Loren  Samba Member
Posted: Tue Mar 07, 2023 1:32 pm Post subject: Re: Fantasy Porsche option project |
That looks sharp! Nice color combo. |
Marcdeb Samba Member
Braukuche Samba Member
Posted: Fri Mar 31, 2023 8:32 am Post subject: Re: Fantasy Porsche option project |
Thanks for the comments everyone.
We are in that phase of the project where more time is spent than things accomplished it seems. But nonetheless progress is being made. The dash is finally complete. We decided the factory steering wheel doesn’t work with the overall aesthetic and so ordered a beautifully done Vintage Aircooled Parts custom wheel which is very similar to an optional Les Leston Porsche 356 wheel, but better made in my opinion. Since this is a performance build we opted to go simple on the sound system and stuck with the original AM/FM radio and a Retrosound speaker under the dash. We also bought a matching Vintage Speed shifter with a ball socket bushing for tighter shifting.
In the rear, we installed an anti sway bar set up for improved handling.
The long block is done on the Porsche 912 spec engine. We used 86mm big bore pistons, 912 heads, 912 spec cam, C crankshaft, new 12 volt flywheel designed to run a stock VW clutch pack, 12 volt small body 912 generator, powder coated tins and a stock replacement muffler to get the Porsche growl.
_________________ Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia |
kingkarmann Samba Member
Posted: Sun Apr 02, 2023 6:14 am Post subject: Re: Fantasy Porsche option project |
It's all in the details
I'm really digging that steering wheel  |
Posted: Tue Apr 11, 2023 7:12 pm Post subject: Re: Fantasy Porsche option project |
Well, it’s in.
This is the second time this year I’ve installed a Porsche 356/912 engine in a Ghia and could do a whole write up on it for those interested. But for this thread I’ll just say it’s a lot easier doing it in a later model car than early, the only modification necessary are the rear and front tins have to be trimmed as well as the side tins, and it’s crazy easy to install one, easier than a regular VW engine.
The biggest challenge for both cars has been the muffler. And here I discovered that an aftermarket 356A muffler is easier to fit than an original A muffler.
Anyway, it’s in and I think looks like it belongs there.
It’s a 1720cc using 86mm big bore pistons and cylinders from AA. Reproduction brand new Solex carburetors, stock for European market 031 distributer with Pertronix electronic ignition module and coil, electric fuel pump, C crank, 912 spec cam, 912 heads, 912 rods, everything balanced. Stock 1600 engine put out 104hp, I imagine this one puts out a bit more.
Retirement is here!
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
1989 Westfalia |
tri356 Samba Member
Posted: Tue Apr 11, 2023 8:13 pm Post subject: Re: Fantasy Porsche option project |
Nice work Dan! That looks great.
Mike |
Posted: Tue Apr 11, 2023 9:33 pm Post subject: Re: Fantasy Porsche option project |
tri356 wrote: |
Mike |
Thanks Mike and thanks for you’re help. _________________ Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
1989 Westfalia |
PeteSC Samba Member
Posted: Wed Apr 12, 2023 6:31 am Post subject: Re: Fantasy Porsche option project |
Yep, looks right at home in there. Outstanding result! |
Era Vulgaris Samba Member
Joined: August 22, 2012 Posts: 1932 Location: Raleigh, NC
Posted: Wed Apr 12, 2023 4:44 pm Post subject: Re: Fantasy Porsche option project |
Looks amazing, that's going to be one really fun car to drive! _________________ Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue |
obus  Samba Member
Joined: March 08, 2001 Posts: 11698 Location: just off Garden State Parkway Exit 81
John Moxon  Samba Moderator
Joined: March 07, 2004 Posts: 14229 Location: Southampton U.K.
Posted: Thu Apr 13, 2023 5:04 am Post subject: Re: Fantasy Porsche option project |
"I know a guy that put a Porsche motor in a VW"
Heard at nearly every show I've ever attended.
Really, I know a guy
Very nice  |
Posted: Thu May 11, 2023 6:38 pm Post subject: Re: Fantasy Porsche option project |
Well, it’s finally up and running and at my house to do the final detailing and polishing. We drove it 15 miles on the freeway from the shop to my house and it’s got a tall third, easily can go to 60mph and fourth almost acts like a fifth gear. Brakes great, and with all the sound deadening sprayed on the inside metal, it’s the quietest convertible Ghia I’ve ever driven.
The Porsche engine fits like a glove. The rear tin is completely fabricated, we have eight hours just into that but it looks factory I think. Which is of course the whole point of the project.
After I detail it we will put 300 miles on it to shake out any bugs and then list it on BAT.
Retirement is here!
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
1989 Westfalia |
Posted: Thu Aug 03, 2023 7:15 am Post subject: Re: Fantasy Porsche option project |
I’m case anyone wants to see a drive video of this car, it’s up right now on BaT. Gives you an idea of what a Ghia with a Porsche engine can do.
https://bringatrailer.com/listing/1974-volkswagen-karmann-ghia-convertible-24/ _________________ Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
1989 Westfalia |
