132AH LiFePO4 easily fits inside the battery box
Page: Previous  1, 2
fxr
fxr is offline
PostPosted: Thu Feb 09, 2023 5:08 pm    Post subject: Re: 132AH LiFePO4 easily fits inside the battery box Reply with quote
loganthecyclist wrote:
fxr wrote:
If the big thick wire on the left is the battery negative, why is there another wire connected to the same post of the shunt? The battery negative should be the ONLY connection to the shunt input post, so that all current flows through the shunt.
The thick wire on the left side of the shunt goes to chassis ground. The battery negative is connected to the right side of the shunt.
Oh yes! A senior moment - I didn't even read the excellent labels... Embarassed
Jim Crowther
Vespa GTS 300
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Wed Mar 08, 2023 8:10 am    Post subject: Re: 132AH LiFePO4 easily fits inside the battery box Reply with quote
PSA:
My driver side 'house' battery box has no "drains." any moisture that goes down there, at least in my case, stays in there until it evaporates.
If your house battery box is also like mine, consider adding weep holes, or such.
Finding this out, in my case, was NOT FUN AT ALL. Most likely I spilled a flimsy cup of water below my left elbow backwards, and the liquid ended up in the box with nowhere to go. However, I am not 100% sure I actually did that, it is just the only explanation I have for a self-caused inch or so of water down in there. I had also, in the same time frame, driven through some of the worst sloppy wet 7" snow storm I have done in my bus, and there could have been another way for liquid intrusion. It was water, not tea, and those are the only things I drink while driving.
Page: Previous  1, 2
Page 2 of 2
