.
On the car, how do I tell which hose would be the oil inlet vs outlet.
Can the 12v Keyed power be the positive side of coil?
I like the on off light indicator. Where do you mount one in the car.
Thank you!
_________________ 1965 Beetle, 1970 1600cc DP, 12v |
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 4140 Location: Rapid City, South Dakota
Posted: Sat Mar 04, 2023 7:35 pm Post subject: Re: Oil Cooler Wiring |
Put the t-stat on the outlet side, then the oil will warm up faster, and the fan will run less.
Also run a ground to the t-stat switch, and let that ground 86 on the relay on/off. Run the keyed 12v straight to the 85 on the relay. It usually makes for less wire runs, and it is easier to wire that way. Less current running through the t-stat switch.
Brian _________________ So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts |
Posted: Sat Mar 04, 2023 7:42 pm Post subject: Re: Oil Cooler Wiring |
Thanks Brian. On the car, how do I tell which hose would be the oil inlet vs outlet. Can the 12v Keyed power be the positive side of coil? _________________ 1965 Beetle, 1970 1600cc DP, 12v |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80061 Location: Sneaking up behind you
Posted: Sat Mar 04, 2023 7:48 pm Post subject: Re: Oil Cooler Wiring |
| DesertG wrote: |
| On the car, how do I tell which hose would be the oil inlet vs outlet. |
Follow the hose from the engine. The one that exits the oil pump is the outlet of the pump. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Sat Mar 04, 2023 8:32 pm Post subject: Re: Oil Cooler Wiring |
Thanks Glen, here is what I have. Does the prior owner have the (broken) thermostat on the line in?
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15602 Location: Deep in the 405
Posted: Sun Mar 05, 2023 12:16 am Post subject: Re: Oil Cooler Wiring |
With a 1600cc engine as in your signature I would immediately remove the auxiliary oil cooler and install a dog house oil cooler and shroud, no matter what the cost and eliminate all you extra baggage and head aches. The way the cooler is mounted up against the package tray there is not very much room for cool air to circulate around it. I'd bet your engine would run a lot cooler with a factory dog house cooler and shroud. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Glenn  Mr. 010
Posted: Sun Mar 05, 2023 5:40 am Post subject: Re: Oil Cooler Wiring |
Looks like the stock non-dog house cooler was remove and this is the only cooler.
I'd go back to stock or convert to a dog house oil cooler and remove the remote one. It's probability not needed. _________________ Glenn
Member #1009
#BlueSquare
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20873 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Mar 05, 2023 8:42 am Post subject: Re: Oil Cooler Wiring |
Best solution is as others say, just replace what you have with stock cooler...
With the adapter that is on engine the upper hose is "OUT" of engine and "IN" to cooler, the lower hose connection is "IN" to engine and "OUT" of cooler....
Don't know what the device is in hose, everyone does this sort of thing different/non standard...
Relay polarity in real life does not matter.... Unless it had a diode across the coil windings... The current passing through the coil creates a magnetic field which causes armature to move, closing a set of contacts that is all it is... And Yes technically 85 should be ground or negative and 86 should be 12 volts or positive by DIN standards ...
And yes cooled where mounted so close to bottom side of package tray is very poor for air flow... It makes it almost useless.... It needs more air gap for air flow... _________________ “Fear The Government That Wants To Take Your Guns"
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Sun Mar 05, 2023 8:56 pm Post subject: Re: Oil Cooler Wiring |
On your electrical drawing, usually #85 on the relay is ground, and #86 switched power. Sometimes it doesn’t matter, sometimes there is a diode in the relay and it does. Just fyi _________________ foam cowboy hats aren't good helmets. |
Posted: Sun Mar 05, 2023 8:58 pm Post subject: Re: Oil Cooler Wiring |
Thank you guys. Can the 12v Keyed power be the positive side of coil? _________________ 1965 Beetle, 1970 1600cc DP, 12v |
Posted: Sun Mar 05, 2023 9:10 pm Post subject: Re: Oil Cooler Wiring |
| DesertG wrote: |
| Thank you guys. Can the 12v Keyed power be the positive side of coil? |
I wouldn't. If the fan kicks on and blows a fuse the car will die. Could be a problem driving on a busy street. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Sun Mar 05, 2023 9:14 pm Post subject: Re: Oil Cooler Wiring |
the fan will be connected to a relay _________________ 1965 Beetle, 1970 1600cc DP, 12v |
Posted: Sun Mar 05, 2023 9:25 pm Post subject: Re: Oil Cooler Wiring |
I don’t see a problem running it off the coil. It’s such a small current needed to activate. Just fuse #30 from the battery and you’re good. _________________ foam cowboy hats aren't good helmets. |
Posted: Fri Mar 24, 2023 12:41 pm Post subject: Re: Oil Cooler Wiring |
After reading more, I am guessing the prior owner added this oil cooler because of 1600cc and no vents on the deck lid. Not sure.
I am going to rewire this weekend. Which way should the fan spin. Sucking air down or blowing air up through the heat exchanger.
Also, if anyone added the light to let you know the fan is running, where did you mount one. I like the idea.
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1662 Location: Marshallville Ohio
Posted: Fri Mar 24, 2023 1:46 pm Post subject: Re: Oil Cooler Wiring |
you should put the thermostat on the "IN" hose to the cooler.
If you put it on the out, it will cause it to "short cycle" and wear out the relay real fast.
Better to have it control the fan based on oil coming right from the motor as it will be most accurate and it will stay on continuous until temps are brought down (no short cycling). |
Posted: Fri Mar 24, 2023 1:55 pm Post subject: Re: Oil Cooler Wiring |
thanks Tom, yes, will run from Oil In line. Which direction should the fan blow.. _________________ 1965 Beetle, 1970 1600cc DP, 12v |
Posted: Fri Mar 24, 2023 2:32 pm Post subject: Re: Oil Cooler Wiring |
| DesertG wrote: |
| thanks Tom, yes, will run from Oil In line. Which direction should the fan blow.. |
instructions on my last one said either way will work. All depends on where you want the hot air to go.
On my Dune Buggy, I mounted the oil cooler in the spare tire well (behind the drivers seat ) flush with the body. I have a switch on the dash so I can reverse the fan blowing the heat inside the buggy if I get chilly. Works fantastic... |
Posted: Fri Mar 24, 2023 2:50 pm Post subject: Re: Oil Cooler Wiring |
Thanks Tom! _________________ 1965 Beetle, 1970 1600cc DP, 12v |
