lightice Samba Member
Posted: Wed Aug 23, 2017 5:02 pm Post subject: Country buggy transmission |
Hi, anyone has any experience with the country buggy transmission?
I came into possession of a H case transmission.
It has large nut RGBs.
I have checked on thesamba for the owner's manual and only found the philippine version, but that didn't include the gear ratios in them. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71520 Location: Phoenix 602
Posted: Thu Aug 24, 2017 8:33 pm Post subject: Re: Country buggy transmission |
Hi Everett, I've checked through that thread.
The problem is the country buggy was produced after 67, while it used the large nut. |
Posted: Fri Aug 25, 2017 6:30 am Post subject: Re: Country buggy transmission |
I did glance through the material, but totally missed out on that.
Thanks!
Guess some who advised were wrong in that not all the gears were the same as the H case buses ones.
The third gear is different.
Did VW ever had a fine tooth 0.82?
Or did they retain the 0.82 coarse tooth?
Wonder what's the 1.26 one.  |
Posted: Sun Aug 27, 2017 9:24 pm Post subject: Re: Country buggy transmission |
That's a bummer, I was hoping it was the longer 1.22 so I could have a 'stock' gearing on my bus. |
Posted: Sat Sep 02, 2017 11:40 pm Post subject: Re: Country buggy transmission |
Coming back to the country buggy transmission.
Anyone has any parts diagram?
The reduction boxes look distinctively different from a split bus reduction box. |
Posted: Mon Sep 04, 2017 10:58 pm Post subject: Re: Country buggy transmission |
Someone sent me the diagram of the reduction boxes, but not the transmission.
He also quoted the transmission parts as having:
Gear Train (3rd Speed) - 113 311 275A
Gear Train (4th Speed) - 113 311 341
Which is contradictory to the sales brochure.
if search the p/n the third would be a 1.22 and forth would be a 0.89. |
nbturbo Samba Member
Joined: August 26, 2004 Posts: 184 Location: Australia
Posted: Thu Oct 05, 2017 11:15 pm Post subject: Re: Country buggy transmission |
I came by a C/B front end and transmission complete many years ago.I have decided to overhaul the lot in readiness for a project.I have discovered that Holden Commodore front disc rotors fit straight onto the C/B spindles,so have had some adapters made to mount the Holden calipers.I have bought a full set of new bearings and seals to make it happen.I have located a double sided IRS gearbox with 4.12 diff and having that converted to swing axle and crown wheel turned over.I will do a disc brake conversion on the reduction boxes with the 5x120 stud pattern.This will give good highway speed with some big wheels on the back. |
bally Samba Member
Joined: April 29, 2006 Posts: 1195 Location: Melbourne, Australia
Posted: Fri Aug 05, 2022 5:22 pm Post subject: Re: Country buggy transmission |
nbturbo wrote: |
Did you ever finish this gearbox mod? I’ve never heard of that before so curious to know how it worked for my own cars.
Cheers. Dave |
Posted: Tue Jan 03, 2023 3:05 am Post subject: Re: Country buggy transmission |
bally wrote: |
nbturbo wrote: |
Cheers. Dave |
I had the transmission fully rebuilt using the later IRS box.The IRS box had a 3.88 final drive,but there was some reason why it couldn't be used.It is too long ago for me to remember.The specs listed in the brochure for 4th gear were not what was in my CB transmission,but again I do not remember what it was.I sent an early 40 horsepower transmission to the builder to get the course tooth 0.82 4th gear set to fit.The process that occurred with this job didn't go well.The guy building i, had it in his workshop for at least 3 years before he started the job.He contracted cancer early on and I didn't put any pressure on him because I had started my Beetle Ute project-so wouldn't need the trans for at least 4 years.When started,he took another couple of years during his chemo and drug therapy.This was one of his last jobs before he passed away.I had known him for about 50 years in the VW scene here and was a good friend and VW enthusiast.I still haven't finished my Ute project and am in 2 minds what to do with the CB transmission. |
bally Samba Member
Posted: Tue Jan 03, 2023 4:31 am Post subject: Re: Country buggy transmission |
Thanks for your detailed response. Sorry to hear about your friend passing. Good luck with the Ute. Time to get back on it? Dave |
JeffL Samba Member
Posted: Tue Mar 14, 2023 7:53 pm Post subject: Re: Country buggy transmission |
In my small cabinet of treasures I do have a County Buggy parts manual.
Is there something specific I can help with?
I always wanted a Country Buggy but stopped with the small fortune in the manual. One can hope.
_________________ http://karmannghias.org/
https://karmannghias.org/GAlken/index.html |
